How to disable JTAG interface on ATMEGA1280
13 posts / 0 new
I'm programming an ATMEGA1280 on a custom PCB via an Arduino Mega 2560 as ISP.
How can I disabled the JTAG interface? I know it's the JTAGEN bit that needs to be set to 1 but I don't know how to do it via the arduino IDE.
Thanks for your help!
How is Arduino programming it? If by bootloader you can't change the fuses. Look at doing the double write to JTD
The ArduinoMega2560 is set as ISP and is wired through the ICSP  (MISO,MOSI, ect) to  the atmega1280.
How do I write to the JTD?
Do that in software when you write the code,add the following code in setup()
Edit: corrected reg name and remove the RMW
MCUCR = (1<<JTD);
MCUCR = (1<<JTD);
Do I need to include a library? Because I get : 'MCUCSR' was not declared in this scope
Don't use ¦=, it forces an RMW which might jeopardize the 4 cycle requirement
What does the datasheet say about how to disable JTAG programmatically?
Which register has that bit on that model?
Many (most?) questions posted here are answered with a datasheet excerpt.
Could you tell me how to set the register please? MCUCSR is not recognized
Thank you for explicit answers since i'm new to the programming world :)
See post #4, code corrected for M1280
theusch wrote:
What does the datasheet say about how to disable JTAG programmatically? Which register has that bit on that model?
I guess the green means you worked it out but just to be clear...
If you're programming a custom PCB using ISP programming, you should learn to use AVRDude or one of the equivalents to set the fuses, externally of the Arduino IDE.
The IDE will disable JTAG with the "Burn Bootloader" command, but it will also set the fuses causing the chip to boot into the booloader section.
