SAMD21 Flashing
5 posts / 0 new
I want to make a custom board with SAMD21E18A-U but I dont have an ATMEL-ICE. Its the only option to flash SAMD21 or can I use another way to flash?
You can use other JTAG device, for example j-Link from Segger.
I apologize, I am at work and don't have AS7 installed on this machine. But if you go through the process of creating a new project, and when you are selecting the Device PN# you are using, a panel should appear on the right with links to the Datasheet, as well as show all of the Supported programmers.
murph
Debugging - Being a detective in a crime movie where you are also the murderer.
Can I use OpenOCD with Raspberry Pi?
Yeah, you can. This requires learning gdb and is way more complicated. https://learn.adafruit.com/debug... Here's Adafruit's guide on doing it with some debugging tools they recommend. You can, however, do this with any serial bridge if I am not mistaken. It may need to be supported by OpenOCD, but all you're doing is using a serial bridge to send openocd commands to a specific MCU.
Here's a video of MickMake doing this on linux: https://www.youtube.com/watch?v=...
im a penguin
