I'm using an ATtiny24A.
Is it still possible to enter serial programming mode if RSTDISBL fuse bit is programmed?
The data sheet says "If the RSTDISBL fuse is programmed, this start-up time will be increased to 14CK + 4 ms to ensure programming mode can be entered."
So if I apply power to VCC while I hold RESET low it should enter serial programming mode?
