AVR32 Studio + JTAG ICD mk-II + STK1000 not working
2 posts / 0 new
I've downloaded and installed Cygwin + AVR32 Studio 1.0.0 BETA 1. I've attached my JTAG ICE mk-II to my STK1000 development board. I want to compile, execute and debug the avr32101_the_avr32_interrupt_controller example ("appnote") working.
I've made a project and imported all the example's files (except the .html) and try to build the project, and get "No rule to make target `all'."
I'm stuck. My AP7000 project cannot proceed until I can build a project, any project, and download and run it on my STK1000.
Help?
Hi Gregory!
If you uncheck the "Build Automatically" item in the Project menu, I think you will find that building and cleaning the project starts working, assuming you also imported the makefile.
If that doesn't help, you could try to define the make target to have the builder execute it properly. Right-click the project and select "Create Make Target...". The default target will be "all", so just click the Create button.
When Build Automatically is checked, you need to set up which target to use, so go to the Project -> Properties, C/C++ Make Project and check the "Build on resource save (Auto Build)" option.
Hope this helps,
Tore
