How to compile a c program to run on sama5d27 running on Linux
10 posts / 0 new
I am new to processors that run Linux. I have got a sama5d27-som1-ek1, from the manual I am able to run Linux and access terminal from serial port. How do I compile c programs to run in Linux.
Load gcc and compile! Or load a cross-compiler and compile on a PC running linux.
Since C has its origins with Unix, just about any C book tells you how or the many millions of tuts and blogs on the interwebs.
Hopefully the linux distribution for the sama5 has the compiler as part of the package. Then google how to compile c program on linux
The PC doesn't even need to be running Linux!
By definition, a Cross-Compiler is one that generates code for a target different from the Host.
Indeed, the Product Page says,
 Linux distribution and software package allows you to easily get started with your development.
http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=ATSAMA5D27-SOM1-EK1
and
To get started with software development, please visit: http://www.at91.com/linux4sam/bi...
The whole point of running Linux is the the processor becomes (almost) irrelevant.
So any general Linux tutorial or book should be able to help you ...
So do you really mean to say that you are new to Linux?
Check out the Yocto project: https://en.wikipedia.org/wiki/Yo...
There is a port for the sama5d27: https://github.com/linux4sam/met...
And some related forums at: http://www.at91.com
Just started with sama5d27 SOM1 dev kit with PDA lcd display.  Created SD demo image and all running smoothly, can get command prompt via usb port.  Tried to apt-get to install toolchain etc
but apt-get not found.  Searched all over for alternative apt manager but nothing found. Also is there a GUI interface for the PDA display?  Appreciate a steer for solution?
Package manager? You’re in the wild west with embedded linux. Generally the likes of gcc can be found precompiled, but just about everything else gets compiled from source and likely cross-compiled. There’s usually something based on buildroot where there are scripts to build common packages as well as building the kernel and creating disk/flash images.
A quick Google suggests Yocto has sama5 support. I’d suggest getting that setup on a PC linux host.
Why cross compile? Doing a major build on the sama5 will slow disk storage and limited ram is Slooooooow. Even with the likes of the raspi, it is usual anything of reasonable size gets cross-compiled on a PC.
Thanks for response. Yes, I do/have xcompiled on PC within VM and your 100% right - much faster :)
I was trying to play with Python and wanted to install a few addo-on's etc and some other features but found no simple way to do; apt-get etc.
I'll post once I find a solution or "how to".
Openwrt is a buildroot based project that seemsto have support for the sama5.
https://www.at91.com/linux4sam/bin/view/Linux4SAM/OpenWrt
It can build python for you.
