how to write a library into a specific memory address using AtmelStudio
3 posts / 0 new
Im using the same library for my firmware and the bootloader. How can I write this library into a specific memory address so I can use it form the bootloader and the firmware.
Best regards
The library itself does not need to be in a "shared" location - just some "hook" to gain access to it's functions. That can be as little a a 16 bit pointer to a struct of function pointers.
Anyway assuming that by "Atmel Studio" you really mean the avr-gcc compiler then the way you manually position anything in that is by placing the code or data into some named section and then using the linker directive -section-start=.section_name=0x1234 to position it to flash address 0x1234. It's also possible to achieve this with linker scripts but the section start thing is probably the easier approach.
For example:
int up(int n) {
    return n + 1;
char down(char n) {
    return n - 1;
typedef void (* fptr)(void);
__attibute__((section(".shared"))) fptr functions[] = {
    (fptr)up,
    (fptr)down
then later:
-Wl,-section-start=.shared=0x1234
Now both this provide and also an accessor can know to look for a table of function pointers at 0x1234. The caller wanting to use down() calls through the second function pointer in this table.
