Unable to debug attiny88
5 posts / 0 new
Hi everyone,
I am using attiny88 and am unable to debug it using atmel ice.
When I use progisp, I can flash code on my attiny88 but when I use atmel ice, it shows error. " Failed to enable DW" .
I am using fresh ic and all the fuse bits are default set.
PFAWorking with progisp programmerDW error showing when using with atmel ice.
Akhilesh Gangwar
Atmel - ice is not selected.
No, it is selected.
I am able to debug other boards. atmel ice is connected
Akhilesh Gangwar
If you have an ATMEL-ICE surely you would use it for SPI programming. For a start, you could read the current fuses and lockbits.
If AS7 says that you can't enter debugWIRE mode, it probably means that you have got a capacitor on the dW/RST pin. Or a strong pullup.
Remove any capacitors and make sure that any pullup is >= 10k.
Make sure that you have a current version of AS7.
Actually, I have not put any pull-up resistors and capacitors. I have directly connected mosi, miso rst, 3v3, gnd and sck to atmel ice.
But if I use the old attiny88 which has dw fuse enabled, I am can debug the board using Atmel ice. But after debugging, I am unable to close debug fuse bit by selecting disable debug wire and close.  It shows error. And with new attiny88, I am getting the error as shown above threads.
So as long as I can understand, on my board, I am unable to disable/enable DWEN fuse bit. If it is enabled previously( by other means), I can debug and download, but can't disable it. And, if it is disabled( as in new attiny88), I am unable to enable DWEN fuse bit and can't debug.
Both the behaviour are on the same board. I have directly connected miso-miso, rst-rst, sck-sck, gnd-gnd, 3v3-Vsense and mosi-mosi of board and atnmel ice.
Any idea?
Well I am going to put all the efforts on the hardware side. Becasue I don't think there will be bug in atmel tool chain as it is the latest one and can do debugging on other avr boards.
Akhilesh Gangwar
