Cannot do programming 101....
9 posts / 0 new
Freaks,
Been looking at a line of code from a freak from the past that I am having an issue with understanding.
uint8_t button_scan;
uint8_t buttons = 0;
uint8_t butos = 0;
uint8_t last_buttons = 0;
buttons = ((button_scan & 0x04) == 0);  //<----this is bugging me
butos = buttons && !last_buttons;
last_buttons = buttons;
button_scan is loaded with a value in an ISR...Thats all well and good, and when the code hits the line above is where I am getting hung up over what is exactly going on.  It seems that 'buttons' equals the bitwise AND of button_scan with 0x04 (0x04 isolates the bit to test), thats all and well, but I cannot understand what the '== 0' is all about.
I am guessing that this:
is the same as:
if((button_scan & 0x04) == 0)
which means that if button_scan and 0x04 == 0,..... buttons = 1.
Correct?
Yes
is a boolean expression which is either true or false
EDIT
This could have been made clearer by declaring buttons as a bool, and giving it a more meaningful name; eg, button_is_pressed.
EDIT 2
The "== 0" is actually superfluous
can also be taken as a boolean expression:
  • It is true when bit 2 is set in button_scan;
  • It is false when bit 2 is clear in button_scan.
Andy, if you dont like the way its written you do not have to answer either.
Thank you for your reply though, I know its either true or false, but I was wondering if the way I am understanding it is correct with regards to the use of 'IF'.  Also since the and-ing being done, ie(button_scan & 0x04) would give a true or false, is it really necessary to have the '== 0' at the end?
JIm
EDIT:
I see you did an edit or two while I was typing! smiley
Yes because you are actually inverting the logical value, so if value == 0, you get 1, and if value != 0 you get zero.
So it would be equivalent to:
buttons = !(button_scan & 0x04);
Yabbut, I always thought that '=' sets the value, and '==' is comparing to.
For example:
if(a == b)
    //do something if a is equal to b
and....
a = b;
//sets a to the same value as b
That's correct, but here you have one of each:
So, if button_scan is 0x04, you get:
buttons = (0x04 == 0);
Since 0x04 is different from zero, the comparison takes value zero (false), so you get:
buttons = 0;
OTOH, if button_scan was zero, you would get:
buttons = (0 == 0);
The comparison would be true, so it would take value 1 (boolean true)
buttons = 1;
So, basically, buttons becomes 1 if bit 0x04 is clear, and 0 if it is set, that is, it takes the opposite value as the bit.
Ahhh! I see now(no pun intended)  I also looked it up in My Smileymicros book and theres a simple one line explanation that is very similar to yours.  Thanks!
off topic
mentioning smileymicros... it appears that Joe has closed up shop. Had anyone noticed that before?
valusoft wrote:
off topic
Joe and I email on occasion and last time he said he was going to cut back a little.  I know he ws having website issues so if the sites not up I wouldnt worry too much.  I'll reach out to him and see whats up.
