WHILE() in a SWITCH/CASE
34 posts / 0 new
Question is simply....Can I put a WHILE(){}  in a CASE?
Heres the scope.  I have to monitor a charging IC whose status is given on two outputs pins.  I want to do the following:
uint8_t charger_status = (pind & 0x03);
switch(charger_status)
       case 0x00:
           while((pind & 0x03) == 0)
               //do something
       }break;
       case 0x01:
           while((pind & 0x03) == 1)
               //do something
       }break;
       case 0x02:
           while((pind & 0x03) == 2)
               //do something
       }break;
       case 0x03:
           while((pind & 0x03) == 3)
               //do something
       }break;
       default:
       }break;
Reasoning for this is that I would think that this would be far more efficient than running the switch over and over to hit the same case until the inputs change.  The way I see the above is the code sits in the while() and when the inputs change the code exits the switch and then starts over on the next pass through.  There is a Timer Interrupt involved that is common to all the cases but that will not affect the operation from what I see.
Any thoughts on this?
I do it. Not frequently. But, one situation is a finite state machine managed with a switch/case list.
In some of those, I check the status of a received or transmitted async serial character using while( ). I've not seen any evidence that it does not work.
Why would you suspect that it is problematic?
West Coast Jim
I didn't think it would be problematic, I am just asking if any of the C gurus here can see any potential pitfall.
Good to see someone else has done this before and with success!
East Coast Jim
Seems like a simple switch inside of a while(1) will achieve the same result.
/pedantic-on
joeymorin wrote:
... while(1) ...
apparently one can be confused by 1 and l per K&R.
https://barrgroup.com/Embedded-Systems/Books/Embedded-C-Coding-Standard/Statement-Rules/For-While-Loops#footnote15
/pedantic-off
cheeky
Yes.
      }break;
It doesn't matter but why is the break outside the statement block? Personally I would have gone for:
       case 0x00:
               //do something
           break;
etc.
PS why "pind" and not "PIND" ??
In fact, why are the outer braces there at all?
It just needs to be
       case 0x00:
               //do something
           break;
etc.
Again, it doesn't actually matter here.
EDIT - also doesn't matter to the question at hand, but ...
Presumably, the code shown is just for illustration, but I'd prefer those pin & state values to be symbolically named - would also help to highlight that you're looking for the status to stay the same:
#define CHARGER_STATUS (pind & 0x03)
switch( CHARGER_STATUS )
       case STATUS_X:
           while( CHARGER_STATUS  == STATUS_X )
               //do STATUS_X stuff
           break;
       case STATUS_Y:
           while( CHARGER_STATUS  == STATUS_Y )
               //do STATUS_Y stuff
           break;
The 'C' syntax/semantics is fine.
Whether it's a good way to handle the charger is another question ...
Yes, but
But that's another question - see #9 ...
Why is there a switch/case at all? Couldn't you just have a series of while loops?
               //do something
               //do something
               //do something
               //do something
note: I'm aware the code is not equivalent, so it may or may not be possible to do this.
How is that equivalent? In the switch() structure only one case: so one while() loop will be executed while your code has all four consecutively.
However I do wonder why a switch() is needed too. Presumably:
while((pind & 0x03) == charger_status)
   //do something
would cater for all the cases in simpler code?
EDIT: ah ha - you edited in your additional "not equivalent" comment while I was typing that ;-)
Yeah, I had a feeling someone was typing a comment along those lines...
My thinking was that maybe this was all inside an infinite loop so it would not make much difference, since you would be constantly checking charger_status.
So now we're well off the original "is it allowed" question and into the (unrelated, but obvious) follow-on: "is it a good way to do it" question ...
See #9
laugh
Is it legal? Yes. Should you do it? I wouod only do it for a test scenario, or for a really simple application. Having the switch hit the same case repeatedly until the input changes is probably not going to cause any noticeable speed reduction, but tying up the processor in a while loop doesn't make much sense to me. I alway try to write non-blocking code if possible, although I confess that I sometimes use blocking UART send or I2C functions.
Indeed. Especially for a battery status - which does not tend to change frequently or rapidly.
Thanks for the feedback.  Lemme answer a few of the posts:
Yes, but there is more to this than I am letting on.  So as to not make this a bigger thread then need be I kept with what is always asked for which is compact code relevant to the question.  Which is can I do this, or is there a possible problem.  You are correct I can/could just keep scanning with a while(1)/switch, and I may end up doing just that, but for now this is what i am looking at doing.
awneil wrote:
Yes.
Perfect!!
clawson wrote:
      }break;
       case 0x00:
               //do something
           break;
etc.
I wrote this at midnight last night and I was pretty tired.  You are correct on both points.
awneil wrote:
EDIT - also doesn't matter to the question at hand, but ... Presumably, the code shown is just for illustration, but I'd prefer those pin & state values to be symbolically named - would also help to highlight that you're looking for the status to stay the same:
You're right it doesn't matter.  And the numbers 0..3 are pretty obvious that they are not going to change.  And if I had used 'symbols' then more questions as to what those symbols are/mean/etc....makes for long thread with posts for nothing.
Yup, as noted in #6, Thanks. the Charger is not the concern.  The syntax is.  I should have kept the application out of the OP.  OOPS!
awneil wrote:
Yes, but
Ahh yes! BUT!!  IF the inputs change during the time that the WHILE in the CASE is running then the case will BREAK and the whole thing runs again.  Which then brings us back to joeys comment about just running the switch over and over anyway....Sort of like the Chicken or the egg first.
   //do something
This is for both Cliff and El Tangas...The charger IC outputs on two pins four binary states - 0..3 to indicate what is going on.  For each one of those states I plan on flashing an RGB LED in some color pattern or whatever.  Hence the four cases and in each case - which corresponds to the condition reported by the IC the task for the AVR to perform.
See #9
laugh
Actually #6, and if West Coast Jim's ego feels bruised he did chimein first in #2,  but thats for discussion in another thread.wink
It is actually a very simple application.  In fact that code posted is just about all of it, sans the //do something, and the init.  While the unit is charging ALL the other functions are not used for the device.
Thanks all!
jim
Go for legibility.
Methinks efficiency will not be much of an issue here.
Go for legibility.
+1
Now.  What about later?  Future-proof your code, I always say ;-)
Fair enough.  You know us, though... we can't help ourselves blush
I certainly can't. So I'm going to suggest that maybe a timer ISR could sample the 2 bits regularly and set the status LED accordingly. This way, only a switch...case would be needed.
If this is just status information for humans, an ISR running at a few Hz would be enough.
Yeah I noticed that it does happen once in a while.....wink
El Tangas wrote:
I certainly can't. So I'm going to suggest that maybe a timer ISR could sample the 2 bits regularly and set the status LED accordingly. This way, only a switch...case would be needed. If this is just status information for humans, an ISR running at a few Hz would be enough.
Ok, ok, ok....enough.
When the unit is plugged in, the device enters 'Charger" mode and there is NOTHING else going on so no need for fancy, fancy, code stuff here. LOL! laugh
{ //do something }
Cliff,
I think I may be reading your code wrong, but How would that work for all four states as in each state something different is going to happen?
Confused.....
JIm
Which is typical for a Finite State Machine.
West Coast Jim
Oh I see - they all contained "// do something". I thought it was the same "something".
Just curious what charger IC we are talking about?   Always looking for cool charging circuits and ideas!
MCP73871.  Its a nice part.  Oh, theres actually a third status line, that I am not using for reasons I am not bringing up here.
Spoilsport!
cheeky
Ready for Tip #5 ... ?
wink
Spoilsport!
cheeky
Yeah, someone has to try and keep the topic on topic....
JIm
Back in 1983 Tom Duff invented something which became known as "Duff's Device":
send(to, from, count)
register short *to, *from;
register count;
    register n = (count + 7) / 8;
    switch (count % 8) {
    case 0: do { *to = *from++;
    case 7:      *to = *from++;
    case 6:      *to = *from++;
    case 5:      *to = *from++;
    case 4:      *to = *from++;
    case 3:      *to = *from++;
    case 2:      *to = *from++;
    case 1:      *to = *from++;
            } while (--n > 0);
Explanation on:
https://en.wikipedia.org/wiki/Duff%27s_device
If "do something" is always the same thing, than I would prefer
uint8_t initial_charger_status = (pind & 0x03);
while((pind & 0x03) == initial_charger_status)
    //do something
If "do something" is different, than I would prefer
void DoSomething0() { ... }
void DoSomething1() { ... }
void DoSomething2() { ... }
void DoSomething3() { ... }
typedef void (*ToDo)();
static ToDo ToDoList[4] = { DoSomething0, DoSomething1, DoSomething2, DoSomething3 };
        ToDoList[initial_charger_status]();
In the beginning was the Word, and the Word was with God, and the Word was God.
In the end I am not using the while() concept that started this. Just a simple SWITCH/CASE as was suggested. The while loop idea will be explored some more, but for now I need to get this thing done.
So, the charger section of the code is functioning properly and I thank everyone for heir contributions. I'll add another post later with the solution(s) pointed out as there were a few.
If you want to re- visit this later:
From my understanding the "case" statements are not more than labels (which have to resolve into an int) and are simply ignored by the rest of the code (Such as the while loop in Duff's device #29)
But the best place to get reliable info in this is probably the good ol K&R or the official C standard.
The Standard does, in fact, call them "case labels" (and the "default label") - there is no such thing as a "case statement".
EDIT
K&R likewise.
