C operators
9 posts / 0 new
What is the difference in the following operators in C? what values will they each output in avr?
PORTA = !0xff;
PORTA = ~0xff;
PORTA = !PORTA;
PORTA = ~PORTA;
PORTA^=0xff;
Put them in your chosen IDE and simulate them.
What does your 'C' textbook tell you?
Here are some links for 'C' learning & reference materials - including a free online textbook: http://blog.antronics.co.uk/2011...
Here's a Tutorial on bit manipulation in 'C': https://www.avrfreaks.net/forum/tut-c-bit-manipulation-aka-programming-101
PORTA = !0xff;
PORTA = ~0xff;
PORTA = !PORTA;
PORTA = ~PORTA;
PORTA^=0xff;
Your main doubt seems to be between bitwise and logical negation. It's simple. Logical negation of any nonzero value is zero, while bitwise negation inverts each bit of the binary representation of the value individually.
As they are entirely standard 'C' operators, it doesn't even have to be an AVR IDE, or any microcontroller IDE:  you could do this in any desktop IDE - MS VisualStudio; Borland (or whatever they're called today); whatever ...
Total votes: 2
#4 has most of what you need to know but just to point out that ! is "logical" and ~ is "bitwise".
One way to remember it is that ! turns truth upside down while ~ turns the bits upside down.
I like that - will have to remember it!
yes
And I guess the pedantic answer to the question, in several of the cases, is....'it depends on what value PORTA holds before the operation is executed.'
Sounds like a school assignment, I would suggest you read your text book, or at least the C references suggested above.
Keys to wealth:
Lets go Brandon!
