Using an external clock with an Atmega32
7 posts / 0 new
When set to use an internal clock, my app works ok.
When set to use an external clock (fuses CKSEL = 0000 and SUT = 10) the chip does nothing. I assume I have something wired incorrectly.
I'm using this external clock:
http://www.abracon.com/Oscillato...
I have it wired like this:
pin 1 floating.
pin 4 to ground.
pin 5 to xtal1 on the atmega32.
pin 8 to voltage.
Does anyone have any sugesstions as to what I may have wrong?
Thanks!
I would guess a busted oscillator. Do you have another to test with?
Those settings look ok, as long as you've got the pinout right. Do you have a scope you can stick on the output of the oscillator to test it?
Clancy _________________ Step 1: RTFM Step 2: RTFF (Forums) Step 3: RTFG (Google) Step 4: Post
The oscillators are brand new. I've tested 2 of them with the same result.
I don't have a scope :(
Are my fuses set correctly? (fuses CKSEL = 0000 and SUT = 10)
Yeah, those fuses look ok.
Try tying pin1 high in case the internal pullups aren't working?
Other than that, I dunno. It's hard to say without a scope to check the clock signal. Do you have another AVR you can test? Maybe the xtal input is fried...
Double check the connections is all I can think of.
You didn't mention this but do you have a capacitor in your circuit? It looks like it calls for a 50pF max cap. If you enable CKOPT (which enables an internal 36pF cap on XTAL1), does anything happen? Also what frequency is the crystal?
He's using an oscillator, not a crystal!
Leon
Leon Heller G1HSM
it's 3.686 mhz
