Just to be sure, isn’t true that it is not possible locking the MCU flash memory (of code) without locking with it the internal EEPROM?
In other words, it is not possible reading the EEPROM data (saved after running the MCU code for example) if the flash was locked at any level.
I use a standalone parallel programmer to program and read ATmega32.
Thank you.
