Graphical LCD using SPI
16 posts / 0 new
Hello Everyone;
I am using ATMEGA32 with a graphical LCD. I need that this LCD will run in SPI Protocol. Is it possible??
I have limited number of Pin so I want to connect the LCD with the minimum number of Pins.
Abhay02 wrote:
Is it possible??
Yes.
Many displays - or, specifically, display controllers - have an SPI connection.
But SPI is little more than just a connection - there is no specific protocol attached to SPI (unlike I2C).
Again, the protocol will be determined by the display controller.
Post a link to the actual display that you have bought.
Common controllers like KS0108 are "only parallel"
Modern controllers sometimes have multiple interface types.
The interface hardware configuration pins are not always accessible.
Thank You for reply.
 Can you please suggest me a graphical LCD which can work on SPI.
I have attached the image of the display which one I am using.
ST7920 modules can use SPI.    They are available on Ebay e.g. https://www.ebay.co.uk/itm/ST7920-128x64-12864-LCD-Display-Blue-Backlight-Parallel-Serial-for-Arduino-5V/302309454831?hash=item46630c33ef:g:LLMAAOSw42dZDZel
Those modules work on 5V.
http://www.lmgtfy.com?q=graphical+LCD+SPI
If you want a full, ready-to-go solution, try adding "Arduino" to your search.
I used this one in a project a few years ago:
https://www.adafruit.com/product...
But there are many other options... And I used a controller that was a lot faster, heres a short video just to show that it's running.
- Brian
When I view that video, one of the "related videos" suggested by YouTube is this:
ST7735 1.8" TFT Dispay: Hardware SPI vs bit-banging the SPI
It's on an Arduino - so should be ideal for the OP ...
I like the DOGM displays.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
I want to use ATMEGA32 micro controller only with a graphical lcd. Is it possible??
As you have been told many times.... YES.
Please suggest me the circuit and code..
Go on. Post #9 specifically gave you links to YouTube videos showing AVRs driving graphical LCDs.
Do you think those videos are fakes?
You already have at least half a dozen threads on this forum about AVRs driving graphical LCDs.
Are you not listening to anything anyone has said to you in all those threads?
Again, you already have at least half a dozen threads on this very forum where people have given you plenty of suggestions for both code and circuits.
And, apart from your own threads, there have been innumerable other threads on the subject.
There are plenty of examples on the interwebs.
I remember those threads also. AvrFreaks tells me I also contributed - not that I remember doing so.
My troll alert is bleeping away loudly but I cannot work out whether it's for real or a false alarm. I'm working on a project with QVGA (16-bit colour) and PIC32 so have an interest in this subject.
Anyway ... despite good advice to the contrary Abhay02 seems insistent on interfacing with ATMEGA32 and is struggling. Probably due to lack of enough I/O pins.
The other threads indicated that this is an upgrade to an existing project (that uses ATMEGA32) .
Now so much time has passed since the first posting which I think was April; that I would advise Abhay02 to do one of the following:
  1. Rework the whole project over again choosing a higher spec micro.
  2. Add a LCD daughter board with secondary micro which can handle a parallel interface thereby giving him a much larger choice of LCD.
  3. Continue to procrastiate endlessly and not ever start this potentially really interesting project.
Abhay02 could prototype #2 using Arduino or a kit off Ebay perhaps then actually get started on his code to see where the real problems lie.
