Armcc or GCC?
5 posts / 0 new
Hi All,
I'm trying to incorporate a static library into my project and I'm having a hard time determining what compiler library I need to select. I don't have much of a background in toolchains so I've found the terminology a little confusing and intermixed.
I have a selection of either armcc, avr or gcc. They are broken up as follows:
  • armcc
    • Cortex_M0
      • "Library File"
    • Cortex_M0+
      • "Library File"
    • Cortex_M3
      • "Library File"
  • avr
    • Cortex_M0
    • Cortex_M0+
    • Cortex_M3
  • gcc
    • Cortex_M0
    • Cortex_M0+
    • Cortex_M3
The MCU I'm using is the SAMD21J18A with Atmel Studio 7, so I know that the AVR options is out and that I need the Cortex_M0+ core.
After researching things online I have found the following:
GCC(OG):
  • Link: https://gcc.gnu.org/
  • The base line compiler that most toolchains are built on.
  • This is open source and community driven
GCC (GNU Arm Embedded Toolchain):
  • Link: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm
  • Toolchain developed by GNU that uses GCC as a core and incorporates ARM device support.
  • Due to the fact that the target devices are different from the workspace it is compiled on; this would make this a cross compiler?
  • Free as long as you follow GNU license agreement, plus open source
ARMCC:
I've looked at my build output and it spits out the following:
Building file: O:/CO/BoschLibraries/BSEC_1.4.6.0_Generic_Release_20180425/API/bme680.c
		Invoking: ARM/GNU C Compiler : 6.3.1
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe"  -x c -mthumb -D__SAMD21J18A__ -DDEBUG -DBOARD=SAMD21_XPLAINED_PRO -D__SAMD21J18A__ -DARM_MATH_CM0PLUS=true -DEXTINT_CALLBACK_MODE=true -DWDT_CALLBACK_MODE=true -DI2C_MASTER_CALLBACK_MODE=true -DSYSTICK_MODE  -I"../src/ASF/common/boards" -I"../src/ASF/sam0/utils"
From the line "Invoking: ARM/GNU C Compiler : 6.3.1", this makes me believe that Atmel Studio and the Samd21 are using the GNU ARM embedded Toolchain. I've also looked in the project properties and found that a lot of the properies just say either "Build option ARM" or "ARM/GNU C Compiler".
So would it be correct to say I am using the GNU Arm Enabled Toolchain(the gcc library option from above)?
Basically, I'm having a hard time distinguishing what terminology I need to look for to determine what toolchain I am using. If i was using Armcc would I see compiler exe calls from a directory with "/armcc/' vs "/gcc/ or "/arm/"?
Please feel free correct me as I want to learn the material, so any information would be helpful.
Thanks for the time and help,
Paul
psantos wrote:
I'm using ... Atmel Studio 7
Then the toolchain is GCC.
ARMCC:
 I don't think that ARMCC "uses gcc" in any way.   ARM bought Keil sometime back, and ARMCC is either based on the Keil ARM compiler, or is something new (web page says based on clang(?))
The "developer.arm.com" version should be the same as the gnu.org version, plus or minus version/feature skewing with binaries and bundles (gcc, libc, binutils)  pre-built for popular operating systems.  Yes, it's a cross compiler - I'm pretty sure that you can't get a "modern" C compiler that actually runs on a CM0...
All of the ARM compilers I'm familiar with are pretty standardized, and ARM defines pretty standardized ABIs and include-file formats.  Most libraries are pretty portable between different compilers.  Possible incompatibilities show up WRT inline assembly language.
Correct. Totally unrelated.
ARMCC is a commercial product - so you'd know if you had it due to the hole in your wallet!
"Something new", I think.
Keil's original ARM compiler was ditched.
Cool, Thanks for the info guys!
Marked as solved.
