Prototyping Boards
39 posts / 0 new
Total votes: 3
I'm old school and still build prototypes (as well as designing my code on paper first). Most of my stuff is more than just an 'Arduino + Shield' so I tend to end up hanging a prototype board onto an Arduino, or stuffing a Nano onto a prototype board. I also use some of these as almost disposable prototypes...
It's a useful little board but sometimes a bit small. As is the Arduino prototype board.
So I'm thinking of making my own and wondered what features I may have missed. So far I have...
mega328 in DIP
DC input jack
USB (power only) jack
2-way screw terminal for DC input
Aref capacitor
on-board 5V or 3V3 regulator (likely switching using a Recom part)
6-pin (FTDI) SIL header with DTR reset capacitor
6-pin AVR ISP connector
Prototype area with power busses
Easy access to all AVR IO pins
Crystal and capacitors
Area tracked for IDC ribbon 'output' connectors
Probably eurocard sized (160mm x 100mm) plus eurocard mounting holes
Area tracked for screw terminals
Unallocated buss lines for other power rails
Can anyone think of any other useful general purpose features?
I also wondered about doing an SMT version for the new 4809 as a second-gen Arduino version.
- One or more unallocated LEDs with series Rs
- Decoupling caps for your M328
- unallocated N channel mosfet for external relay drive
- test pins
- links in supply lines for measuring current consumption
- buzzer perhaps (with mosfet driver)
- RS485 driver (maybe)
- (G)LCD connections
IR transmitter/receiver devices (unallocated)
- unallocated trimpot (maybe to simulate analogue input)
- op amp (if you are into analogue)
- provision for I2C bus
Likewise.
The trouble I always find with commercial "development" boards is that they try to cram too much stuff on - which ends up just getting in the way of what I need to do.
Therefore I like Ross's idea of the unallocated extras - so you can easily connect them if you need them, but they don't get in the way when you don't.
I build things on Arduino Protoshield pcb.   The green pcbs on Ebay are better than the official Blue pcbs.   A Mega Protoshield has more area than a Uno one.
You can stack Shields if you run out of space.
I also solder breadboardable modules like BluePill or ESP32 onto a Protoshield.   Then I can attach other Protoshields.
Alternatively,  I put Arduino headers onto a regular large Protoboard.   (I have to crank the D8-D13 header to fit the 2.54mm matrix)
I still have several traditional dev boards that are useful for their "built-in" RS232, 7-seg, LEDs, LCD header, GLCD header, ...
Quite honestly,   Arduino format boards with onboard debugger  are a lot more convenient than dev board + power + debugger + trailing cables + ...
e.g. Zero, Nucleo, FRDM, ... need one USB cable.   ( + shield containing external electronics)
It is all a question of personal choice.    YMMV.
fyi, solderless IDC connectors :
https://www.mouser.com/new/Wurth-Electronics/wurth-redfit-idc-skedd/
The connector's lifetime is limited to 25 mating cycles for bench use (10 mating cycles for field use)
BusBoard has a mega1284 eurocard board.
http://www.busboard.com/microcontroller
Would be interested in a mega4809 with 1.27mm pitch SMD pads for the proto area.
A few leds should always be included, add header pins to them so you can jumper them to wherever you need.  Maybe 2 switches should also always be included, with a connection header.  A pot was also mentioned.
Or perhaps you prefer to solder in everything you want & have no excess---its a tradeoff.
Polyswitch (or fuse) on power input
Perhaps define a spot for a secondary regulator (diodes,reg & caps)---in case not everything runs at the same voltage (ex: feed in 15V, regulate 12V & 5V,  feed in 12v regulate 9V & 3.3V )
Thanks for the hint David, also found some nano to uno boards on Ebay as well.
Now the wait for china shipping. sad
Thanks, I did wonder about doing a 1284 version. That one probably has too much dedicated stuff on it and not enough 'sea of pads'.
or PolyZen (PolySwitch on Zener diode)
If Brian selects the Recom SMPS and it's 24V SLA battery for an electrical power source then it's PolySwitch (PolyZen is 16V max for one model)
PolyZen can get hot (a few watts)
https://www.littelfuse.com/products/polyzen-devices.aspx
avrcandies wrote:
Perhaps define a spot for a secondary regulator ...
Yes though a significant amount of analog can be on a 24V SLA; a relative few JFET op amps are 10V max.
3.3V is popular for cellular, Wi-Fi, LoRa, Bluetooth, and Ethernet modules.
Low noise regulators aren't a requirement or a need for both primary and secondary regulators.
IIRC, there's no EMC requirement for an evaluation board's regulators.
Maybe a more incremental improvement would be the Mega328PB. The 4809 is very different from a 328P.
Don't forget the 0.1 uF cap and 10uH inductor on the AVCC pin for noise cancellation as shown in the Analog Noise Canceling Techniques section of the ATmega328P data sheet.
MarkThomas wrote:
Don't forget the 0.1 uF cap and 10uH inductor on the AVCC pin for noise cancellation...
All my designs follow the letter of the Atmel 'How To..." App Notes.
El Tangas wrote:
... Mega328PB.
or mega324PB as mega328PB is on some third party boards whereas can't recall any mega324PB third party boards.
0-series megaAVR is the follow-on to PB megaAVR.
SMPS from Recom, are those those 3pin 78xx replacements?
Less soldering than a discrete solution, but trivial.
A shunt resistor together with a 2pin 0.1" header to measure the voltage over the shunt can be handy.
This 2 pin header can then also be jumpered if no current measurement is needed.
I like to have an obvious way to connect measurement equipment to GND.
2 holes of around 2mm diameter and 15 mm apart let you easily add a piece of copper installation wire (2.5qmm) for a big loop to connect the GND leads of your oscilloscope.
Layout for an UEXT connector may be handy.
It is a 10 pin IDC with UART, I2C, SPI & Power, specified by Olimex.
I also keep my development boards small, and then use a board to board connector (or IDC cable) to connect it to a regular protoboard.
Easy access to the unregulated supply will make it easy to add a 2nd voltage regulator for a different voltage.
Also: after a bit of practice soldering (the larger) SMD parts is easier than soldering through hole parts.
- No constant turning of the PCB
- Not getting confused by mirror images anymore.
- No components falling off.
- No clipping of leads for resistors, capacitors etc.
Also: I see you use tubes to isolate your wires.
I tend to use lacquered copper wire, with a hot (temperatur controlled) Iron ( 400 to 430 Celcius).
This is hot enough to burn through the lacquered wire, with no need for stripping the wires or cutting tubes.
(Download or open the picture in a separate tab to view it in higher resolution)
Is PCBA fab less expensive for SMD than TH?
Reasons :
  • advertisements from several PCBA fabricators for prototypes and very low rate production
  • Brian wants a pile for himself and to sell wink
Another instance except it's SMD :
ELM - Wiring Techniques
Extreme Wiring on the Prototyping Board
July 14, 1997
Update: December 16, 2014
http://elm-chan.org/docs/wire/wiring_e.html
I recently surprised myself and decided I really need a board with a ZIF socket.  And again when I figured out just how much extra room that would take :-(
I'm not sure that a barrel jack and regulator is so important any more, what with the ubiquity of 5V "USB" supplies.  I've got at least one design with two USB connectors - one for power only, and the other for actual USB Comm...
I put an 8-pin header socket {such as comes on the Arduino UNO} on the pins of the Arduino Nano as shown:
Now, an 8-pin header strip on the daughterboard has Vcc, gnd, reset, I2C, and a few I/O pins that plug directly into the microcontroller board.
I have also taken to use an Arduino UNO with a TFT parallel shield (like an ILI9341) in a manner that makes a little A-Frame stand.  The pins for the entire right side of the TFT (D0-D7_D8-D13) shield are soldered to the Via pads of the UNO on that side.  Then I carefully bend the two boards to be at a 90 degree angle, so that the unsoldered edges of the TFT and the UNO are flush on the table surface. This makes a 45-degree stand to the user and the UNO board is its back support.  All peripheral boards, batteries, and connectors go into the  empty "V" space in the middle between the TFT and UNO boards.  I do have to do rework with 8-inch [20cm] pieces of thin wire-wrap AWG30 to connect the A0-A5 pins between the TFT and UNO.  Be sure to buy AWG30 wire wrap in an package that has an assortment of colors so that you can use the same color scheme between boards.  I suggest  red:Vcc  black(grey):gnd  blue:SCL  green:SDA  purple:SCK  yellow:MISO  orange:MOSI  white:reset.
Photo?
It hurts to see this   http://elm-chan.org/docs/wire/rc/wcs.jpeg
Here: https://www.olimex.com/Products/Modules/UEXT/
Or there's the XPlained Pro standard.
Or any number of other "standards" - proposed by every other board maker.
we call it, "sleeving".
very important!
I've seen some video of the elm-can (like) soldering.
Soldered with a big shaky iron, and often other wires are touched while soldering a wire next to it, which leads to that wire disconnecting and a lot of extra work.
It is made more like an piece of art, then as something practical.
Brian, perhaps it is a good idea to put the needed capacitors for the 328/1284 next ot the pins of the processor.
And if they are at the same location a provision to put a HC49 crystal right next to the pins too.
Sorry, I should have said that the left hand processor area is unfinished. Lots of toys to go into that area.
The plan for the processor sections is...
co-sited 1284p/328P
all necessary decoupling
all necessary AVCC filtering
6-pin ISP connector
6-pin FTDI connector with reset capacitor
USB connector (size to be decided) for power
screw terminals for power
2 uncommitted LEDs, with resistors, wired to 40-way centre connector section
1 uncommitted switch, with pull-up, wired to 40-way centre connector section
LED on VCC rail
2 0V attachment points for 'scope probes
reset pushbutton
on-board regulator using recom part
polarity protection diode on screw terminal power input
xtal and capacitors connected to chip
I like to use a full wave bridge rectifier (W04 usually). I can then use "any old trannie"...
valusoft wrote:
"any old trannie"
I guess bit pushers move in different circles to hardware folks.
So do I, and I add plenty of filtering.
You could add 0.1uF caps near the mounting holes on the right for the voltage rails.
--Mike
Brian, could you provide the source of the protoboard shown in your initial post? It looks like something that might work for me.
hj
Sure, ... https://www.rkeducation.co.uk/rk...
You used to be able to buy just the bare boards although I can't find that option any more.
Soldering skillz =>>> God Mode !
and below is my embedded project on the preffboard, which surprisingly to me worked.
work in progress...
A small project update...I'm currently exploring the megaAVR 0-series and wondering if it's worth doing a protoboard for the older AVRs and if I should just make the switch to newer models.
Well, I can notice more and more questions in the forum for the AVR-0 and AVR-1, so clearly they are gaining popularity.
If readers are interested boards for the older 8 bit AVRs, I would recommend the prototype and development boards by Protostack at https://protostack.com.au/product-category/boards/ .
They are a bit more expensive but the development boards allow for a flexible variety of support components while the prototyping boards are close to the layout of the breadboard type for transferring a prototype to a one-off final design.   The boards are high quality FR4 material with through holes and silk screening.  Shipping to the US is (was in 2017) $7.00 flat fee and takes between 1 and 1 1/2  weeks.
I have used the prototyping boards to make development boards for micro controllers not supported by Protostack's current offerings.
Alan
Might I suggest some smt footprints. Some soic-8 to 16 (try both jedec and eia/iec widths), a few sot23 or 25 for fets, smt capacitors for reservoir caps and maybe decoupling in 0805, etc all routed to 0.1” holes for onward connecting.
As much as I hate the bgas and 0201s I work with daily it is the way of the modern electronics world so you might as well try being flexible...
There are already a million monkeys in front of a million keyboards, and the internet is nothing like Shakespeare!
Also consider power supply. Not everything is only 5v nowadays so maybe a 3v3 rail and some level shifters might be an idea to squeeze in.
