AT90USB162 won't show up in windows, can't get it to work
22 posts / 0 new
I'm trying to program an AT90USB162 with Atmel FLIP, however I can't get it to work.
Here's the schematic:
I'm new to MCUs and I don't know what to do. The only thing I was able to verify is that the MCU is getting 5v.
Any ideas what should I do?
Check the crystal datasheet to make sure those 10pF caps are the right value.
--Mike
This is what I found about the crystal I have, what capacitor should I use?
The 16MHz crystals I have require 22pF.  Your datasheet indicates between 16pF and 30pF.  If you have a scope, you can check whether the oscillator is actually toggling, and at what rate.
--Mike
03vmate wrote:
I'm new to MCUs
then USB is a bit advanced to be starting with!
I would suggest that you'd be better starting with either an Arduino, or an XPlained Pro / Mini / Nano with onboard debugger:
I've used arduinos before, I'm referring to "the hardware". I've never used anything else than a prebuilt dev board. Also, I really need USB for a project, so that's why I chose the AT90USB162
--Mike
I've swapped the 10pF caps for 20pF ones, still doesn't work.
The only other idea I have is you left RESET floating.  Check the datasheet for the way to hook it up properly.
--Mike
While many/most/all of us would indeed usually/always add circuitry to /RESET on AVR applications to ensure robust operation during a variety of real-world conditions, there is no reason why a "bench setup" otherwise benign would suffer the appearance of a dead AVR.  ~30k is indeed kind of a weak pullup -- but remember we all use such a weak internal pullup on our buttons/switches in production apps.
I've added a 1k pullup to the reset pin, didn't  work. Tried 0.3k and 10k with the same result
Also, tried with 2 other AT90USB162's, and the same thing is happening with those: nothing.
I would suggest an Arduino Pro-micro (M32U4, leonardo clone), looking at it's schematic, is not much different then your AT90, one diff is the M32U4 has a /HWB pin that is tied to gnd on the Leonardo.
Does the AT90 have a pin like that?
Edit: yes it does, suggesting it needs to be tied to gnd to enter bootloader (is one present?) upon power up.
I need the MCU to have USB host, so that's why I chose the AT90USB series. It does have a /HWB pin, I tried connecting it to ground or vcc but nothing happened.
1) Use an ohm meter to verify that the 22 ohm resistors are actually 22 ohms.
Here is the schematic for the Olimex board for the AT90USB162.
Note the bypass capacitors - 10uF and several 100nF caps.  These are necessary for proper operation.
Note the switch (BUT) connected to PD7.  PD7 should be grounded to enter bootloader mode.
Note that the above circuit uses an 8MHz crystal.
the pro-micro uses a 16MHz, but is using a different bootloader!
That is interesting  -- I'll wager a virtual cold one that that model does NOT have host capabilities.
Yeah, I *might* have overlooked something. Do you have any recommendation for a really low cost usb host capable MCU?
The AT90USB647 and AT90USB1287 support USB Host Mode.
The 647 is around $7 and the 1287 is around $9.
Edit: Corrected typo.
Thanks - I did not know about the internal reset pullup resistor.  My only experience with custom AVR hardware is using the Ultimate Arduino Prototype Board which has external reset parts.  This is how I knew the 10pF caps were suspect.  BTW, I personally am a bit weak when it comes to pull ups as well.
Arduino Ultimate Prototype Board v2
Well, thanks everyone for the help, I think I'll look into the SAMD series for price reasons.
Here are some Host adaptors so that you can use an "ordinary" MCU: http://www.hobbytronics.co.uk/usb-host
I thought you had to assert HWB at power on for DFU to enumerate? Are you doing this?
