ASsembly Question
8 posts / 0 new
Hi freaks, I have a simple asm routine that I am having trouble compiling.  It is as follows:
void context(void);
__attribute__((naked))void context(void){
	__asm__ __volatile__(	"MOV32   R0, OSTCBCur\n\t"
							"MOV32   R1, OSTCBHighRdy\n\t"
							"LDR     R2, [R1]\n\t"
							"STR     R2, [R0]\n\t"
							"LDR     SP, [R2]\n\t"
							"LDMFD   SP!, {R0}\n\t"
							"LDMFD   SP!, {R0-R12, LR, PC}");
The error message is thus:
C:\Users\wmjen\AppData\Local\Temp\cciolx1T.s:174: Error: bad instruction `mov32 R0,#OSTCBCur'
C:\Users\wmjen\AppData\Local\Temp\cciolx1T.s:175: Error: bad instruction `mov32 R1,OSTCBHighRdy'
Both are pointers.  Could someone suggest something to try?
Did you include the header where the OSTCB.....   are defined?
I take this in not an 8 bit AVR your talking about?
Sure.  Try telling us which processor brand/model is the target of this incantation.  And, of course, try telling us the full context including the definition of all the offending parameters.
Hi freaks, don't be shouting at me now but the target is the asma5d4 coolAnyways, its a comiler question and someone might know how to solve the error.  smiley
Google gives no pertinent  results for "asma5d4".  So your answer doesn't help much, does it?
Who is yelling?
But this section of the site is for AVR8 and similar models.  Those compilers won't generate a MOV32 instruction.
Still hasn't; even after the "helpful" response.
So I put "mov32 r0" into a Google search. Guess what information I got in the first two hits?  Sample:
You are using gnu assembler with arm assembler pseudo instructions.
This works!!!
__attribute__((naked))static void context (void){
			"MOV   R0, %[tcb_current]\n\t"
		    "MOV   R1, %[tcb_new]\n\t"
		    "LDR     R2, [R1]\n\t"
		    "STR     R2, [R0]\n\t"
		    "LDR     SP, [R2]\n\t"
		    "MSR     SPSR_cxsf, R0\n\t"
		    "LDMFD   SP!, {R0-R12, LR, PC}" :: [tcb_current] "r" (&OSTCBCur), [tcb_new] "r" (&OSTCBHighRdy));
