MAX7219 Simple interfacing problem
8 posts / 0 new
Hello guys i'm trying to interface an ATMEGA32A  with a max7219 chip to drive 8 segment display,im using AS7 gcc ,my approach was to use any 3 port pins , one to shift data out from , one to use as a clock , and the last one for load pin required to latch data to the max7219 , however my code failed and i've been debugging for hours all i'm getting is blank 7 segment digits ,i've checked that my chip is working by connecting it to an arduino and used SPI library to display some digits and it seems to be working fine,when i tried adding delays with some leds and try to see what is happening i notice that my load pin never actually goes high, the clock pin never stop toggling even if it has already shifted out the 8 bits or so.
what i expect to happen : DIN pin starts shifting out data synchronized with the clk pin , after it is done sending ,clk should stop toggling and load pin goes high to latch the data but that never happens.
i've my code in 3 files , MAX7219.C , MAX7219.h and main.c
Main.c:
#define F_CPU 8000000UL
#include <avr/interrupt.h>
#include <util/delay.h>
#include <MAX7219.h>
int main(){
	MAX7219_init();
	MAX7219_send(TEST_REGISTER,YES_TEST);
	_delay_ms(2000);
	while(1){}
MAX7219.C file:
 * MAX7219 Driver.c
 * Created: 8/2/2018 4:44:06 AM
 * Author : ~~~~~~~~~~~~~GARMOOOSHHHHHHHHHHH~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
#define DIN 0
#define CLK 1
#define LOAD 2
#define MAX_PORT PORTA
#define MAX_DDR DDRA
/*set the pins as output */
void MAX7219_init(void){
	MAX_DDR=(1<<LOAD)|(1<<CLK)|(1<<DIN);                                //LOAD,CLK,DIN pins are outputs
	MAX_PORT&=~((1<<LOAD)|(1<<CLK)|(1<<DIN));
/*transmits an 8 bit word by shifting through DIN  pin   , MSB  FIRST */
 void shift8bit(unsigned char data){
	uint8_t i;
	for(i=7;i>=0;i--){
		if(data&(1<<i)){
			_delay_ms(1000);
			MAX_PORT|=(1<<DIN);
			_delay_ms(1000);                                //if THE BIT IS HIGH
			MAX_PORT|=(1<<CLK);
			_delay_ms(1000);
			MAX_PORT&=~(1<<CLK);
			_delay_ms(1000);
		else{
			_delay_ms(1000);
			MAX_PORT&=~(1<<DIN);
			_delay_ms(1000);                               // ELSE THE BIT IS LOW
			MAX_PORT|=(1<<CLK);
			_delay_ms(1000);
			_delay_ms(1000);
/*SENDS OUT A 16 BIT WORD , 8 BIT FOR ADDRESS , 8 BIT FOR DATA */
void MAX7219_send(unsigned char addr,unsigned char data){
shift8bit(addr);                                  //send out addr
shift8bit(data);                                 //send out data
_delay_ms(1000);
MAX_PORT|=(1<<LOAD);                             //rising edge on load pin
_delay_ms(1000);
MAX_PORT&=~(1<<LOAD);
_delay_ms(1000);                              //back to low
header file:
 * MAX7219.h
 * Created: 8/2/2018 4:44:48 AM
 *  Author: ~~~~~~~~~~~~~GARMOOOSHHHHHHHHHHH~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
#ifndef MAX7219_H_
#define MAX7219_H_
*MAX 7219 REGISTER ADDRESSES
*HIGH NIBBLE IS DONT CARE
*REGISTER MAP OF MAX7219
#define NOP_REGISTER 0X00
#define DIG0_REGISTER 0X01
#define DIG1_REGISTER 0X02
#define DIG2_REGISTER 0X03
#define DIG3_REGISTER 0X04
#define DIG4_REGISTER 0X05
#define DIG5_REGISTER 0X06
#define DIG6_REGISTER 0X07
#define DIG7_REGISTER 0X08
#define DECODE_REGISTER 0X09
#define INTENSITY_REGISTER 0X0A
#define SCAN_REGISTER 0X0B
#define SHUTDOWN_REGISTER 0X0C
#define TEST_REGISTER 0X0F
/* OP CODES FOR DIFFERENT REGISTERS
*SHUT DOWN , NORMAL OPERATION ,INTENSITY CONTROL ETC
#define DATA_MASK 0XF0
#define SHIFT_MASK 0X80
#define SHUTDOWN_MODE  0X00
#define NORMAL_MODE    0X01
#define YES_DECODEB    0XFF
#define NO_DECODEB 0X00
#define INTENSITY_LV0 0X00
#define INTENSITY_LV1 0X01
#define INTENSITY_LV2 0X02
#define INTENSITY_LV3 0X03
#define INTENSITY_LV4 0X04
#define INTENSITY_LV5 0X05
#define INTENSITY_LV6 0X06
#define INTENSITY_LV7 0X07
#define INTENSITY_LV8 0X08
#define INTENSITY_LV9 0X09
#define INTENSITY_LV10 0X0A
#define INTENSITY_LV11 0X0B
#define INTENSITY_LV12 0X0C
#define INTENSITY_LV13 0X0D
#define INTENSITY_LV14 0X0E
#define INTENSITY_LV15 0X0F
#define SCAN_1DIG 0X00
#define SCAN_2DIG 0X01
#define SCAN_3DIG 0X02
#define SCAN_4DIG 0X03
#define SCAN_5DIG 0X04
#define SCAN_6DIG 0X05
#define SCAN_7DIG 0X06
#define SCAN_8DIG 0X07
#define NO_TEST 0X00
#define YES_TEST 0X01
/*functions */
void MAX7219_init(void);
void MAX7219_send(unsigned char addr,unsigned char data);
void shift8bit(unsigned char data);
#endif /* MAX7219_H_ */
header file just contains register addresses and op codes copied from the datasheet.
i even used ready made code from other sites and used code given by kartman on other posts concerning max7219 but still my segments remain turned off, but works when i connect with my arduino.
any help is appreciated .
	uint8_t i;
	for(i=7;i>=0;i--){
What do you think this does?
i think it loops from 7 to 0 so i can use ' i ' to test every bit of the argument data
come to think of it i have no idea what it will do in the last iteration with the uint8_t should i change it to char ? or am i completely wrong here?
for a uint8_t, 0-1 = 255.  That's why your loop never ends, the tested condition never fails because an unsigned variable can never go below zero.
How to fix this depends on a few other matters, but yes, any signed variable type would solve the problem.
However, your (1<<i) is very inefficient on an AVR.  Better, IMO, to set a mask (mask = 0x80 if you're shifting out MSB first), test for each bit via (data & mask), and then shift mask right after each bit.  Then, as a side benefit, you don't even need to have a count variable, because when the mask is 1 and you shift right, it becomes 0, so you can just test for mask != 0 in your loop.
Another thing, please put some white space in your code.  The readability will improve immensely.
One final thing I noticed is that you have redundant code.  You repeat the clock output code in two places (1 data bit and 0 data bit), when it should only be in one place.
So something like this?
	unsigned char mask=0x80;
	for(;mask;mask>>=1){
		if(data&(mask)){
			MAX_PORT|=(1<<DIN);
		else{
			MAX_PORT&=~(1<<DIN);}
				_delay_ms(1000);
				MAX_PORT|=(1<<CLK);
				_delay_ms(1000);
				_delay_ms(1000);
thanks for the help this worked , although when i changed the uint8_t to a char , it didn't work i have no idea why shouldn't changing to char would've also solved the problem?
Formatting is off, and still no whitespace, but that looks right.
In AVR GCC, char is equivalent to unsigned char.  You want signed char.  Or better yet, int8_t.
