Hello to all!
I am coming back to the forum, because I would like to add the WDT to the code in oneofmy previous posrs due to the quetiins of stability issues! See the post#54
I am not sure how to exactly use the WDT. For example, I would like the WDT to fire every min or so, not 8sec, which is factory max. But more importantly, I am not sure how to avoid most of the stuff in the setup after the WDT reset. For example, I would only need to use one method from there instead of the whole setup function...
Anybody? Is there a way to actually do this? And, most importantly how to even consider the WDT in this example, because, if the led is turned ON it should not be turned OFF due to the WDT, btw is this even possible?
Best.
PS I am now writing like you, WDT means watch dog timer, which you all probably know :P
