Come Join Us (MPLAB Now Supports AVRs)
277 posts / 0 new
Pages
One other development, Microchip’s newly released, low-cost PICkit™ 4 In-Circuit programming and debugging development tool also currently provides Beta support for AVRs.
PICkit 4 is on-sale :
Microchip Direct Logo
microchipDIRECT
DEVELOPMENT TOOL DEALS
https://www.microchipdirect.com/product/DevToolDeals
Part Number: PG164140 - MPLAB PICkit 4 In-Circuit Debugger
[47.95USD then 20% off]
[in stock, 308]
Edit : zero stock as of 13-Aug'18; IIRC, the sales price is honored when restocked.
Edit1 : restocked at 1366 as of 17-Aug'18
low-cost PICkit™ 4
It is ... interesting that Microchip has embraced the SAM chips for use in their debuggers.  The nEDBG chip on the recent PIC16F18446 giveaway board is a SAMD21, and this PicKit4 has a SAME70...
Any word on whether PICKit 4 will support ARM chips?  (It should be able to - has SWD and JTAG.  I guess the more correct question is whether Atmel Studio will support PICKit4...)
PS: Thanks!  Ordered.  20% discount + free shipping via FLASHSHIP - $38+tax was irresistible.
More worrisome is the "AVR Support in XC8", given XC8's rather sketchy reputation in "free" mode.   And no C++.
>>  http://microchipdeveloper.com/mp...
Hmm.  There are some problems with that page, I think.   I especially like:
Concept MPLAB Atmel Studio
Set/Clear Bit Values
Clear bit: Bit value = 0
Set bit: Bit value = 1
Clear bit: Bit value = 1
They're presumably talking about fuse/config bits.  But I don't think that's obvious, especially if you're new to AVRs.
I presume that that is the same logic as using ATmega32U4 for mEDBG on XMINI boards.    It works but the "performance" is poor.
The "paid-for" debuggers will have a proper performance e.g. ATMEL-ICE or PicKit4.
It seems to be a crazy marketing decision.    It costs a few cents more to use SAME70 instead of SAMD21.    Likewise UC32 vs AVR.   Prospective customers explore the evaluation/giveaway boards and conclude that the target chips are "worse" than NXP, ST, TI, ...
The only argument for ATmega32U4 is 5V tolerance.    But PicKit hardware have always coped with 5V.
An oft repeated claim but one that no-one has ever produced any real-world evidence for, or not that I've ever found. I've seen figures of 10% slower code/more RAM/more Flash but, IMHO, if 10% is the difference between your project working and your project breaking then you have bigger problems.
SAM S70 and E70 in MPLAB X 5 (first in MPLAB X 4.20) from 'Device Support.htm'.
 Oh, there was plenty of evidence when XC8 first came out; much discussion on the PICList mailing list.
Things were improved quite a bit since then, and the hard part is figuring out whether a given bit of source code is going to fall into the "adequately optimized" column, or the "you've got to be kidding" column.
Most recently (last week or so) there was a blog post ( https://www.bitsnblobs.com/blog/... ) where it was reported that the PIC16F18446 board (mentioned previously) ran a "native" pin-toggle benchmark at about the same speed as an Arduino digitalWrite() loop (at the same clockspeed.)  Now, at the same clockspeed, a PIC is about 4x slower than an AVR.  But digitalWrite() in Arduino is 10 to 20x slower than "native" code, so the PIC *should* have come out ahead by quite a bit.
I investigated.   I had a PIC16F18855 board, and it's "hello world" LED blink code ran significantly faster.   Initially, I expected errors in clock configuration.
But it turns out that the current Microchip Code Configurator tool generates nice macros for pin toggle:
#define IO_RA2_Toggle() do { LATAbits.LATA2 = ~LATAbits.LATA2; } while(0);
While the (older?) example I had for the 18855 had:
#define IO_RA0_Toggle()   do { LATA0 = ~LATA0; } while(0)
Those should be about equivalent, right?  All compile-time constant folding, essentially?
Nope.   The later (older) example produces "reasonable" code:
0x26: MOVLW 0x4
0x27: MOVLB 0x0
0x28: XORWF LATA, F
0x29: GOTO 0x26
It could short-circuit that loop a bit more (GOTO 28 instead of GOTO 26), but ... good enough.
The newer-style code, however, produced:
!      do { LATAbits.LATA2 = ~LATAbits.LATA2; } while(0);
0x26: BCF STATUS, 0x0
0x27: MOVLB 0x0
0x28: BTFSS LATA, 0x2
0x29: BSF STATUS, 0x0
0x2A: BTFSC STATUS, 0x0
0x2B: GOTO 0x2D
0x2C: GOTO 0x30
0x2D: MOVLB 0x0
0x2E: BSF LATA, 0x2
0x2F: GOTO 0x32
0x30: MOVLB 0x0
0x31: BCF LATA, 0x2
0x32: GOTO 0x26
Someone else confirmed that the "Pro" compiler with optimization settings (unusable to free users) does optimize the new-style source to the same as the old-style source.
XC16 and XC32 are gcc-based, but don't allow the usual gcc optimization flags.  The net is rife with instructions on how to patch the binaries, and/or environment, and/or compile from source, since all those options are supposedly legal according to the gcc licenses...  (however, gcc with -O0 is not nearly as bad as the original XC8.   We were expecting code like -O0, and we got ... the sort of code you'd expect out of someone's 2nd year compiler project, in which the main point was to learn about parsing...)
[SAMD21 or ATmega32u4 instead of SAME70] works but the "performance" is poor.
The sad part is that I really don't see any reason that a SAMD21, or even a 32u4, should have "poor" performance for this sort of application.
If the Xplained Mini boards weren't so cheap, *I'd* be working on a faster version.   Maybe.  At least to the extent of figuring out whether CMSIS/DAP introduces unavoidable overhead.
SAMD21 is Cortex-M0 @ 48MHz.    Considerably poorer performance than M3 or M4 @ 48MHz.   And obviously noticeably slower than M4, M7 @ 200MHz or faster.
Mega32U4 @ 16MHz is severely limited for Flash as well as speed.     I suspect that the worst bottlenecks could be "improved" but you are still stuck for speed.    DebugWIRE is inherently slower than SWD or UPDI but it should not be that SLOW.
Hey-ho.   The XMINI-328P does work.   So it is better than nothing.
Yes, but doing something simple like programming the flash ought to be limited by either the uplink speed to the PC (full speed USB for both of those chips, right?) or the downlink speed to the chip (which shouldn't change between debug technology.)  And yes, "32k" is "Severely limited flash" in some sense. but I'd think it would be plenty for any single target (granted, if you have an mEDBG chip, and it's supposed to support everything, then that's a valid excuse for code space issues...
To whom it may concern... finally, someone was able to direct me to the PICKIT4->AVR pin mapping, and I can confirm programming an ATmega4809 (UPDI interface) with the PICKIT4 from MPLAB X IDE 5.00.
Here's the link: http://microchipdeveloper.com/pi...
There is no requirement to use the XC8 compiler for AVRs in MPLABX.  The AVR toolchain has worked for me on both Windows or Linux.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
I was hoping they would add PIC support to AtmelICE. The Microchip programmers are awful, especially the ICD range.
I just hope the free toolchain is maintained.
YouTube
Getting Started - AVR® in MPLAB® X - Ep. 1 - Import Studio 7 Project into MPLAB X IDE
Microchip Technology
Aug 7, 2018
https://www.youtube.com/watch?v=uMOKiY3bdjM (3m44s)
Example import:
• ASF3 Example Project
Import process:
• Locate Studio *.cproj File
• Select Device
• Select Tool
• Select Compiler
• Name project & folder
How import works:
• Source files linked (not copied)
[2 URL]
via https://plus.google.com/+MicrochipTech/posts/ZBBSkLo3sU5
Edit: browse YouTube Microchip Technology for two more videos in that series
I agree better is always good, but 'a few cents more' is not quite accurate :
ATSAMD21E15L 32QFN  $0.735/3k
cheapest SAME70
ATSAME70J19A-AN   64LQFP  $7.19970/3k
There is a ATSAM3U1CB-AU, with 480MHz HS-USB, for $2.44/1k, but they seem to have skipped over that ?  Maybe it has some issues ?  Or was the 512k / 300MHz of the SAME70 seen as more future proof ?
A key increment here seems to be the jump from FS-USB to HS-USB, ( as well as a core MCU MHz jump that would allow even an intern code useful speed.)
What price they can sell a chip on the open market is not relevant to the manufacturer.
They only have to consider the die size and wafer yield.     There is no need to go for the ultimate performance but their brand name tools deserve to work well and with some future proofing.
It is less clear with a "giveaway" evaluation board.    Do you go for cheap or "adequate"?
Personally,   I think that the mEDBG was a false economy.     Just compare the Microchip/Atmel evaluation boards with ST, TI, SiLabs, ...
gchapman wrote:
YouTube
Aug 7, 2018
Example import:
Import process:
• Select Device
• Select Tool
• Select Compiler
How import works:
[2 URL]
Thanks, that was interesting. It seems to work well enough for a simple ASF project. I'm going to try it.
I think Atmel Studio is dead now. MPLAB is inferior but we will have to get used to it, because AS7 will be the last version.
You will still be able to keep using it; it just won't get updated.
After all, people are still using WinAVR, and ancient versions of AVR Studio - long after they were "discontinued" ... !
As long as they keep updating for new parts I suppose. But yes, I won't bother upgrading projects for the most part, just start from scratch. I tend not to upgrade production code unless there is a very good reason.
Well, that's the point: they probably won't - so it'll be frozen in time; it'll just carry on doing what it does now.
And there's also talk that Microchip won't be updating avr-gcc ...
EDIT
Here: #108
That would be a real blow to the maker and open source communities. Arduino, for example, picked AVR in no small part because there is a free high quality compiler for it.
Maybe it's time to think about ditching Microchip/Atmel architectures and moving to ARM. At least then you are not tied to one manufacturer's mast and gcc will always be free and up to date.
Maybe Arduino has gained a sufficient "critical mass" to be able to keep avr-gcc going independently ... ?
Or maybe they will adopt the same strategy: freeze all the AVR stuff as it is now, and everything new happens on ARM ... ?
After all, there's now quite a few non-AVR Arduinos  - particularly ARM  ...
EDIT
On the discontinuation of avr-gcc: #108
Sad news. Looks like they decided to steal our free software, gimp it and make building the legally required release of the optimized version extremely difficult and time consuming.
Just think of the effort they had to put in to destroying the free version's performance, and how it could have been better spent on something productive.
Whatever good will Atmel had is quickly being destroyed. Microchip can shove their compiler, and forget about me designing their parts into new products. What made Atmel so great was the community, and respecting the GPL and having a decent free compiler are core requirements. I'm not going to contribute my time and energy if they take but give nothing back.
Likely yes and Microchip has a link to Arduino through Bob Martin.
This post was updated today :
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=2#comment-2504476
A while back, one of the Arduino creators asked the Arduino community to merge the Atmel AVR GCC patches into the Arduino AVR toolchain (it was done)
Assuming the ones at Microchip release what they can of xc8-gcc then it'll get done again.
One advantage of AVR in Microchip's 8-bit line-of-business is C++.
http://www.microchip.com/development-tools/maker-diy-solutions
A door has opened to third parties.
Microsoft Visual Studio AVR extensions though not zero price (low price) and incomplete AVR model coverage :
  • PlatformIO
  • VisualGDB
Zero price is the current EDBG in Microsoft Visual Studio Code though some effort to add AVR to it and it's more akin to AVR Studio than Atmel Studio :
https://www.avrfreaks.net/forum/avr-studio-mac-linux#comment-2440271
Long poles in the tent :
  • lifetime of EDBG
  • third party support of MPLAB PICkit 4 and MPLAB ICD 4
http://docs.platformio.org/en/latest/ide/visualstudio.html
PlatformIO value-added (iow not zero price) for arm, ESP32, RISC-V, and Texas Instruments MSP430 :
http://docs.platformio.org/en/latest/plus/debugging.html
PlatformIO AVR EDBG :
PIO Unified Debugger for AVR · Issue #95 · platformio/platform-atmelavr · GitHub
https://github.com/platformio/platform-atmelavr/issues/95
can Ivan be convinced to add EDBG?
reason: VisualGDB is a GDB client
https://visualgdb.com/tutorials/avr/
Does anyone have a link to the Microchip compiler source archives? I'm tempted to set up a build environment and release free versions periodically.
Microchip Technology Inc
PIC and dsPIC Downloads Archive
http://www.microchip.com/development-tools/pic-and-dspic-downloads-archive
(near bottom)
Source Archives
FSF AVR GCC on Windows :
AVR-GCC 8.1.0 for Windows 32 and 64 bit
By
http://blog.zakkemble.co.uk/avr-gcc-builds/
due to https://gcc.gnu.org/
Edit : one AVR regression fixed in 8.2 : https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85805
Total votes: 2
I think I speak for quite a few part-timers and people who just screw around with this stuff in our spare time: We don't like to feel like we are missing out on the tools. Paying for MPLAB isn't really in the cards for someone like me, and if I'm using the free version and constantly feel like I'm missing out, it isn't going to make me happy. It is going to make me look for a different toolchain, possibly one for different chips with a company who is more interested in selling chips instead of tools.
So what you say, you guys only buy a few chips! Ah, well, yes. But we improve the ecosystem, build libraries and give them away, test and popularize things and ultimately make things easier for everyone. That million item product down the road may well use a particular chip because of some home gamer like me. And, often, might even be made by a home gamer like me.
Microchip needs to drag themselves out of the dark ages of nickel and dimeing their engineers/devs and decide if they want to sell chips or tools. They could also help their case by teaming up more; I'd be happy if they provided a tool chain for something like CLion (with hardware debugging) or others.
(near bottom)
Source Archives
Thanks, but I searched the whole page for "XC8" but the only mention of it is the binary installer. Maybe I'll email them.
Mr.Paul wrote:
Paying for MPLAB ...
/pedantic on
MPLAB XC
/pedantic off
wink
Having a zero price IDE (MPLAB X) is ecosystem essential with today's competitors.
Mr.Paul wrote:
They could also help their case by teaming up more; ...
Atmel did not compete against third parties.
Microchip does compete against third parties (HP InfoTech, Imagecraft, IAR)
xc8-gcc vs (CodeVisionAVR, JumpStart C for AVR, EWAVR)
I emphatically second your motion!!!!
An example of such is Texas Instruments packages and maintains FSF MSP430 GCC and has a multi-platform debugger interface package in MSPDS.
Advantage AVR is some megaAVR and XMEGA AVR have an EBI (MSP430 doesn't have an EBI)
Another AVR advantage is an extended temperature range though TI has recently added several 105C to the MSP430 line and has several at 125C or greater.
http://hpinfotech.ro/
http://imagecraft.com/
https://www.iar.com/iar-embedded-workbench/#!?architecture=AVR
http://www.ti.com/tool/msp430-gcc-opensource
http://www.ti.com/tool/MSPDS
Mr.Paul wrote:
...and if I'm using the free version and constantly feel like I'm missing out, it isn't going to make me happy.
But does lacking a few percent of optimisation really matter?
You buy a mega328 and you don't spend your time anguishing over why Atmel didn't make it with 64k of flash do you?
You buy a new car and you don't waste time wishing it did 130MPH instead of 120MPH do you?
To be fair, XC8 is not based on "free software" of any sort.  XC16 and XC32 are built on gcc, and instructions for building those (or otherwise removing the optimization restrictions) are widely available.
The Microchip compilers do not include C++ for the 8bit CPUs, which is a pretty substantial problem, given both Arduino, and a large contingent of "it's time for the embedded world to consider using C++" prophets and evangelists.
That is entirely missing the point. It will all be "ok, you want to do X, that is only available in the pro version" and "Oh, your loop is sloppy, that is only available in the pro version", etc. What I want to focus on is programming the chip. I don't want to drop hundreds or thousands on an IDE, and all the oh you need the update but your maintenance is not up to date. I want the best the company has to offer, so that I don't have to think about "Should I upgrade my IDE" instead can think "How can I keep this wake up and poll sequence under 4ms", which is a vastly more fun problem to solve.
And, for the record, if Atmel had 64k flash in a chip and decided I need to pay an extra free to unlock it, I would not buy that chip. They are, of course, within their rights to that business model, but for personal use I'm not interested in participating. Same for my car; If I bought it and Honda went and said "Oh, you know, that car will do 130 mph, just subscribe to the fast car program" I not only wouldn't pay, I would be pretty unhappy, even if I didn't plan to do 130 mph.
Work is work, commerce is commerce, but when I do things for fun I like it to be friendlier, easier and with less friction (which a paid IDE definitely introduces). It isn't rational from a economics point of view, but fun is fun and profit is profit. Atmel walked that line very wel, microchip is not -- so far -- looking like they are walking well.
Hehe, but you probably already are doing exactly that.
All those MCU parts with differing code-sizes, but same peripherals & pinouts are usually not differing die - they are the same die, with varying factory options.
Code size is the most easily 'factory set'.
Well yah but I don’t want it in my face. Also the smaller sizes QA better
As in if you manufacture 64k but only sell 32 and have a fusable page map or something you can get better yield.
fyi, MPLAB XC8 Pro in dongle form is a perpetual license and it was on sale last month.
MPLAB XC8 Pro's price would be steep for the small in SMB but likely not a large issue for the medium in SMB; for a large business it's a tool at a reasonable price so maybe it's a good value if its quality is good.
Mr.Paul wrote:
Atmel walked that line very wel, ...
Concur
Mr.Paul wrote:
... microchip is not -- so far -- looking like they are walking well.
Compilers as profit centers.
Continual pressure on profit centers is likely the Microchip way; investors and shareholders like that.
Transparency - I do not possess any Microchip stock.
Reason - twice bitten, thrice shy (dotcom bust, Oct'08)
Lesson learned - support Main Street, not Wall Street
Matters not ... why?
WinAVR is dead ... long live WinAVR
wink
AVR's ecosystem is well past critical mass (an amazing number of computer languages and compilers or interpreters)
My concern is with debuggers.
Is EDBG a part of MPLAB PICkit 4?
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=2#comment-2504076
No.  But the example I quoted recently ( https://www.avrfreaks.net/commen... ) was more than 3x bigger (13 words instead of 4), and much slower (3.4us vs 1.3us) than the "obvious" object code.  Various other folks have mentioned that "example projects" fail to fit in the target chip when compiled with the free version of the compiler.  Those are problems worth complaining about.  When I look at the object code produced by the compiler, I should be able to say "Well, I could have done it faster if I tried", but not "This is stupid!"
In a way, I have similar objections to ASF.  1k of initialization code for the system clock is sort-of OK on a SAMD21 with 256k of flash, but it's not really acceptable for the SAMD09 with 8k...
One of the best things about Atmel parts is the community support. If you go over the Microchip forums you will see a night and day difference. No real community, people don't volunteer their time like they do here. Microchip has to pay staff to answer questions.
If Microchip destroy that just because they insist on charging for the compiler then people will move on to something else.
Err, speak for yourself! (top speed may not matter per se but it's a likely indication of aerodynamics and engine power which DO matter!)
Ah, but you bought that car knowing that the brochure said 120.
I would never buy a car if the brochure only said 120 !!
Seriously though, the difference between optimisation and none can be a whole lot more than +5..10%. Here's an example using a very simple code from another thread...
D:\atmel_avr\avr8-gnu-toolchain-win32_x86\bin>type avr.c
#define F_CPU 1000000UL
#include <util/delay.h>
int main(void) {
    DDRB = 0xFF;
    DDRC = 0xFF;
    DDRD = 0xFF;
    while(1) {
        PORTB ^= 0xFF;
        PORTC ^= 0xFF;
        PORTD ^= 0xFF;
        _delay_ms(100);
D:\atmel_avr\avr8-gnu-toolchain-win32_x86\bin>avr-gcc -mmcu=atmega328p -O0 -g avr.c -o avr.elf
In file included from avr.c:3:0:
d:\atmel_avr\avr8-gnu-toolchain-win32_x86\avr\include\util\delay.h:112:3: warning: #warning "Compiler optimizations disabled; functions from <util/del
ay.h> won't work as designed" [-Wcpp]
 # warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
D:\atmel_avr\avr8-gnu-toolchain-win32_x86\bin>avr-objdump -S avr.elf
avr.elf:     file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
   0:   0c 94 34 00     jmp     0x68    ; 0x68 <__ctors_end>
   4:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
   8:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
   c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  10:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  14:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  18:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  1c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  20:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  24:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  28:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  2c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  30:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  34:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  38:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  3c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  40:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  44:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  48:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  4c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  50:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  54:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  58:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  5c:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  60:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
  64:   0c 94 3e 00     jmp     0x7c    ; 0x7c <__bad_interrupt>
00000068 <__ctors_end>:
  68:   11 24           eor     r1, r1
  6a:   1f be           out     0x3f, r1        ; 63
  6c:   cf ef           ldi     r28, 0xFF       ; 255
  6e:   d8 e0           ldi     r29, 0x08       ; 8
  70:   de bf           out     0x3e, r29       ; 62
  72:   cd bf           out     0x3d, r28       ; 61
  74:   0e 94 40 00     call    0x80    ; 0x80 <main>
  78:   0c 94 02 02     jmp     0x404   ; 0x404 <_exit>
0000007c <__bad_interrupt>:
  7c:   0c 94 00 00     jmp     0       ; 0x0 <__vectors>
00000080 <main>:
int main(void) {
  80:   cf 93           push    r28
  82:   df 93           push    r29
  84:   cd b7           in      r28, 0x3d       ; 61
  86:   de b7           in      r29, 0x3e       ; 62
  88:   2e 97           sbiw    r28, 0x0e       ; 14
  8a:   0f b6           in      r0, 0x3f        ; 63
  8c:   f8 94           cli
  8e:   de bf           out     0x3e, r29       ; 62
  90:   0f be           out     0x3f, r0        ; 63
  92:   cd bf           out     0x3d, r28       ; 61
    DDRB = 0xFF;
  94:   84 e2           ldi     r24, 0x24       ; 36
  96:   90 e0           ldi     r25, 0x00       ; 0
  98:   2f ef           ldi     r18, 0xFF       ; 255
  9a:   fc 01           movw    r30, r24
  9c:   20 83           st      Z, r18
    DDRC = 0xFF;
  9e:   87 e2           ldi     r24, 0x27       ; 39
  a0:   90 e0           ldi     r25, 0x00       ; 0
  a2:   2f ef           ldi     r18, 0xFF       ; 255
  a4:   fc 01           movw    r30, r24
  a6:   20 83           st      Z, r18
    DDRD = 0xFF;
  a8:   8a e2           ldi     r24, 0x2A       ; 42
  aa:   90 e0           ldi     r25, 0x00       ; 0
  ac:   2f ef           ldi     r18, 0xFF       ; 255
  ae:   fc 01           movw    r30, r24
  b0:   20 83           st      Z, r18
    while(1) {
        PORTB ^= 0xFF;
  b2:   85 e2           ldi     r24, 0x25       ; 37
  b4:   90 e0           ldi     r25, 0x00       ; 0
  b6:   25 e2           ldi     r18, 0x25       ; 37
  b8:   30 e0           ldi     r19, 0x00       ; 0
  ba:   f9 01           movw    r30, r18
  bc:   20 81           ld      r18, Z
  be:   20 95           com     r18
  c0:   fc 01           movw    r30, r24
  c2:   20 83           st      Z, r18
        PORTC ^= 0xFF;
  c4:   88 e2           ldi     r24, 0x28       ; 40
  c6:   90 e0           ldi     r25, 0x00       ; 0
  c8:   28 e2           ldi     r18, 0x28       ; 40
  ca:   30 e0           ldi     r19, 0x00       ; 0
  cc:   f9 01           movw    r30, r18
  ce:   20 81           ld      r18, Z
  d0:   20 95           com     r18
  d2:   fc 01           movw    r30, r24
  d4:   20 83           st      Z, r18
        PORTD ^= 0xFF;
  d6:   8b e2           ldi     r24, 0x2B       ; 43
  d8:   90 e0           ldi     r25, 0x00       ; 0
  da:   2b e2           ldi     r18, 0x2B       ; 43
  dc:   30 e0           ldi     r19, 0x00       ; 0
  de:   f9 01           movw    r30, r18
  e0:   20 81           ld      r18, Z
  e2:   20 95           com     r18
  e4:   fc 01           movw    r30, r24
  e6:   20 83           st      Z, r18
  e8:   80 e0           ldi     r24, 0x00       ; 0
  ea:   90 e0           ldi     r25, 0x00       ; 0
  ec:   a8 ec           ldi     r26, 0xC8       ; 200
  ee:   b2 e4           ldi     r27, 0x42       ; 66
  f0:   89 83           std     Y+1, r24        ; 0x01
  f2:   9a 83           std     Y+2, r25        ; 0x02
  f4:   ab 83           std     Y+3, r26        ; 0x03
  f6:   bc 83           std     Y+4, r27        ; 0x04
        __builtin_avr_delay_cycles(__ticks_dc);
#else
        uint16_t __ticks;
        __tmp = ((F_CPU) / 4e3) * __ms;
  f8:   20 e0           ldi     r18, 0x00       ; 0
  fa:   30 e0           ldi     r19, 0x00       ; 0
  fc:   4a e7           ldi     r20, 0x7A       ; 122
  fe:   53 e4           ldi     r21, 0x43       ; 67
 100:   69 81           ldd     r22, Y+1        ; 0x01
 102:   7a 81           ldd     r23, Y+2        ; 0x02
 104:   8b 81           ldd     r24, Y+3        ; 0x03
 106:   9c 81           ldd     r25, Y+4        ; 0x04
 108:   0e 94 6d 01     call    0x2da   ; 0x2da <__mulsf3>
 10c:   dc 01           movw    r26, r24
 10e:   cb 01           movw    r24, r22
 110:   8d 83           std     Y+5, r24        ; 0x05
 112:   9e 83           std     Y+6, r25        ; 0x06
 114:   af 83           std     Y+7, r26        ; 0x07
 116:   b8 87           std     Y+8, r27        ; 0x08
        if (__tmp < 1.0)
 118:   20 e0           ldi     r18, 0x00       ; 0
 11a:   30 e0           ldi     r19, 0x00       ; 0
 11c:   40 e8           ldi     r20, 0x80       ; 128
 11e:   5f e3           ldi     r21, 0x3F       ; 63
 120:   6d 81           ldd     r22, Y+5        ; 0x05
 122:   7e 81           ldd     r23, Y+6        ; 0x06
 124:   8f 81           ldd     r24, Y+7        ; 0x07
 126:   98 85           ldd     r25, Y+8        ; 0x08
 128:   0e 94 e7 00     call    0x1ce   ; 0x1ce <__cmpsf2>
 12c:   88 23           and     r24, r24
 12e:   2c f4           brge    .+10            ; 0x13a <main+0xba>
                __ticks = 1;
 130:   81 e0           ldi     r24, 0x01       ; 1
 132:   90 e0           ldi     r25, 0x00       ; 0
 134:   9a 87           std     Y+10, r25       ; 0x0a
 136:   89 87           std     Y+9, r24        ; 0x09
 138:   3f c0           rjmp    .+126           ; 0x1b8 <main+0x138>
        else if (__tmp > 65535)
 13a:   20 e0           ldi     r18, 0x00       ; 0
 13c:   3f ef           ldi     r19, 0xFF       ; 255
 13e:   4f e7           ldi     r20, 0x7F       ; 127
 140:   57 e4           ldi     r21, 0x47       ; 71
 142:   6d 81           ldd     r22, Y+5        ; 0x05
 144:   7e 81           ldd     r23, Y+6        ; 0x06
 146:   8f 81           ldd     r24, Y+7        ; 0x07
 148:   98 85           ldd     r25, Y+8        ; 0x08
 14a:   0e 94 68 01     call    0x2d0   ; 0x2d0 <__gesf2>
 14e:   18 16           cp      r1, r24
 150:   4c f5           brge    .+82            ; 0x1a4 <main+0x124>
                //      __ticks = requested delay in 1/10 ms
                __ticks = (uint16_t) (__ms * 10.0);
 152:   20 e0           ldi     r18, 0x00       ; 0
 154:   30 e0           ldi     r19, 0x00       ; 0
 156:   40 e2           ldi     r20, 0x20       ; 32
 158:   51 e4           ldi     r21, 0x41       ; 65
 15a:   69 81           ldd     r22, Y+1        ; 0x01
 15c:   7a 81           ldd     r23, Y+2        ; 0x02
 15e:   8b 81           ldd     r24, Y+3        ; 0x03
 160:   9c 81           ldd     r25, Y+4        ; 0x04
 162:   0e 94 6d 01     call    0x2da   ; 0x2da <__mulsf3>
 166:   dc 01           movw    r26, r24
 168:   cb 01           movw    r24, r22
 16a:   bc 01           movw    r22, r24
 16c:   cd 01           movw    r24, r26
 16e:   0e 94 ec 00     call    0x1d8   ; 0x1d8 <__fixunssfsi>
 172:   dc 01           movw    r26, r24
 174:   cb 01           movw    r24, r22
 176:   9a 87           std     Y+10, r25       ; 0x0a
 178:   89 87           std     Y+9, r24        ; 0x09
 17a:   0f c0           rjmp    .+30            ; 0x19a <main+0x11a>
 17c:   89 e1           ldi     r24, 0x19       ; 25
 17e:   90 e0           ldi     r25, 0x00       ; 0
 180:   9c 87           std     Y+12, r25       ; 0x0c
 182:   8b 87           std     Y+11, r24       ; 0x0b
    milliseconds can be achieved.
void
_delay_loop_2(uint16_t __count)
        __asm__ volatile (
 184:   8b 85           ldd     r24, Y+11       ; 0x0b
 186:   9c 85           ldd     r25, Y+12       ; 0x0c
 188:   01 97           sbiw    r24, 0x01       ; 1
 18a:   f1 f7           brne    .-4             ; 0x188 <main+0x108>
 18c:   9c 87           std     Y+12, r25       ; 0x0c
 18e:   8b 87           std     Y+11, r24       ; 0x0b
                while(__ticks)
                        // wait 1/10 ms
                        _delay_loop_2(((F_CPU) / 4e3) / 10);
                        __ticks --;
 190:   89 85           ldd     r24, Y+9        ; 0x09
 192:   9a 85           ldd     r25, Y+10       ; 0x0a
 194:   01 97           sbiw    r24, 0x01       ; 1
 196:   9a 87           std     Y+10, r25       ; 0x0a
 198:   89 87           std     Y+9, r24        ; 0x09
                __ticks = 1;
                while(__ticks)
 19a:   89 85           ldd     r24, Y+9        ; 0x09
 19c:   9a 85           ldd     r25, Y+10       ; 0x0a
 19e:   89 2b           or      r24, r25
 1a0:   69 f7           brne    .-38            ; 0x17c <main+0xfc>
 1a2:   14 c0           rjmp    .+40            ; 0x1cc <main+0x14c>
                        __ticks --;
                return;
                __ticks = (uint16_t)__tmp;
 1a4:   6d 81           ldd     r22, Y+5        ; 0x05
 1a6:   7e 81           ldd     r23, Y+6        ; 0x06
 1a8:   8f 81           ldd     r24, Y+7        ; 0x07
 1aa:   98 85           ldd     r25, Y+8        ; 0x08
 1ac:   0e 94 ec 00     call    0x1d8   ; 0x1d8 <__fixunssfsi>
 1b0:   dc 01           movw    r26, r24
 1b2:   cb 01           movw    r24, r22
 1b4:   9a 87           std     Y+10, r25       ; 0x0a
 1b6:   89 87           std     Y+9, r24        ; 0x09
 1b8:   89 85           ldd     r24, Y+9        ; 0x09
 1ba:   9a 85           ldd     r25, Y+10       ; 0x0a
 1bc:   9e 87           std     Y+14, r25       ; 0x0e
 1be:   8d 87           std     Y+13, r24       ; 0x0d
 1c0:   8d 85           ldd     r24, Y+13       ; 0x0d
 1c2:   9e 85           ldd     r25, Y+14       ; 0x0e
 1c4:   01 97           sbiw    r24, 0x01       ; 1
 1c6:   f1 f7           brne    .-4             ; 0x1c4 <main+0x144>
 1c8:   9e 87           std     Y+14, r25       ; 0x0e
 1ca:   8d 87           std     Y+13, r24       ; 0x0d
        _delay_ms(100);
 1cc:   72 cf           rjmp    .-284           ; 0xb2 <main+0x32>
000001ce <__cmpsf2>:
 1ce:   0e 94 1b 01     call    0x236   ; 0x236 <__fp_cmp>
 1d2:   08 f4           brcc    .+2             ; 0x1d6 <__cmpsf2+0x8>
 1d4:   81 e0           ldi     r24, 0x01       ; 1
 1d6:   08 95           ret
000001d8 <__fixunssfsi>:
 1d8:   0e 94 47 01     call    0x28e   ; 0x28e <__fp_splitA>
 1dc:   88 f0           brcs    .+34            ; 0x200 <__fixunssfsi+0x28>
 1de:   9f 57           subi    r25, 0x7F       ; 127
 1e0:   98 f0           brcs    .+38            ; 0x208 <__fixunssfsi+0x30>
 1e2:   b9 2f           mov     r27, r25
 1e4:   99 27           eor     r25, r25
 1e6:   b7 51           subi    r27, 0x17       ; 23
 1e8:   b0 f0           brcs    .+44            ; 0x216 <__fixunssfsi+0x3e>
 1ea:   e1 f0           breq    .+56            ; 0x224 <__fixunssfsi+0x4c>
 1ec:   66 0f           add     r22, r22
 1ee:   77 1f           adc     r23, r23
 1f0:   88 1f           adc     r24, r24
 1f2:   99 1f           adc     r25, r25
 1f4:   1a f0           brmi    .+6             ; 0x1fc <__fixunssfsi+0x24>
 1f6:   ba 95           dec     r27
 1f8:   c9 f7           brne    .-14            ; 0x1ec <__fixunssfsi+0x14>
 1fa:   14 c0           rjmp    .+40            ; 0x224 <__fixunssfsi+0x4c>
 1fc:   b1 30           cpi     r27, 0x01       ; 1
 1fe:   91 f0           breq    .+36            ; 0x224 <__fixunssfsi+0x4c>
 200:   0e 94 61 01     call    0x2c2   ; 0x2c2 <__fp_zero>
 204:   b1 e0           ldi     r27, 0x01       ; 1
 206:   08 95           ret
 208:   0c 94 61 01     jmp     0x2c2   ; 0x2c2 <__fp_zero>
 20c:   67 2f           mov     r22, r23
 20e:   78 2f           mov     r23, r24
 210:   88 27           eor     r24, r24
 212:   b8 5f           subi    r27, 0xF8       ; 248
 214:   39 f0           breq    .+14            ; 0x224 <__fixunssfsi+0x4c>
 216:   b9 3f           cpi     r27, 0xF9       ; 249
 218:   cc f3           brlt    .-14            ; 0x20c <__fixunssfsi+0x34>
 21a:   86 95           lsr     r24
 21c:   77 95           ror     r23
 21e:   67 95           ror     r22
 220:   b3 95           inc     r27
 222:   d9 f7           brne    .-10            ; 0x21a <__fixunssfsi+0x42>
 224:   3e f4           brtc    .+14            ; 0x234 <__fixunssfsi+0x5c>
 226:   90 95           com     r25
 228:   80 95           com     r24
 22a:   70 95           com     r23
 22c:   61 95           neg     r22
 22e:   7f 4f           sbci    r23, 0xFF       ; 255
 230:   8f 4f           sbci    r24, 0xFF       ; 255
 232:   9f 4f           sbci    r25, 0xFF       ; 255
 234:   08 95           ret
00000236 <__fp_cmp>:
 236:   99 0f           add     r25, r25
 238:   00 08           sbc     r0, r0
 23a:   55 0f           add     r21, r21
 23c:   aa 0b           sbc     r26, r26
 23e:   e0 e8           ldi     r30, 0x80       ; 128
 240:   fe ef           ldi     r31, 0xFE       ; 254
 242:   16 16           cp      r1, r22
 244:   17 06           cpc     r1, r23
 246:   e8 07           cpc     r30, r24
 248:   f9 07           cpc     r31, r25
 24a:   c0 f0           brcs    .+48            ; 0x27c <__fp_cmp+0x46>
 24c:   12 16           cp      r1, r18
 24e:   13 06           cpc     r1, r19
 250:   e4 07           cpc     r30, r20
 252:   f5 07           cpc     r31, r21
 254:   98 f0           brcs    .+38            ; 0x27c <__fp_cmp+0x46>
 256:   62 1b           sub     r22, r18
 258:   73 0b           sbc     r23, r19
 25a:   84 0b           sbc     r24, r20
 25c:   95 0b           sbc     r25, r21
 25e:   39 f4           brne    .+14            ; 0x26e <__fp_cmp+0x38>
 260:   0a 26           eor     r0, r26
 262:   61 f0           breq    .+24            ; 0x27c <__fp_cmp+0x46>
 264:   23 2b           or      r18, r19
 266:   24 2b           or      r18, r20
 268:   25 2b           or      r18, r21
 26a:   21 f4           brne    .+8             ; 0x274 <__fp_cmp+0x3e>
 26c:   08 95           ret
 26e:   0a 26           eor     r0, r26
 270:   09 f4           brne    .+2             ; 0x274 <__fp_cmp+0x3e>
 272:   a1 40           sbci    r26, 0x01       ; 1
 274:   a6 95           lsr     r26
 276:   8f ef           ldi     r24, 0xFF       ; 255
 278:   81 1d           adc     r24, r1
 27a:   81 1d           adc     r24, r1
 27c:   08 95           ret
0000027e <__fp_split3>:
 27e:   57 fd           sbrc    r21, 7
 280:   90 58           subi    r25, 0x80       ; 128
 282:   44 0f           add     r20, r20
 284:   55 1f           adc     r21, r21
 286:   59 f0           breq    .+22            ; 0x29e <__fp_splitA+0x10>
 288:   5f 3f           cpi     r21, 0xFF       ; 255
 28a:   71 f0           breq    .+28            ; 0x2a8 <__fp_splitA+0x1a>
 28c:   47 95           ror     r20
0000028e <__fp_splitA>:
 28e:   88 0f           add     r24, r24
 290:   97 fb           bst     r25, 7
 292:   99 1f           adc     r25, r25
 294:   61 f0           breq    .+24            ; 0x2ae <__fp_splitA+0x20>
 296:   9f 3f           cpi     r25, 0xFF       ; 255
 298:   79 f0           breq    .+30            ; 0x2b8 <__fp_splitA+0x2a>
 29a:   87 95           ror     r24
 29c:   08 95           ret
 29e:   12 16           cp      r1, r18
 2a0:   13 06           cpc     r1, r19
 2a2:   14 06           cpc     r1, r20
 2a4:   55 1f           adc     r21, r21
 2a6:   f2 cf           rjmp    .-28            ; 0x28c <__fp_split3+0xe>
 2a8:   46 95           lsr     r20
 2aa:   f1 df           rcall   .-30            ; 0x28e <__fp_splitA>
 2ac:   08 c0           rjmp    .+16            ; 0x2be <__fp_splitA+0x30>
 2ae:   16 16           cp      r1, r22
 2b0:   17 06           cpc     r1, r23
 2b2:   18 06           cpc     r1, r24
 2b4:   99 1f           adc     r25, r25
 2b6:   f1 cf           rjmp    .-30            ; 0x29a <__fp_splitA+0xc>
 2b8:   86 95           lsr     r24
 2ba:   71 05           cpc     r23, r1
 2bc:   61 05           cpc     r22, r1
 2be:   08 94           sec
 2c0:   08 95           ret
000002c2 <__fp_zero>:
 2c2:   e8 94           clt
000002c4 <__fp_szero>:
 2c4:   bb 27           eor     r27, r27
 2c6:   66 27           eor     r22, r22
 2c8:   77 27           eor     r23, r23
 2ca:   cb 01           movw    r24, r22
 2cc:   97 f9           bld     r25, 7
 2ce:   08 95           ret
000002d0 <__gesf2>:
 2d0:   0e 94 1b 01     call    0x236   ; 0x236 <__fp_cmp>
 2d4:   08 f4           brcc    .+2             ; 0x2d8 <__gesf2+0x8>
 2d6:   8f ef           ldi     r24, 0xFF       ; 255
 2d8:   08 95           ret
000002da <__mulsf3>:
 2da:   0e 94 80 01     call    0x300   ; 0x300 <__mulsf3x>
 2de:   0c 94 f1 01     jmp     0x3e2   ; 0x3e2 <__fp_round>
 2e2:   0e 94 e3 01     call    0x3c6   ; 0x3c6 <__fp_pscA>
 2e6:   38 f0           brcs    .+14            ; 0x2f6 <__mulsf3+0x1c>
 2e8:   0e 94 ea 01     call    0x3d4   ; 0x3d4 <__fp_pscB>
 2ec:   20 f0           brcs    .+8             ; 0x2f6 <__mulsf3+0x1c>
 2ee:   95 23           and     r25, r21
 2f0:   11 f0           breq    .+4             ; 0x2f6 <__mulsf3+0x1c>
 2f2:   0c 94 da 01     jmp     0x3b4   ; 0x3b4 <__fp_inf>
 2f6:   0c 94 e0 01     jmp     0x3c0   ; 0x3c0 <__fp_nan>
 2fa:   11 24           eor     r1, r1
 2fc:   0c 94 62 01     jmp     0x2c4   ; 0x2c4 <__fp_szero>
00000300 <__mulsf3x>:
 300:   0e 94 3f 01     call    0x27e   ; 0x27e <__fp_split3>
 304:   70 f3           brcs    .-36            ; 0x2e2 <__mulsf3+0x8>
00000306 <__mulsf3_pse>:
 306:   95 9f           mul     r25, r21
 308:   c1 f3           breq    .-16            ; 0x2fa <__mulsf3+0x20>
 30a:   95 0f           add     r25, r21
 30c:   50 e0           ldi     r21, 0x00       ; 0
 30e:   55 1f           adc     r21, r21
 310:   62 9f           mul     r22, r18
 312:   f0 01           movw    r30, r0
 314:   72 9f           mul     r23, r18
 316:   bb 27           eor     r27, r27
 318:   f0 0d           add     r31, r0
 31a:   b1 1d           adc     r27, r1
 31c:   63 9f           mul     r22, r19
 31e:   aa 27           eor     r26, r26
 320:   f0 0d           add     r31, r0
 322:   b1 1d           adc     r27, r1
 324:   aa 1f           adc     r26, r26
 326:   64 9f           mul     r22, r20
 328:   66 27           eor     r22, r22
 32a:   b0 0d           add     r27, r0
 32c:   a1 1d           adc     r26, r1
 32e:   66 1f           adc     r22, r22
 330:   82 9f           mul     r24, r18
 332:   22 27           eor     r18, r18
 334:   b0 0d           add     r27, r0
 336:   a1 1d           adc     r26, r1
 338:   62 1f           adc     r22, r18
 33a:   73 9f           mul     r23, r19
 33c:   b0 0d           add     r27, r0
 33e:   a1 1d           adc     r26, r1
 340:   62 1f           adc     r22, r18
 342:   83 9f           mul     r24, r19
 344:   a0 0d           add     r26, r0
 346:   61 1d           adc     r22, r1
 348:   22 1f           adc     r18, r18
 34a:   74 9f           mul     r23, r20
 34c:   33 27           eor     r19, r19
 34e:   a0 0d           add     r26, r0
 350:   61 1d           adc     r22, r1
 352:   23 1f           adc     r18, r19
 354:   84 9f           mul     r24, r20
 356:   60 0d           add     r22, r0
 358:   21 1d           adc     r18, r1
 35a:   82 2f           mov     r24, r18
 35c:   76 2f           mov     r23, r22
 35e:   6a 2f           mov     r22, r26
 360:   11 24           eor     r1, r1
 362:   9f 57           subi    r25, 0x7F       ; 127
 364:   50 40           sbci    r21, 0x00       ; 0
 366:   9a f0           brmi    .+38            ; 0x38e <__mulsf3_pse+0x88>
 368:   f1 f0           breq    .+60            ; 0x3a6 <__mulsf3_pse+0xa0>
 36a:   88 23           and     r24, r24
 36c:   4a f0           brmi    .+18            ; 0x380 <__mulsf3_pse+0x7a>
 36e:   ee 0f           add     r30, r30
 370:   ff 1f           adc     r31, r31
 372:   bb 1f           adc     r27, r27
 374:   66 1f           adc     r22, r22
 376:   77 1f           adc     r23, r23
 378:   88 1f           adc     r24, r24
 37a:   91 50           subi    r25, 0x01       ; 1
 37c:   50 40           sbci    r21, 0x00       ; 0
 37e:   a9 f7           brne    .-22            ; 0x36a <__mulsf3_pse+0x64>
 380:   9e 3f           cpi     r25, 0xFE       ; 254
 382:   51 05           cpc     r21, r1
 384:   80 f0           brcs    .+32            ; 0x3a6 <__mulsf3_pse+0xa0>
 386:   0c 94 da 01     jmp     0x3b4   ; 0x3b4 <__fp_inf>
 38a:   0c 94 62 01     jmp     0x2c4   ; 0x2c4 <__fp_szero>
 38e:   5f 3f           cpi     r21, 0xFF       ; 255
 390:   e4 f3           brlt    .-8             ; 0x38a <__mulsf3_pse+0x84>
 392:   98 3e           cpi     r25, 0xE8       ; 232
 394:   d4 f3           brlt    .-12            ; 0x38a <__mulsf3_pse+0x84>
 396:   86 95           lsr     r24
 398:   77 95           ror     r23
 39a:   67 95           ror     r22
 39c:   b7 95           ror     r27
 39e:   f7 95           ror     r31
 3a0:   e7 95           ror     r30
 3a2:   9f 5f           subi    r25, 0xFF       ; 255
 3a4:   c1 f7           brne    .-16            ; 0x396 <__mulsf3_pse+0x90>
 3a6:   fe 2b           or      r31, r30
 3a8:   88 0f           add     r24, r24
 3aa:   91 1d           adc     r25, r1
 3ac:   96 95           lsr     r25
 3ae:   87 95           ror     r24
 3b0:   97 f9           bld     r25, 7
 3b2:   08 95           ret
000003b4 <__fp_inf>:
 3b4:   97 f9           bld     r25, 7
 3b6:   9f 67           ori     r25, 0x7F       ; 127
 3b8:   80 e8           ldi     r24, 0x80       ; 128
 3ba:   70 e0           ldi     r23, 0x00       ; 0
 3bc:   60 e0           ldi     r22, 0x00       ; 0
 3be:   08 95           ret
000003c0 <__fp_nan>:
 3c0:   9f ef           ldi     r25, 0xFF       ; 255
 3c2:   80 ec           ldi     r24, 0xC0       ; 192
 3c4:   08 95           ret
000003c6 <__fp_pscA>:
 3c6:   00 24           eor     r0, r0
 3c8:   0a 94           dec     r0
 3ca:   16 16           cp      r1, r22
 3cc:   17 06           cpc     r1, r23
 3ce:   18 06           cpc     r1, r24
 3d0:   09 06           cpc     r0, r25
 3d2:   08 95           ret
000003d4 <__fp_pscB>:
 3d4:   00 24           eor     r0, r0
 3d6:   0a 94           dec     r0
 3d8:   12 16           cp      r1, r18
 3da:   13 06           cpc     r1, r19
 3dc:   14 06           cpc     r1, r20
 3de:   05 06           cpc     r0, r21
 3e0:   08 95           ret
000003e2 <__fp_round>:
 3e2:   09 2e           mov     r0, r25
 3e4:   03 94           inc     r0
 3e6:   00 0c           add     r0, r0
 3e8:   11 f4           brne    .+4             ; 0x3ee <__fp_round+0xc>
 3ea:   88 23           and     r24, r24
 3ec:   52 f0           brmi    .+20            ; 0x402 <__LOCK_REGION_LENGTH__+0x2>
 3ee:   bb 0f           add     r27, r27
 3f0:   40 f4           brcc    .+16            ; 0x402 <__LOCK_REGION_LENGTH__+0x2>
 3f2:   bf 2b           or      r27, r31
 3f4:   11 f4           brne    .+4             ; 0x3fa <__fp_round+0x18>
 3f6:   60 ff           sbrs    r22, 0
 3f8:   04 c0           rjmp    .+8             ; 0x402 <__LOCK_REGION_LENGTH__+0x2>
 3fa:   6f 5f           subi    r22, 0xFF       ; 255
 3fc:   7f 4f           sbci    r23, 0xFF       ; 255
 3fe:   8f 4f           sbci    r24, 0xFF       ; 255
 400:   9f 4f           sbci    r25, 0xFF       ; 255
 402:   08 95           ret
00000404 <_exit>:
 404:   f8 94           cli
00000406 <__stop_program>:
 406:   ff cf           rjmp    .-2             ; 0x406 <__stop_program>
D:\atmel_avr\avr8-gnu-toolchain-win32_x86\bin>avr-gcc -mmcu=atmega328p -Os -g avr.c -o avr.elf
  78:   0c 94 54 00     jmp     0xa8    ; 0xa8 <_exit>
00000080 <main>:
int main(void) {
    DDRB = 0xFF;
  80:   8f ef           ldi     r24, 0xFF       ; 255
  82:   84 b9           out     0x04, r24       ; 4
    DDRC = 0xFF;
  84:   87 b9           out     0x07, r24       ; 7
    DDRD = 0xFF;
  86:   8a b9           out     0x0a, r24       ; 10
    while(1) {
        PORTB ^= 0xFF;
  88:   85 b1           in      r24, 0x05       ; 5
  8a:   80 95           com     r24
  8c:   85 b9           out     0x05, r24       ; 5
        PORTC ^= 0xFF;
  8e:   88 b1           in      r24, 0x08       ; 8
  90:   80 95           com     r24
  92:   88 b9           out     0x08, r24       ; 8
        PORTD ^= 0xFF;
  94:   8b b1           in      r24, 0x0b       ; 11
  96:   80 95           com     r24
  98:   8b b9           out     0x0b, r24       ; 11
        #else
                //round up by default
                __ticks_dc = (uint32_t)(ceil(fabs(__tmp)));
        #endif
  9a:   87 ea           ldi     r24, 0xA7       ; 167
  9c:   91 e6           ldi     r25, 0x61       ; 97
  9e:   01 97           sbiw    r24, 0x01       ; 1
  a0:   f1 f7           brne    .-4             ; 0x9e <main+0x1e>
  a2:   00 c0           rjmp    .+0             ; 0xa4 <main+0x24>
  a4:   00 00           nop
  a6:   f0 cf           rjmp    .-32            ; 0x88 <main+0x8>
000000a8 <_exit>:
  a8:   f8 94           cli
000000aa <__stop_program>:
  aa:   ff cf           rjmp    .-2             ; 0xaa <__stop_program>
The red generated code is the version with optimisation disabled, the blue is with it enabled. Perhaps it was unfair to include the _delay_ms() which goes potty if optimisation is not enabled? Even without that the difference is:
00000080 <main>:
int main(void) {
  80:   cf 93           push    r28
  82:   df 93           push    r29
    DDRB = 0xFF;
  88:   84 e2           ldi     r24, 0x24       ; 36
  8a:   90 e0           ldi     r25, 0x00       ; 0
  8c:   2f ef           ldi     r18, 0xFF       ; 255
  8e:   fc 01           movw    r30, r24
  90:   20 83           st      Z, r18
    DDRC = 0xFF;
  92:   87 e2           ldi     r24, 0x27       ; 39
  94:   90 e0           ldi     r25, 0x00       ; 0
  96:   2f ef           ldi     r18, 0xFF       ; 255
  98:   fc 01           movw    r30, r24
  9a:   20 83           st      Z, r18
    DDRD = 0xFF;
  9c:   8a e2           ldi     r24, 0x2A       ; 42
  9e:   90 e0           ldi     r25, 0x00       ; 0
  a0:   2f ef           ldi     r18, 0xFF       ; 255
  a2:   fc 01           movw    r30, r24
  a4:   20 83           st      Z, r18
    while(1) {
        PORTB ^= 0xFF;
  a6:   85 e2           ldi     r24, 0x25       ; 37
  a8:   90 e0           ldi     r25, 0x00       ; 0
  aa:   25 e2           ldi     r18, 0x25       ; 37
  ac:   30 e0           ldi     r19, 0x00       ; 0
  ae:   f9 01           movw    r30, r18
  b0:   20 81           ld      r18, Z
  b2:   20 95           com     r18
  b4:   fc 01           movw    r30, r24
  b6:   20 83           st      Z, r18
        PORTC ^= 0xFF;
  b8:   88 e2           ldi     r24, 0x28       ; 40
  ba:   90 e0           ldi     r25, 0x00       ; 0
  bc:   28 e2           ldi     r18, 0x28       ; 40
  be:   30 e0           ldi     r19, 0x00       ; 0
  c0:   f9 01           movw    r30, r18
  c2:   20 81           ld      r18, Z
  c4:   20 95           com     r18
  c6:   fc 01           movw    r30, r24
  c8:   20 83           st      Z, r18
        PORTD ^= 0xFF;
  ca:   8b e2           ldi     r24, 0x2B       ; 43
  cc:   90 e0           ldi     r25, 0x00       ; 0
  ce:   2b e2           ldi     r18, 0x2B       ; 43
  d0:   30 e0           ldi     r19, 0x00       ; 0
  d2:   f9 01           movw    r30, r18
  d4:   20 81           ld      r18, Z
  d6:   20 95           com     r18
  d8:   fc 01           movw    r30, r24
  da:   20 83           st      Z, r18
  dc:   e4 cf           rjmp    .-56            ; 0xa6 <main+0x26>
00000080 <main>:
int main(void) {
    DDRB = 0xFF;
    DDRC = 0xFF;
    DDRD = 0xFF;
    while(1) {
        PORTB ^= 0xFF;
  8a:   80 95           com     r24
        PORTC ^= 0xFF;
  90:   80 95           com     r24
        PORTD ^= 0xFF;
  96:   80 95           com     r24
  9a:   f6 cf           rjmp    .-20            ; 0x88 <main+0x8>
That is more than just 5..10% !!
Depends, many EVs are electronically limited but still have masses of power right up to maximum speed. My old Leaf was like that, loads of power even at motorway speeds but electronically limited to ~100 MPH. Actually it could do 96 MPH in reverse too.
I did https://www.avrfreaks.net/forum/... as long as they keep the Xmeag32E5 going for a few more years I'm happy.
@clawson
As much as I brutally hate XC8 with a passion and MPLAB X which are both third-world quality compared to tools actually meant for C (VS, CLion, etc).....
AVR-GCC in this situation hasn't been gimped. I opened up Studio 7. Selected the ATMega328P and compiled the same code and got the same raw list file.
What you are "doing wrong" is not using -O1 which is the studio default. XC8 isn't charging for -O1 either.
GccApplication2.elf:     file format elf32-avr
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .data         00000000  00800100  00800100  0000045c  2**0
                  CONTENTS, ALLOC, LOAD, DATA
  1 .text         00000408  00000000  00000000  00000054  2**1
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  2 .comment      00000030  00000000  00000000  0000045c  2**0
                  CONTENTS, READONLY
  3 .note.gnu.avr.deviceinfo 00000040  00000000  00000000  0000048c  2**2
                  CONTENTS, READONLY
  4 .debug_aranges 00000020  00000000  00000000  000004cc  2**0
                  CONTENTS, READONLY, DEBUGGING
  5 .debug_info   0000073c  00000000  00000000  000004ec  2**0
  6 .debug_abbrev 0000065b  00000000  00000000  00000c28  2**0
  7 .debug_line   000002d2  00000000  00000000  00001283  2**0
  8 .debug_frame  00000034  00000000  00000000  00001558  2**2
  9 .debug_str    00000384  00000000  00000000  0000158c  2**0
 10 .debug_loc    00000047  00000000  00000000  00001910  2**0
 11 .debug_ranges 00000010  00000000  00000000  00001957  2**0
00000080 <main>:
int main(void) {
  80: cf 93        push r28
  82: df 93        push r29
  8c: f8 94        cli
DDRB = 0xFF;
  9c: 20 83        st Z, r18
DDRC = 0xFF;
  a6: 20 83        st Z, r18
DDRD = 0xFF;
  b0: 20 83        st Z, r18
while(1) {
PORTB ^= 0xFF;
  bc: 20 81        ld r18, Z
  be: 20 95        com r18
  c2: 20 83        st Z, r18
PORTC ^= 0xFF;
  ce: 20 81        ld r18, Z
  d0: 20 95        com r18
  d4: 20 83        st Z, r18
PORTD ^= 0xFF;
  e0: 20 81        ld r18, Z
  e2: 20 95        com r18
  e6: 20 83        st Z, r18
#else
uint16_t __ticks;
if (__tmp < 1.0)
__ticks = 1;
void
__asm__ volatile (
while(__ticks)
// wait 1/10 ms
__ticks --;
__ticks = 1;
while(__ticks)
__ticks --;
return;
_delay_ms(100);
 1d6: 08 95        ret
 1f6: ba 95        dec r27
 206: 08 95        ret
 21a: 86 95        lsr r24
 21c: 77 95        ror r23
 21e: 67 95        ror r22
 220: b3 95        inc r27
 226: 90 95        com r25
 228: 80 95        com r24
 22a: 70 95        com r23
 22c: 61 95        neg r22
 234: 08 95        ret
 26c: 08 95        ret
 274: a6 95        lsr r26
 27c: 08 95        ret
 28c: 47 95        ror r20
 29a: 87 95        ror r24
 29c: 08 95        ret
 2a8: 46 95        lsr r20
 2b8: 86 95        lsr r24
 2be: 08 94        sec
 2c0: 08 95        ret
 2c2: e8 94        clt
 2ce: 08 95        ret
000002d0 <__gesf2>:
 2d8: 08 95        ret
 396: 86 95        lsr r24
 398: 77 95        ror r23
 39a: 67 95        ror r22
 39c: b7 95        ror r27
 39e: f7 95        ror r31
 3a0: e7 95        ror r30
 3ac: 96 95        lsr r25
 3ae: 87 95        ror r24
 3b2: 08 95        ret
 3be: 08 95        ret
 3c4: 08 95        ret
 3c8: 0a 94        dec r0
 3d2: 08 95        ret
 3d6: 0a 94        dec r0
 3e0: 08 95        ret
 3e4: 03 94        inc r0
 402: 08 95        ret
00000404 <_exit>:
 404: f8 94        cli
I fear you have entirely missed my point. I deliberately used (and used color highlighting to make the point) -O0 to show what you can get from a C compiler that is not optimising. I'm not saying this is a "good thing". In fact if you look at my signature then point #4 has been saying this very thing for more than a decade! But what I'm saying is that a compiler that makes no attempt to optimise can be ATROCIOUS in its code generation (gcc is!). The suggestion had been that the difference between optimisation on/off might be a 5..10% issue. My point was that it might be a case of code bloated by a factor of 10 or 20 or worse.!!
So no optimisation if not a "minor inconvenience" - it is "totally unusable".
I imagine that people who charge money to have optimisation switched on know this cheeky
I think you can see somewhat similar between AVRFreaks and the other so-called "communities" here?
As someone said (complained, actually) in another manufacturer's forum: there is a big difference between just opening a forum, and actually building a community.
I would not get too stressed over Compiler,  Microchip pricing, ....
Just try the MPLABX with whatever Tools suite is default.
How good is the debugging experience?
How pleasant is it to use e.g. compared to AS7, Keil, Rowley, ...
The current AVR Compiler works pretty well.   I would not worry if this is the "free" version.
If you have to pay for a "better" Compiler it is much like GCC vs IAR.  Or ARM-GCC vs the ARM Compiler.   Performance differences are marginal.
If the debugger was size-limited like Keil or otherwise crippled.   that would be fatal.
But hey-ho,   this would not be in Microchip's interest.
No,  I am not brave enough to try MPLABX yet.    I will let others be the guinea pigs first.
In a lot of the work I do the compiler is critical. I have invested a lot of time in understanding and gaining experience with AVR-GCC. It's also key to producing good firmware for some of my hobby stuff, and even then sometimes I have to drop down to assembler to get what I need.
So for me dropping AVR-GCC support, or just not updating it, means I will probably not ever switch to MPLAB or use new parts that are currently not supported. In fact, it's time to consider alternatives, maybe ARM since then I'm not tied to one vendor.
I am quite happy to use ARM-GCC even if the ARM tools are marginally better.
I would guess that the new XTiny chips have a similar compiler-model to Xmega.
So any new chips require no more than header files.
There is little point in getting upset. Just wait and see how MPLAB plays out.
Project build is trivial. Debug and Simulation are the critical areas.
Pages
