I'm confused with sbi cbi commands?
5 posts / 0 new
I'm trying to add some debug to my ASM and wanted to see it on a scope. So I simply used
sbi PORTB,2;//debug
and
cbi PORTB,2;//debug
But I only see one condition not both? I know my analyzer runs 4 times as fast as my device and my DDRB is set correctly.
If I only run the set command I get [```````] condition is hi. if I run a clear command I get [_______] condition is clear. but when running a set and clear I see the last operation only. [_______]  where I'd suspect to see  [````_____] .
In my C code I can just set the PORTB receptively and I get exactly what I'd expect to see. Even if I set the condition in ASM and clear in C it works as expected. For some reason (unknown to me) I do not see the change when using the two asm commands only.
Here is an exmaple
	sbi PORTB,2;//debug
#if USB_CFG_IMPLEMENT_FN_WRITEOUT   /* if we have data for endpoint != 0, set usbCurrentTok to address */
    andi    x3, 0xf             ;[32]
    breq    storeTokenAndReturn ;[33]
    mov     token, x3           ;[34] indicate that this is endpoint x OUT
#endif
storeTokenAndReturn:
    sts     usbCurrentTok, token;[35]
doReturn:
cbi PORTB,2;//debug
    POP_STANDARD                ;[37] 12...16 cycles
    USB_LOAD_PENDING(YL)        ;[49]
    sbrc    YL, USB_INTR_PENDING_BIT;[50] check whether data is already arriving
    rjmp    waitForJ            ;[51] save the pops and pushes -- a new interrupt is already pending
sofError:
    POP_RETI                    ;macro call
	RETI
but honestly my analyzer should have no issues picking up a
    cbi PORTB,2;//debug
    sbi PORTB,2;//debug
and does so in c with
 PORTB |= 0x04
 PORTB &= ~0x04
first it should work
just make a simple forever loop (and nothing else).
2.
 PORTB |= 0x04
 PORTB &= ~0x04
I would expect that the compiler use SBI and CBI for those lines of code. (and not a read modify write).
Yes, OP is perhaps assuming too much about the behavior of his code.  He should write this simple loop and confirm that he can detect it.
That's meaningless garble.
What is the minimum pulse width you can capture & display?  Is glitch removal turned on?  If so, turn it off.
For a "Are you even alive?!?!?!" type check, I tend to toggle a pin instead of pulsing it. Easier to spot on a scope or analyzer.
"We trained hard... but it seemed that every time we were beginning to form up into a team, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing. And a wonderful method it can be of creating the illusion of progress while producing confusion, inefficiency and demoralization." Petronius Arbiter, approx. 2000 years ago.
