SAMD20J17 - Watchdog callbacks/application note
5 posts / 0 new
Hi Everyone,
I'm using AS7.x and am trying to use the WDT module. I am also following the application note for using the watchdog in a callback configuration:
http://www.atmel.com/Images/Atmel-42124-SAM-Watchdog-WDT-Driver_ApplicationNote_AT03264.pdf
When I put the watchdog code in to my application, it appears to hang here (in wdt.c) for-ever which truly is ironic.
       while (wdt_is_syncing()) {
              /* Wait for all hardware modules to complete synchronization */
void configure_wdt(void) {
  struct wdt_conf config_wdt;
  wdt_get_config_defaults(&config_wdt);
  config_wdt.always_on = false;
  config_wdt.clock_source = GCLK_GENERATOR_4;
  config_wdt.timeout_period = WDT_PERIOD_4096CLK;
  config_wdt.early_warning_period = WDT_PERIOD_2048CLK;
  wdt_set_config(&config_wdt);
void configure_wdt_callbacks(void)
  wdt_register_callback(watchdog_early_warning_callback, WDT_CALLBACK_EARLY_WARNING);
  wdt_enable_callback(WDT_CALLBACK_EARLY_WARNING);
void watchdog_early_warning_callback(void)
int main(void) {
  system_init();
  configure_wdt(); // gets stuck here
  configure_wdt_callbacks();
Any ideas on making this work? :-)
Surely you can follow it "into" this call and find out where in that it is actually "stuck"? Presumably there's a wait loop on some status bit that is never set or something?
It appears as though the STATUS.reg register is not getting the appropriate bit cleared and always returning true.
#define WDT_STATUS_SYNCBUSY (0x1ul << WDT_STATUS_SYNCBUSY_Pos)
* \retval false If the module has completed synchronization
* \retval true If the module synchronization is ongoing
static inline bool wdt_is_syncing(void)
  Wdt *const WDT_module = WDT;
  #if (SAML21) || (SAML22) || (SAMC20) || (SAMC21)
  if (WDT_module->SYNCBUSY.reg) {
  #else
    if (WDT_module->STATUS.reg & WDT_STATUS_SYNCBUSY) { // right here
  #endif
      return true;
    return false;
I have the watchdog working;
I changed
     config_wdt.clock_source = GCLK_GENERATOR_2; // from _4
Why didn't config_wdt.clock_source = GCLK_GENERATOR_4 work?
Hey all,
Sorry to revive a dead post, but I thought I would add some things that I looked into and helped out with me understand some things.
Preface this with I’m using AS7.X, ASF(3.40.0) with a SAMD21. I know the OP is using SAMD20J17 and possibly ASF(v4?), so not sure how much it would directly correlate.
Also, here is some good clock reading: http://www.lucadavidian.com/2017/08/08/arduino-m0-pro-il-sistema-di-clock/
I’ve looked further into this and have followed the function calls into ASF land trying to figure out where GCLKs are setup:
  • system_init() is called from main.c and goes to system.c
  • Calls system_clock_init() and goes to clocks.c
    • This is the very modular clock initialization based on what the user has defined in conf_clocks.h
  • Calls system_gclk_init() and goes to gclk.c
    • This just initializes the GCLK driver and not the individual generic clocks. Turns on the digital interface clock to the module and software resets it.
  • Returns to clocks.c and initializes all GCLKs via _CONF_CLOCK_GCLK_CONFIG based on what is selected in conf_clocks.h
Via Clocks.c
#  define _CONF_CLOCK_GCLK_CONFIG(n, unused) \
    if (CONF_CLOCK_GCLK_##n##_ENABLE == true) { \
    struct system_gclk_gen_config gclk_conf;                          \
    system_gclk_gen_get_config_defaults(&gclk_conf);                  \
    gclk_conf.source_clock    = CONF_CLOCK_GCLK_##n##_CLOCK_SOURCE;   \
    gclk_conf.division_factor = CONF_CLOCK_GCLK_##n##_PRESCALER;      \
    gclk_conf.run_in_standby  = CONF_CLOCK_GCLK_##n##_RUN_IN_STANDBY; \
    gclk_conf.output_enable   = CONF_CLOCK_GCLK_##n##_OUTPUT_ENABLE;  \
    system_gclk_gen_set_config(GCLK_GENERATOR_##n, &gclk_conf);       \
    system_gclk_gen_enable(GCLK_GENERATOR_##n);                       \
My original assumption was that ASF would setup the all clocks for the WDT when added via ASF wizard and when using the library functions. This seems to be 50/50 correct. When using the library files(and the Example here), it sets up the digital interface clock but the WDT still needs a source clock which is one of the GCLKs. These clocks need to be enabled in conf_clocks.h. It seems that on a fresh ASF project, only GCLK[0] is enabled by default which is the main clock(also the CPU clock?). So this would probably explain why GCLK_GENERATOR_4 would not work. It’s trying to setup on a non-enabled clock and it is hanging waiting for something that won’t sync.
Now the issue is that changing GCLK_GENERATOR_4 to GCLK_GENERATOR_2 works. However, when I look at my conf_clocks.h none of my GCLKs(Other than GCLK[0]) are enabled.
Why does this work??
