Setting a flag in ASM
40 posts / 0 new
I want to set a simple global flag in ASM but I'm struggling to make it work.
In my S file I have
an include to my global var (_SOF_Flag)
I did this
 .extern _SOF_Flag
and later
sts     _SOF_Flag,1;set flag
but I my c app location that also includes the global definition  never sees this variable go to 1.
STS takes a register number as the second parameter so you are storing R1 into the location. In GCC R1 usually hols 0x00
Do something like:
LDI R24, 0x37
STS _SOF_Flag, R24
Ok, curios though. Are there any tricks to do this in 1 clock cycle? I'm tiring to set a flag in my USB code and it's extremely time sensitive. The flag just need to be set to anything other then 0.
If you choose the active state of the flag to be zero instead of one, it will be faster, because r1 is already zero (you don't need to clear it if it's a function called from C), you can just move r1 to the flag.
The sts instruction itself takes 2 cycles at least, I think. To be faster, you can use some I/O register within the range of the out instruction (1 cycle) to store the flag (some I/O register you are not using and is safe to change).
Duh, of course (Should have thought about that). I can do that. Is sts 2 clocks?
STS _SOF_Flag, R1 ;[2] ?
Yes, for classic AVRs memory access instructions usually take 2 cycles. Details here: http://ww1.microchip.com/downloa...
Remember that SBI and CBI also take 2 clk!
if it's only one flag and you are in control (no C) then use the T register. one clk to set and clear and easy to check with branches.
why not use:
ser reg#  ...set to 0xFF   ex:  ser myflag
clr reg#   ...set to 0x00  ex:   clr myflag
that's as fast as it gets.
Can you afford to allocate a whole register as your flag?  Probably, if you only have one (or few) flags.
because then you have to reserve one of the high registers.
but if that is ok use ORI and ANDI and skip on bit. then only one bit is used. (an AVR don't really have either SER and CLR instructions thy are macros for LDI r,$ff and EOR r,r )
Yeah I tried that but it required me to use a register.
I decided to go with the 2 clock and just use the portb. This way I don't even have to fool with making a global (and for quick test). but where did I go wrong?
asm
sbi PORTB,0
code
PORTB &= ~1;
while(!PORTB & 1)
//I never hit this loop?
Damn parenthesizes.
If there are many flags, General Purpose I/O Registers (GPIORx) registers within range of SBI/CBI and SBIS/SBIC can be used.
The tiny2313 has three such registers, but many AVRs have only one within range.
Which suggests the code where you later change the state of the bit is never executed. Can't help thinking you could benefit from an ICE here!
I should be clear just by single step the generated ASM code in the simulator.
Sparrow - apparently it's V-USB he's trying to understand/change. The "SOF" mentioned above is a USB "Start of Frame". As it's software USB it might be quite difficult to setup the external conditions for true simulation with just the AS7 simulator - that's why I suggested ICE.
ok I was just looking at the problem code in #10
IS there any way possible for a xmega to set a PORT register in one clock?
I only have 1 nop .
; bit 7:    jump, eor
rxLoop:
    eor     x3, shift   ;1 [0] reconstruct: x3 is 0 at bit locations we changed, 1 at others
    in      x1, USBIN   ;1 [1] <-- sample bit 0
    st      y+, x3      ;2 [3] store data
    ser     x3          ;1 [4]
    nop                 ;1 [5]
    eor     x2, x1      ;1 [6]
    bst     x2, USBMINUS;1 [7]
    bld     shift, 0    ;1 [8]
    in      x2, USBIN   ;1 [9] <-- sample bit 1 (or possibly bit 0 stuffed)
    andi    x2, USBMASK ;1 [10]
    breq    se0         ;1 [11] SE0 check for bit 1
    andi    shift, 0xf9 ;1 [12]
I think sbi only takes 1 cycle on the xmega.
I kept reading 1 on tiny, 2 on xmega on the forums. but stuffing sbi in the NOP causes it to fail.
Is the moment when the port changes important? Maybe placing the instruction before the "ser x3" would help, it's possible the instruction takes one cycle but the effect is not immediate due to some kind of pipeline.
Or maybe it really takes 2 cycles. Try on the Atmel Studio simulator, it usually has correct timings.
No it can flip later, that's ok.  Best I can tell it is taking 2. Any way of preparing data or a register and using load immediate? Does not matter what is loaded as long as it is always loaded the same way. I can check any condition.
The Xmega has the ability to map four PORTx_OUT/PORTx_DIR/PORTx_IN registers to low IO space using "VPORT" and then you can use things like SBI/CBI on them but if you are talking about the "USBIN" mentioned in the code above then if that is a real USB register in the USB peripheral then, no almost all the other SFRs in the XMega are not mappable to low addresses to benefit from IN/OUT/SBI/CBI/etc
Or is "USBIN" just a synonym for some PORTx_IN? If so, then yes, look to map "x" to one of the four VPORT positions.
PS this post is in the tiny/mega forum. Are you saying it's actually about Xmega?
Sorry I meant atmega.
Was looking to set any register or variable in one clock. Does not have to be a PORT register.
The only 1 clk IO instruction on "normal" AVR's are the IN and OUT instructions.
Add:
Forget this I did not read the "not"
Ok so
out $18,r1 ;
Should write a zero to PORTB  (PORTB  =0) based on the memory map since r1 is initially 0.
Any register?  [and you gave the OUT example with a whole register >>and<< I/O address.
You have already been given the T register suggestion.  There are many op codes on AVR8 that will affect e.g. the low bit of a register in one cycle. [apparently the xmega mention was a red herring but we still don't know the purpose of the snip hunt]  CLR COM INC DEC ADDI ...
If its that super-critical, why not just pick a register for that purpose & be done with it?  The AVR has plenty available.
That's a good point and I can always CLR or INC it in one clock. A bit more elegant than using a predefined register like PORTx anyways. Is there  away in the AVRstudio 6 debugger to see what has not been used? I'm thinking r31 is a safe bet want want to be sure.
Is there a way in GCC to allocate a variable to a fixed location in a register? You can certainly do it in other compilers.
Do you mean GCC 'C', or the GNU Assembler ?
GCC does have a mechanism to reserve registers. The command line option -ffixed-13 would tell it not to generate code that contains R13 (0..31 obviously available) and in C the syntax:
register uint8_t foo asm("r13");
could locate a variable called "foo" into register 13.
However, the libc that comes with the compiler (strcpy, printf, memset, etc) comes pre-compiled and on the day that it was built no one told it to avoid R13. So if this a program in which any libc function is invoked (either from Asm or C or both) there's a possibility the reserved register may be clobbered. It may be enough simply to study the LSS to verify that nothing but the author's code touches R13 but if the program is later built with next month's issue of GCC+libc it may be clobbered because of usage in the next issue.
r31 is for sure bad because it's a part of Z.
In general with GCC you can use r2-r10, but it depends of the libs you use.
read the doc. just to declare a variable to a register don't tell compiler not to use it for other things, but there is a way to tell not to use that register.
And remember that all instructions with a constant don't work with the low registers!
Not only then. There are more sources for pre-compiled code than libc (libgcc, libm). You don't even need to call a function explicitly, simple usage of operators can pull in pre-compiled code from a library.
Stefan Ernst
Aside from choosing the right register how can I use this?
in my h i did
register unsigned char CT_BUSY_FLAG asm("r3");
in asm I did
 .extern CT_BUSY_FLAG
inc CT_BUSY_FLAG
but I get constant value required.
I fear you misunderstand. The point is with -ffixed-3 and the:
in your C you have reserved register R3 so in the Asm you don't need an "extern" reference to it. It is simply R3. So if you do something like:
ldir R24, 0x55
mov r3, r24
then back over in the C when you access the "CT_BUSY_FLAG" you should find it now contains 0x55.
Two things:
1) I wouldn't use all upper case for C symbols. Most programmers on planet earth expect any symbol in upper case to be a pre-pro macro so it is very confusing!
2) I suppose in the Asm you could use define or similar to give R3 a more obvious name. Like:
#define CT_busy_flag r3
   ldi r24, 0x55
   mov CT_busy_flag, r24
and there I go breaking the rule in #1. For consistency I think you'd want to use the exact same symbol name in C and Asm but because of (1) I'm suggesting it's not all upper case so now in the Asm you have a #define that breaks rule (1) because it's a macro with a name that is no longer all upper case. Guess you can't win!
(perhaps avr-as has another way to assign a name to a register that does not involve the pre-pro or #define?)
Sure that all makes sense. Curios though what the difference here? Or I should say, why is mov needed?
  ldi r24, 0x55
  ldi CT_busy_flag,0x55
LDI works only with R16-R31.
Stefan Ernst
Does that really apply globally, or is it really just a 'C' thing?
If it's just a 'C' thing, then that gets rid of (or, at least, reduces) your "problem" of breaking rule #1 (which is, then, just a 'C' rule) when writing in Assembler ...
cool
.equiv CT_busy_flag, 3
(no, the '3' instead of 'r3' is not a typo)
Stefan Ernst
the answer to #35 is given but I will add:
in1 clk on low registers:
low registers can easy be cleared (eor r2,r2, or sub r2,r2) and that will work regardless of the value of r2 before.
but there is no simple way to put a value even just non zero into a low register (without knowing something else).
if you know it's zero just inc r2. (or com , neg ) (if there can come more than 0 this can fail)
if you know T==1 bst r2,n
if C(carry)==1 subc r2,r2  (this sounds odd to use but often that is actually the reason why you are setting the flag.)
have an other register that for sure are none zero mov r2,rn
If speed really matter I would go for the last and the most "clean", I have had ASM programs where r14=0xff and R15=0x00 all the time.
Ok there are also the ugly version:
in r2,$nn
(it should be possible to find something that is non zero, like if there is a output on a port that PORT register is non zero)
