Write on flash memory of Atmega64 during running
15 posts / 0 new
i want to write float variable to flash memory during running and change the variable depending on running code
i tried to use SPM instruction but i can't understand the steps to write on flash clearly .
i am using Atmel studio 7  and Atmega64 microcontroller
mohamed elsayed
Why Flash specifically? ATMega64 has 2K EEPROM ...
https://www.microchip.com/wwwproducts/en/ATmega64
So show what you tried.
For instructions on how to post source code, see Tip #1.
On the Product Page (link above), go to the 'Documents' Tab.
There are (at least) 3 Application Notes there regarding writing to Flash ...
i can't use  EEPROM because i want to write array of floats and the size of data will be more than 2K
mohamed elsayed
AVR106
You do know that flash has a limited write lifetime, ~10k times, right?  Seems you have chosen the wrong micro for the task, or look at using external eeprom/flash memory.
Each float is 32 bits; so you have over 64 512 values to store?
Do they really have to be floats ... ?
EDIT
Correction: see #8
ccrause wrote:
AVR106
Yep - that's one of 'em!
#6 ?
The EEPROM can hold 512 floats.
oops - you're right.
Must remember the difference between bits & bytes!
blush
#6 corrected.
#5
yes i know but i have to use internal flash memory and already the writing on flash will be less than 100 times .
thanks
#6
i have more than 512 float  .
#7
thanks it's very useful and i will try it now .
mohamed elsayed
And you're sure that they do actually need to be floats?
#11
unfortunately yes crying
i will try the functions in application note
thank you
mohamed elsayed
When you use the 'Reply' button in a post, the forum automatically identifies which post you're replying to - no need to manually type it:
#HowToReply
oh sorry i am a new user blush .
thanks
mohamed elsayed
I still put them in because in the past spam cleaning would break the number.
Is that fixed ?
