AREF to GND
10 posts / 0 new
I accidentally connected AREF to ground on my atmega328p and now it's not working.
I tried to recover fuses (http://www.instructables.com/id/HV-Rescue-Simple/), but it didn't work.
Did I destroy it or can I save it somehow?
Ondra
ondralukes wrote:
it's not working
what's not working - AREF, the ADC, or the whole chip?
"what's not working - AREF, the ADC, or the whole chip?"
As far as now, neither :
according to OP fuse recovery is not working.... and his natural (and interesting, unlike some answer)  question is whether chip is still working.... and can be recovered...
the whole chip isn't working
Then, only remaining question is "can I save it somehow?"
In such a dubious state, I could not sell it (would be unethical); if something went wrong, I could not find wether it is software issue or half burned hardware.
-> I would get rid of it (but before, wait and hope until someone more competent than me tells I am wrong)
How do you know?
For example...
can you read the signature?
can you still program the chip?
can you flash an LED at 1Hz?
It isn't working at all, I can't read signature, can't program the chip.
Image result for it's dead, jim
crying
Ok, I'll buy new one.
Anyway, thanks for help.
Wait until someone more competent rknows how to resurrect it
In the mean time, buy two -at least-  (are cheap; allows other short circuits)
