ATtiny417 / ATtiny814 / ATtiny816 / ATtiny817
382 posts / 0 new
Pages
Ultimately you can write programs for any model of AVR using Eclipse but note that if you are using "plugins" that "know" the AVR models and perhaps allow you to select them from a drop list then those may not yet have been updated for newer models (so you may have to find some way to over-ride what they are selecting - presumably the input value for -mmcu= ?
AT_TRUCK wrote:
Is it possible to program attiny817 / 1616 via eclipse?
No, you will need an Atmel-ICE to program it.....  devil
Microchip Technology Inc
Press Release
Increase System Performance in Closed-loop Control Applications with New PIC® and AVR® MCUs
Chandler, Arizona
May 31, 2018
https://www.microchip.com/pressreleasepage/optimize-closed-loop-control-applications-with-new-PIC-and-AVR-MCUs
Offered in a compact 3 x 3 mm 20-pin QFN package, the new ATtiny1607 family is optimized for space-constrained closed-loop control systems such as handheld power tools and remote controls. In addition to the integrated high-speed Analog-to-Digital Converter (ADC) that provides faster conversion of analog signals resulting in deterministic system response, the devices provide improved oscillator accuracy, allowing designers to reduce external components and save costs.
Pricing and Availability
The PIC18 Q10 and ATtiny1607 are available today for sampling and in volume production.
... and pricing for the ATtiny1607 family starts at $0.56 each in 10,000-unit quantities.
via https://plus.google.com/+MicrochipTech/posts/PCvM6yQN3y1
http://new.microchipdirect.com/product/search/all/ATtiny1607
This is getting confusing. Let me compare the tiny AVR-0 and tiny AVR-1 side by side:
So the "zeroes" are stripped down versions of the "ones"...
edit: but do they have an ADC? I don't see it here, but it's in the datasheet.
Or maybe ONEs that had some flash or RAM problems and they become ZEROS? laugh
Where is the ADC in the Tiny1607 comparison in post # 355 but mentioned in the press release of post # 354?
I copied that from Microchip's site, I think they forgot the ADC but it exists. At least it's in the datasheet.
I have designed a Offline Autoprogramer can support UPDI interface to program ATTINY816/817......with updi interface.
if you interest this, please contact me.
Microchip
Product Change Notification - SYST-08NSCT658 - 11 Jun 2018 - Data Sheet - ATtiny416/ATtiny417/ATtiny816/ATtiny817 Automotive Data Sheet
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-08NSCT658
Microchip
Product Change Notification - SYST-08FCQV798 - 11 Jun 2018 - Data Sheet - ATtiny1616/1617 Automotive Data Sheet
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-08FCQV798
Speed Grade corrected to: 0-8 MHz @ 2.7V – 5.5V
That's a bit depressing (used to be 0-10MHz in that voltage range, and 20MHz (now 16) f0r 4.5-5V.)
Chips/processes are not supposed to get slower...
Ideally, yes, they get faster ... ;)
I see they also did this  Removed the Data retention: 20 years at 85°C
I guess it comes down to yields... ?
remember that "normal" tiny1616 still is 20MHz
They say it's a documentation change only, the product is the same. I guess things just get tough @ 125 ºC and they just can't risk guaranteeing operation above 8 MHz.
Application Notes
AN2636 Migration Between tinyAVR® 1-Series and tinyAVR 0-Series
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en604871
peripheral types not in tinyAVR 0-series :
  • DAC
  • PTC
  • TCD
reduced peripherals in tinyAVR 0-series :
  • AC - low power only, 16KB have one AC instead of three
  • EVSYS - channel count is halved
  • TWI - no alternate pins
  • CLKCTRL - no crystal oscillator (tinyAVR 0-series have 20MHZ internal RC, 32KHz internal RC, and EXTCLK)
https://www.microchip.com/wwwproducts/en/ATTINY1617
https://www.microchip.com/wwwproducts/en/ATTINY1607
#365
And for some parts less RAM
El Tangas wrote:
# ATtiny3216
    signature = 0x1E 0x95 0x21;
# ATtiny3217
    signature = 0x1E 0x95 0x22;
Press Release
Increase Functionality in Sensor Nodes with New 8-bit tinyAVR® MCUs
ATtiny3217 and ATtiny3216 join Microchip’s tinyAVR family with largest memory in the series
Chandler, Arizona
June 28, 2018
https://www.microchip.com/pressreleasepage/increase-functionality-in-sensor-nodes-with-tinyavr-mcus
Ideal for sensor applications including capacitive touch interfaces, the ATtiny3217 and ATtiny3216 bring the benefit of two Analog-to-Digital Converters (ADCs) that enable systems to implement touch control simultaneously with other analog measurements. One ADC can be used with the Peripheral Touch Controller (PTC) for touch signal acquisition, while the second one monitors other inputs such as thermistors and pressure sensors, or both ADCs can be used for faster sampling of different types of sensors. Additional benefits of the ATtiny3217 and ATtiny3216 MCUs include:
[EVSYS, POR + BOD + VLM + WWDT, 5V and 125C, 32KB flash]
Development Tools
For evaluation purposes, the ATtiny3217 Xplained Pro evaluation kit is also available.
[http://www.microchip.com/developmenttools/ProductDetails/ATTINY3217-XPRO]
The ATtiny3217 and ATtiny3216 are available now for sampling and in volume production starting at $0.68 each in 10,000-unit quantities. The ATtiny3217 Xplained Pro evaluation kit (ATTINY3217-XPRO) is available now for $38 each.
via https://plus.google.com/+MicrochipTech/posts/Hp5ZvA4t8rM
http://new.microchipdirect.com/product/search/all/ATtiny3217
http://new.microchipdirect.com/product/search/all/ATtiny3216
New arrivals at Mouser though not yet in stock :
https://www.mouser.com/new/microchip/microchip-attiny204-mcu/ (ETA 31-Aug-18)
https://www.mouser.com/new/microchip/microchip-attiny404-mcu/ (ETA 31-Aug-18)
# ATtiny412
    signature = 0x1E 0x92 0x23;
new arrival at Mouser :
https://www.mouser.com/new/microchip/microchip-attiny412-mcu/
tiny1607 and tiny807 are new arrivals at Mouser :
https://www.mouser.com/new/microchip/microchip-attiny1607-mcu/
https://www.mouser.com/new/microchip/microchip-attiny807-mcu/ (ETA 10-Sep'18 and 18-Oct'18)
Edit : ETA
Product Change Notification - SYST-20GTSK052 - 23 Aug 2018 - Data Sheet - ATtiny3217/ATtiny1617 Data Sheet
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-20GTSK052
Description of Change
These errata were removed from ATtiny3217 die revision C:
• ADC: Pending event stuck when disabling ADC
• All for CCL, RTC, and USART
likewise for tiny3216 and tiny1616 :
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-20YBIS927
https://www.mouser.com/new/microchip/microchip-attiny3217-kit/
Mouser has ordered tiny3216 (both temperature ranges) with an ETA of 14-Jan'19.
https://www.mouser.com/new/microchip/microchip-attiny3216-mcu/
https://www.microchip.com/wwwproducts/en/ATTINY3216
Microchip Thailand will be the second assembly site for some tinyAVR 0 and 1-series.
Product Change Notification - LIAL-30BVKD482 - 17 Sep 2018 - CCB 3321 and 3321.001 Final Notice: Qualification of MTAI as an additional assembly site for selected Atmel products of the 59.91k wafer technology available in 20L VQFN package.
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=LIAL-30BVKD482
tinyAVR 0-series in CodeVisionAVR :
CodeVisionAVR V3 Revision History
V3.34 Commercial Release
  • Compiler
  • Added support for the ATtiny202/204/402/404/406/412/804/806/807/1604/1606/1607 AVR8X chips
  • CodeWizardAVR
  • Added support for the AVR8X ATtiny202/204/402/404/406/412/804/806/807/1604/1606/1607 AVR8X chips
  • Added code generation for the ADC of the AVR8X chips
I've published schematics , PCB and FWs for mEDBG based DIY debugger: https://www.avrfreaks.net/forum/xplained-yourself-diy-updi-ispdw-tpi-swd-debugger-supported-atmel-studio
Unlike Xplained series it supports all MCUs with corresponding protocol. It can be roprogrammed to UPDI ,ISP, TPI, SWD. Maybe it will help somebody.
Pages
