ATBTLC1000 is not discoverable
5 posts / 0 new
We want to hook up ATBTL1000 to an external host MCU (AT32UC3A0512) via UART to establish a serial data communication over Bluetooth. Basically, we want to have a cable replacement solution for data transfer between a host PC/iPhone/Android/Mac and out device.
Following are the connections between the BT module and MCU. We haven't connected the 6 UART pins to the MCU yet, because we first wanted to see if the chip is even discoverable with the 3.3V, GND, Wake and Chip_EN pins. Despite seeing 3.3V, GND and 32.768 kHz clock on the corresponding pins, and not connected pins floating high, on the Oscilloscope, the BT module is not discoverable.
P4 - NC
P5 - NC
P6 - 3.3V
P7 - NC
P8 - NC
P17 - 3.3V
P20 - 3.3V
P21 - NC
P22 - NC
P1 - GND
P6 - 3.3V
P9 - GND
P13 - GND
P22 - 3.3V
P24 - GND
What is wrong with this set-up? Please advise.
(FYI - When I opened a ticket, tech support seemed to suggest that I need a API for the chip to be discoverable, which makes no sense to me!! if you have any experience with this module, could you verify this statement or share with me what I could be doing wrong?)
Thanks for pointing that out. I will post my question there.
I will lock this one.
Topic locked
