Atmel Studio 7 search issue
4 posts / 0 new
I am working on a project for a SAMD device. whenever i try to search for a reference from the main.c file , neither the search function (CTRL - F -> entire solution) nor the the context menu (hovering over variable/constant) can find the reference in another file that is part of the whole project.
for example...
i try to find where  "GCLK_CLKCTRL_ID_SERCOM0_CORE" is located in the the files that are part of the project . The only result both searches point me to are in the main.c file even though it is also to be found in the /dependencies/gclk.h  file .
If i have the gclk.h file opened in an editor window , the search (CTRL - F -> entire solution) can find "GCLK_CLKCTRL_ID_SERCOM0_CORE" in all files (main.c and gclk.h)
Is there a setting i need to adjust for the search to to look inside all the dependencies and included files ?
Try rebuilding the symbol database inside Visual Assist.  There are a couple of settings to play with under the menu VAssistX->Visual Assist Options->Performance
didnt work.
"go to implementation" from context menu when hovering over what one wants to find works tough.
