Atmel Start Import - Component Version missing
4 posts / 0 new
I would like to use Atmel Start with ATSAME70 Xplained to configure my project. Unfortunately I obtain this error message:
 "Device ATSAME70Q21B has been updated, project might not wok correctly. Please run the Device Pack Manager. Do you still want to try to load the project?"
I installed the latest: Atmel.SAMV70_DFP.2.3.90.atpack
I tried to change to ATSAME70Q21 A or B with various packages but I still obtain the same message. And if I skip and load the project, it doesn't compile.
Could you please suggest?
Many thanks.
Are you sure you have all the SAME70 device packs?  The latest is 2.3.98 not 2.3.90.  From the main menu, Tools->Device Pack Manager.  Here's a screenshot of my setup:
It worked! Fantastic! Thank you.
So please mark the solution - see Tip #5
