Id returned 1 exit status
7 posts / 0 new
Hello Everyone, Recently i convert Arduino mega2560 programme into atmega1284p using Arduino library, but when i compile the Avr Code it give me Error "Id returned 1 exit status".
can anybody help me please.
I use Atmel studio 7 (Version : 7.0.1931)
PcC Operating System : Windows 10 64 bit.
 i Atteched entire code as Zip file. thank you.
I think you'll find that's "ld" (with a lowercase 'L') - not "Id" ?
In other words, you have a Linker error.
So what you need to do is to go to the 'Output' Tab, copy the entire output from the build, and paste that here.
------ Rebuild All started: Project: P10_RGB_Demo_1284p_C++, Configuration: Debug AVR ------
Build started.
Project "P10_RGB_Demo_1284p_C++.cppproj" (Clean target(s)):
Target "Clean" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++.cppproj" (entry point):
Task "RunCompilerTask"
Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe clean
rm -rf  Adafruit_GFX.o main.o Print.o RGBmatrixPanel.o WString.o
rm -rf  Adafruit_GFX.d main.d Print.d RGBmatrixPanel.d WString.d
rm -rf "P10_RGB_Demo_1284p_C++.elf" "P10_RGB_Demo_1284p_C++.a" "P10_RGB_Demo_1284p_C++.hex" "P10_RGB_Demo_1284p_C++.lss" "P10_RGB_Demo_1284p_C++.eep" "P10_RGB_Demo_1284p_C++.map" "P10_RGB_Demo_1284p_C++.srec" "P10_RGB_Demo_1284p_C++.usersignatures"
Done executing task "RunCompilerTask".
Done building target "Clean" in project "P10_RGB_Demo_1284p_C++.cppproj".
Done building project "P10_RGB_Demo_1284p_C++.cppproj".
Build succeeded.
Build started.
Project "P10_RGB_Demo_1284p_C++.cppproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++.cppproj" (target "Build" depends on it):
C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 4 --output-sync
Building file: .././main.cpp
Invoking: AVR8/GNU C Compiler : 5.4.0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include" -I".." -I"../.."  -O0 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p" -c -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.cpp"
Finished building: .././main.cpp
Building file: .././Print.cpp
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include" -I".." -I"../.."  -O0 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p" -c -MD -MP -MF "Print.d" -MT"Print.d" -MT"Print.o"   -o "Print.o" ".././Print.cpp"
Finished building: .././Print.cpp
Building file: .././RGBmatrixPanel.cpp
In file included from .././RGBmatrixPanel.cpp:31:0:
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay.h(92,3): warning: #warning "F_CPU not defined for <util/delay.h>" [-Wcpp]
# warning "F_CPU not defined for <util/delay.h>"
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay.h(112,3): warning: #warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed" [-Wcpp]
# warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
.././RGBmatrixPanel.cpp: In member function 'void RGBmatrixPanel::dumpMatrix()':
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\RGBmatrixPanel.cpp(407,7): warning: unused variable 'i' [-Wunused-variable]
   int i, buffsize = 32 * nRows * 3 * nPanels;
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\RGBmatrixPanel.cpp(407,10): warning: unused variable 'buffsize' [-Wunused-variable]
.././RGBmatrixPanel.cpp: In member function 'void RGBmatrixPanel::updateDisplay()':
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\RGBmatrixPanel.cpp(560,73): warning: 'tick' may be used uninitialized in this function [-Wmaybe-uninitialized]
       asm volatile("out %0,%1" :: "I"(_SFR_IO_ADDR(SCLKPORT)),"r"(tick)); \
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\RGBmatrixPanel.cpp(561,73): warning: 'tock' may be used uninitialized in this function [-Wmaybe-uninitialized]
       asm volatile("out %0,%1" :: "I"(_SFR_IO_ADDR(SCLKPORT)),"r"(tock));
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include" -I".." -I"../.."  -O0 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p" -c -MD -MP -MF "RGBmatrixPanel.d" -MT"RGBmatrixPanel.d" -MT"RGBmatrixPanel.o"   -o "RGBmatrixPanel.o" ".././RGBmatrixPanel.cpp"
Finished building: .././RGBmatrixPanel.cpp
Building file: .././Adafruit_GFX.cpp
.././Adafruit_GFX.cpp: In member function 'bool Adafruit_GFX_Button::contains(int16_t, int16_t)':
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\Adafruit_GFX.cpp(1125,28): warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   return ((x >= _x1) && (x < (_x1 + _w)) &&
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\Adafruit_GFX.cpp(1126,28): warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           (y >= _y1) && (y < (_y1 + _h)));
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include" -I".." -I"../.."  -O0 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p" -c -MD -MP -MF "Adafruit_GFX.d" -MT"Adafruit_GFX.d" -MT"Adafruit_GFX.o"   -o "Adafruit_GFX.o" ".././Adafruit_GFX.cpp"
Finished building: .././Adafruit_GFX.cpp
Building file: .././WString.cpp
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\include" -I".." -I"../.."  -O0 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p" -c -MD -MP -MF "WString.d" -MT"WString.d" -MT"WString.o"   -o "WString.o" ".././WString.cpp"
Finished building: .././WString.cpp
Building target: P10_RGB_Demo_1284p_C++.elf
Invoking: AVR8/GNU Linker : 5.4.0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -o P10_RGB_Demo_1284p_C++.elf  Adafruit_GFX.o main.o Print.o RGBmatrixPanel.o WString.o   -Wl,-Map="P10_RGB_Demo_1284p_C++.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mrelax -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.90\gcc\dev\atmega1284p"
Adafruit_GFX.o:(.rodata._ZTV12Adafruit_GFX[vtable for Adafruit_GFX]+0x8): undefined reference to `__cxa_pure_virtual'
Print.o:(.rodata._ZTV5Print[vtable for Print]+0x4): undefined reference to `__cxa_pure_virtual'
collect2.exe(0,0): error: ld returned 1 exit status
make: *** [P10_RGB_Demo_1284p_C++.elf] Error 1
Z:\Creation\Hiren\P10_LED_Display\RGB Atmel Studio\P10_RGB_Demo_1284p_C++\P10_RGB_Demo_1284p_C++\Debug\Makefile(154,1): error: recipe for target 'P10_RGB_Demo_1284p_C++.elf' failed
The command exited with code 2.
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "P10_RGB_Demo_1284p_C++.cppproj" -- FAILED.
Done building project "P10_RGB_Demo_1284p_C++.cppproj" -- FAILED.
Build FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
So you have a number of problems reported there:
But the actual reason for the link failing is here:
Build FAILED.
I'll have to let the C++ experts take that one ...
As an aside, I would suggest that you avoid the use of '+' in file or folder names:
Yes, you are getting away with it at the moment - but probably best to just avoid the issue entirely ...
EDIT
As if to prove the point, this just came up: https://www.avrfreaks.net/commen...
cool
Suggest you read:
All is revealed (and you will want to follow the other guidance given there too!)
Thank You so much clawson it's Work like charm. Thank You so much Everyone who help me.
