Trying To Find A Switch
9 posts / 0 new
I've having a fine time trying to find a switch like this. I need the wider cap version, 17.3mm wide (the one in the picture is 12.4mm) with a red cap and single LED hole.
Ideally on the shelf at a distributors as I only need about 20 of them.
'Rocker switch' and 'keyboard switch' throw up hundreds of wrong search result.
Is a momentary contact, NO switch?
If you could get a better photo, you could try a google image search on it ...
(at the moment, it just thinks it's an "electrical connector")
EDIT
Sometimes putting the item on a scanner can get a good close-up picture.
(depends on the scanner)
Momentary changeover.
awneil wrote:
....you could try a google image search on it ...
I try and avoid Google wherever possible but it looks like it might be known as an 'SP86' switch. Millions of sellers in the Far East, I just need to find someone who will sell me 20 and get them here in less that 60 days.
Mouser lists them but non-stocked, I would call them and see what they can do for you.
107-SP86-B1-1-01-EV for the Red/Red version
Mountain Switch
They stock a white cap/red led version if that would do
107-SP86-B1-4-01-EV
I have bought that switch from Grayhill switches in the past if that helps
At Digikey bring up Pushbutton Switches, then select Keyswitch, Illuminated
Then selecting color Red, All LED colors leaves one in-stock hit.
https://www.digikey.com/products/en?keywords=r%20%09EG17155-ND
Digi-Key Part Number    EG17155-ND
Quantity Available         176 Can ship immediately
Manufacturer                E-Switch
Manufacturer P/N          5501MREDRED
Description                  SWITCH PUSH SPDT 0.3A 12V
Width                         12mm
Price   quantity 10        US$43.72
5501MREDRED E-Switch | EG17155-ND DigiKey Electronics
For 17mm the E-Switch 5511 series, Digikey only stocks White and Black keys with LEDs.
Thanks all. I think I have found a way to do this.... It looks like Mouser have some red caps in stock which I can swap over with the caps on some switches I already have. Now all I need to do is think of another £45 worth of things to buy to get free shipping.
