TICK SOUND COMES WHEN DISABLE TCC MODULE.
4 posts / 0 new
Im playing some frequency between 15K to 20 K via TCC module. Whenever I disable the TCC after playing, the Tick sound comes at last.
I want to get rid of this tick sound..
Kindly help.
A TCC on its own won't make any sound - so please describe how you are creating the sound.
Post your schematic (aka "circuit diagram") - see Tip #1 for instructions.
Please give a fuller description of what this "Tick sound" is ?
Do you have an oscilloscope to see what's happening?
If so, post a screenshot.
Perhaps post a minimal but complete code example which illustrates the issue. Again, see Tip #1 for instructions.
Are you stopping at the zero crossover or mid-waveform?
Tick sound is same as saying tick.
Im generating some sound via speaker through TCC0.
below is the code
void tcc_config_diff(int period)
    struct tcc_config config_tcc;
    tcc_get_config_defaults(&config_tcc,TCC0);
    config_tcc.compare.wave_generation=TCC_WAVE_GENERATION_SINGLE_SLOPE_PWM;
    config_tcc.compare.wave_ramp = TCC_RAMP_RAMP1;
    config_tcc.counter.reload_action=TCC_RELOAD_ACTION_RESYNC;
    config_tcc.counter.clock_source=TCC_PWM_USONIC_CLK;
    config_tcc.counter.clock_prescaler= TCC_CLOCK_PRESCALER_DIV16;
    config_tcc.counter.period=period;
    config_tcc.compare.match[0]=period/2;
    config_tcc.pins.enable_wave_out_pin[TCC_MATCH_CAPTURE_CHANNEL_0]=true;
    config_tcc.pins.wave_out_pin[TCC_MATCH_CAPTURE_CHANNEL_0]=PIN_PA08E_TCC0_WO0;
    config_tcc.pins.wave_out_pin_mux[TCC_MATCH_CAPTURE_CHANNEL_0]=MUX_PA08E_TCC0_WO0;
    tcc_init(&tcc_instance_diff, TCC0, &config_tcc);
    tcc_enable(&tcc_instance_diff);
tcc_config_diff(1000);
    enable_speaker();
for(I=0;i<100;i++)
            period= ((256*i)/10);
            tcc_set_top_value(&tcc_instance_diff,  period);
            tcc_set_compare_value(&tcc_instance_diff, 0, period/2);
             delay_ms(100);
tcc_disable(&&tcc_instance_diff);
disable_speaker();
When I do either tcc_disable or disable speaker the tick sound comes.
Also the frequency I'm generating is not stable and exact.
I want exact frequency with stability.
Kindly help to reach the goal.
Also please look into my DMA thread which is again big issue for me.
