KEYPAD PORT CHANGE.
8 posts / 0 new
Can someone help me change the port of keypad 4x4? I want to shift lower nibble port D pins to port B lower nibble because I have to use serial communication and external interrupts.
////////////////////////	KEYAPD	/////////////////////////////
#define KEY_PRT 	PORTD
#define KEY_DDR		DDRD
#define KEY_PIN		PIND
unsigned char keypad[4][4] = {
	{'A','3','2','1'},
	{'B','6','5','4'},
	{'C','9','8','7'},
	{'D','#','0','*'}};
	unsigned char colloc, rowloc;
	char keyfind()
			KEY_DDR = 0xF0;           /* set port direction as input-output */
			KEY_PRT = 0xFF;
			do
				KEY_PRT &= 0x0F;      /* mask PORT for column read only */
				asm("NOP");
				colloc = (KEY_PIN & 0x0F); /* read status of column */
			}while(colloc != 0x0F);
			do
				do
					_delay_ms(20);             /* 20ms key debounce time */
					}while(colloc == 0x0F);        /* check for any key press */
					_delay_ms (40);	            /* 20 ms key debounce time */
				/* now check for rows */
				KEY_PRT = 0xEF;            /* check for pressed key in 1st row */
				asm("NOP");
				if(colloc != 0x0F)
					rowloc = 0;
					break;
				KEY_PRT = 0xDF;		/* check for pressed key in 2nd row */
				asm("NOP");
				if(colloc != 0x0F)
					rowloc = 1;
					break;
				KEY_PRT = 0xBF;		/* check for pressed key in 3rd row */
				asm("NOP");
				if(colloc != 0x0F)
					rowloc = 2;
					break;
				KEY_PRT = 0x7F;		/* check for pressed key in 4th row */
				asm("NOP");
				if(colloc != 0x0F)
					rowloc = 3;
					break;
			if(colloc == 0x0E)
			return(keypad[rowloc][0]);
			else if(colloc == 0x0D)
			return(keypad[rowloc][1]);
			else if(colloc == 0x0B)
			return(keypad[rowloc][2]);
			return(keypad[rowloc][3]);
I cannot find a new code for the keypad which works.
thanks for help.
Get rid of your Magic Numbers - instead #define symbolic names so that you can easily use arbitrary pins on arbitrary ports!
Thats not my code i just copy paste it
can I change this
by bit manipulation like join both port d and b (D7, D6, D5, D4, B3, B2, B1, B0).
Obviously, if your keypad is not on a single port, you can't just have a single #define for the port - can you?
How general do you want it to be?
In the OP, you just talked about having 4 bits on the lower nibble of one port, and 4 bits on the lower nibble of another port.
Or do you want to make it completely general - so that any bit can be on any pin of any port?
I juat want that col goes to port d upper nibble and rows goes to port b lower nibble . How can i do this ?
Do you understand how the code you copied works?
You could start by just modifying it to use a different complete port.
Then think about how to combine half of one port and half of the other ...
Because of this
and this
It's clear that this existing code is using PD7..PD4 as the outputs and PD3..PD0 as the inputs. If you want to split this you are going to need something like:
#define KEY_DDR_OUT		DDRD
#define KEY_DDR_IN		DDRB
then something like:
        KEY_DDR_OUT = 0x0F;           /* set low 4 bits of D as the outputs */
        KEY_DDR_IN  = 0x?0;           /* set low 4 bits of B as the inputs */
I left ? in second line here as I don't know what you want to do with the upper 4 bits of B ?
In the same way that I have split this you will need to split:
In a similar way - now if it's the case that writes are only ever made to KEY_PRT and reads are only ever made to KEY_PIN then this may be as simple as:
#define KEY_PIN		PINB
but now the output bits are in the lower 4 of D you are going to need to change lines such as:
to be
				KEY_PRT = 0x?E;            /* check for pressed key in 1st row */
Again I used ? because I can't know what you want to do with the 4 high bits now.
