EEPROM ISSUE
5 posts / 0 new
I just started using internal EEPROM. I am trying to write "8051" on 0,1,2,3 location of EEPROM and then read it (turn off and then). so first I write on it by
#include <avr/eeprom.h>
#include "LCD16x2_4bit.h"
#define  F_CPU 1000000UL
#include <util/delay.h>
	uint8_t x;
	LCD_Init();
	LCD_Clear();
	LCD_String("Writing;");
  eeprom_write_byte((uint8_t*)0,'8');
   eeprom_write_byte((uint8_t*)1,'0');
    eeprom_write_byte((uint8_t*)2,'5');
	 eeprom_write_byte((uint8_t*)3,'1');
	 LCD_String_xy(2,0,"writing complete");
	 _delay_ms(500);
	 LCD_Clear();
	 LCD_String("Reading:");
	 x=eeprom_read_byte((uint8_t*)0);
	 LCD_Char(x);
	 x=eeprom_read_byte((uint8_t*)1);
	 LCD_Char(x);
	 x=eeprom_read_byte((uint8_t*)2);
	 LCD_Char(x);
	 x=eeprom_read_byte((uint8_t*)3);
	 LCD_Char(x);
    while (1)
it works fine and I get this
I wrote another program to read bytes again which is
	uint8_t x;
	LCD_Init();
	_delay_ms(500);
	LCD_Clear();
	LCD_Char(x);
	LCD_Char(x);
	LCD_Char(x);
	LCD_Char(x);
	while (1)
and this does not work and I get this
I don't know why is this happening.
EESAVE !!
Means??
He means the EESAVE fuse must be set to prevent EEPROM from being erased when you burn the second program.
So i will make EESAVE 0
