Digital Tachometer (First Project)
28 posts / 0 new
Digital Tachometer First Project in 4 parts: 1 the project, 2 what I have done so far, 4 what I need, 3 who I am.
1. I want to build a digital tachometer using an ATmega328P as per the C program and circuitry in atmel AN8103 as a starting point.
2. I have purchased an Arduino Uno to use as a programmer (would an AVR-ISP-MKII be better?). Read the quick start tutorial on this forum. Read a ton of material on programming chips. Spent most of the week on the Internet. Seemed like a simple project at first, but now getting more complicated.
3. I need advice on development software for a MacBook Pro with a Windows VM. (And some coaching on how to use it!)
4. I was a computer tech, and then a systems analyst, on large scale computers in the ‘80s. Worked as a technical writer in an R&D department where the company developed oil well devices in my last job. I am now retired and make jewelry for a hobby using a Sherline lathe and CNC mill (hence the interest in a tachometer).
Any help would be appreciated.
Bob
Yes though the original Atmel AVRISP2 passed EOL; there's one clone (Waveshare) and several function-likes via Dean's LUFA.
Its replacement is Atmel-ICE.
http://www.microchip.com/developmenttools/ProductDetails/ATATMEL-ICE
A match for the Arduino Uno is Microsoft Visual Studio Code on macOS though that doesn't yet have AVR debugging.
https://www.avrfreaks.net/forum/avr-studio-mac-linux#comment-2440271
Don't see AN8103 anywhere---what is it?
The MKII programmer is not longer avail, but I use it all the time.  Clones are still out there, but often problematic.  It does not have a debugger, but have never needed on anyhow.
You can also look up how to make a frequency counter--similar techniques.
AVR340: Direct Driving of LCD Using General Purpose IO
http://ww1.microchip.com/downloads/en/AppNotes/doc8103.pdf
Actually, making any AVR project has 5 steps.  There is a zero step before the four that have been listed.   That step is to go on eBay and type in the name of your project in the Search box.   A search on "digital tachometer" brings up this listing: https://www.ebay.com/itm/Black-D...
Can you make a digital tachometer as good as this for $9.60??  Including all the parts and shipping, all the coding, all the hours of troubleshooting, all the calibration, all the custom assembly???
It's an honest question.  It is the first question that should be asked before beginning any microcontroller-based project.
Thank you,
Assuming AVR340 is the App Note you are referring to, directly driving the LCD is an unnecessary complication, as there are a multitude of inexpensive LCDs with built-in controllers.
You will want a stable, accurate clock source (either Xtal or external oscillator).
I would have chosen one of the Xplained Mini boards as they are inexpensive (under $10US), they have built-in programmer/debugger, and an Xtal-based clock source is available.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
You're assuming that the object of the exercise is purely to get a tachometer.
You're discounting the possibility that the journey is more important than (or, at least, as important as) the destination ...
+10
Too many questions ruin the fun  :(
These days seems like too much stuff is just a free ship from China.  Only the innovative survive.  Fidget spinners for all.
I have a similar background, pcp-11, vax, alpha VMS, 6800, 6809, z80, 8085,..... Mac's, PC's, Linux, etc.   discovered AVR's about 10 years ago.
Today if I were startiong out, I would start with an ardunio uno + shield(s) for initial sw dev and prototyping, then use an arduino nano or pro-micro for building my own devices.
No additional h/w needed, and builds on PC, Mac, or Linux, take your pick, and a ton of example programs to learn from.  In fact, just about anything you want to build has been done on such devices.
Have fun,
ki0bk wrote:
pcp-11
Be careful with that PCP.  It will rot your brain.  wink
EDIT: typo
Greg Muth
Portland, OR, US
You probably guessed that Simonetta is a stand-in for the local village idiot when they are on vacation. If everyone here followed the advice of "just buy one on ebay" none of us would ever design/implement anything AVR based and Freaks might as well not exist cheeky So ignore nonsense like that and have fun implementing your design idea.
BTW as someone who's done decades of Asm then C then C++ your choice of Asm intrigues me. Is it simply that you like an additional challenge?
Or was it that you thought it would be easier with a standalone Asm on a Mac?
Thank you all very much for your contributions. Everyone, it seems, has a creative and workable approach. Since I am new to this, I'm seeking the simplest approach. That seems to me buying ATMEL-ICE Basic and downloading ATMEL Studio for my Windows VM. Does anyone have any final thoughts?
Bob
Clawson (don't know how to use the quote function, yet)
When I was a computer tech, I programmed in Asm when trying to uncover hardware faults. Asm was the closest to machine language (which I also used). I like it because it's so specific.
There’s many ways to skin a cat.....
Since you have an Arduino board, the installation of the Arduino tools on your Mac gives you an assembler. You can then choose whether to prototype your code in Arduino c/c++ and then move to asm or go straight to asm. Downside - no debug tools. Upside simple installation on the Mac and no extra outlay.
I’m not sure what an atmel ice is worth, but i bet it costs more than a couple low cost dev boards with inbuilt debuggers.
You have too many choices!
Yes, too many choices. I've tried to choose the simpilist. Any further comments.
Would someone "explain" how the Xplain328 mini board might be a simpler (and much cheaper) solution? I.e. Will it program the actual chip that I will be using in my project?
Still undecided!
Look at the schematic!
I’m not sure how well the xplained boards behave with a Mac and virtual machine. Yesterday I was attempting to use a xplained saml21 board with the macbook and win7 on virtualbox. The virtual machine wouldn’t grab the edbg as it kept on wanting to appear as a disk drive on the Mac due to MBED functionality. Yet to try under Parallels to see if it behaves better. I ended up using the Atmel ice.
The debug experience on the AVR is poxy compared to Arm based devices, so my choice would lean towards Arm.
Thanks again for all your help. I've ordered the Xplained board. I'll let you know how it works out. No more questions (about programmers).
Bob
Well, I got my tachometer working. After much thrashing around, I took Jim's advice to heart. I've used my Arduino uno to work out the problems, and I will more than likely use a nano board in the finished project. If I decide to use discrete components, it seems a fairly small step from here to there. Thanks very much to all of you for your generous contributions.
Bob
Excellent!
Now please mark the solution - see Tip #5
I've marked the solution, and tagged the post solved. How do I add solved to the title?
Well you don't really need to. Marking solved made the green tick appear here:
readers know this means "this topic has a solution".
But just for the record the way to change anything in the title of a thread (as sometimes the topic wanders) is simply to go back and edit post #1 and change the text in the Subject box.
But as I say you don't really need "Solved" anyway.
Did you not see EDIT 2 in the linked post?
EDIT
I've now added Cliff's image to that post as an illustration
Great. Thanks.
and it also means that the forum itself knows - which simply adding "solved" to the title doesn't do.
Obviously, for real closure on the Thread, we need to see a photo of the tach and the lathe, and a sample of what your making!
JC,
I wanted an RPM meter that would integrate nicely with my tools, rather than some large, clunky unit available on Amazon or eBay. This is why I'm building my own.
I am doing a PCB layout at the moment, and then will mill a case out of aluminum flat stock. I'll post photos of it all once I am done.
Bob
