Problems reading memory using AtmelStudio
7 posts / 0 new
Hi guys,
I really was surpised  recognizing that my AtmelStudio (V7, avrisp mkii) is not able to read the memory of an ATmega328 correctly...
The original hex-file I wrote started like this:
:100000000C94AB000C94C8000C94C8000C94EC1435
:100010000C94C8000C94C8000C94C8000C94C80040
:100020000C94C8000C94C8000C94C8000C94C41420
:100030000C94C8000C94C8000C94C8000C94C80020
:100040000C94C8000C94C8000C948F230C94C80026
:100050000C94C8000C94C8000C94C8000C94C80000
:100060000C94C8000C94C80007634236B79BD8A70D
:100070001A39685618AEBAAB558C1D3CB7CC5763CD
:10008000BD6DEDFD753EF6177231BF000000803F7B
:1000900008000000BE922449123EABAAAA2ABECD97
And reading the just written file again shows:
:100050000C94C8000C94C8000C94C8000000000068
:100060000000000000000000000000000000000090
:100070000000000000000000000000000000000080
:100080000000000000000000000000000000000070
:100090000000000000000000000000000000000060
The memory seems to be empty, but the chip is working fine.
As well the verifying of the original hex-file after programming has no errors.
Lock bits are all off.
Any idea what I'm doing wrong?
Thanks!
BEXX
So writing the .hex file to the chip changes the file..?  The first file has a larger vector table than the second file.  What did you change?
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Maybe my first post was a bit confusing...
The .hex file made by the compiler is the first one. This one has been written to the flash an verified OK.
The second one is the re-read .hex file from the same chip after successful programming.
I'm wondering, why the re-read one is not equal to one programmed before.
Do you mean you re-read IMMEDIATELY after the initial write/verify operation? Also what tools did you use for the writing/reading? If a command line tool such as avrdude what were the command parameters?
Yes, I've been using Atmel Studio 7 for programming and also the AS7device programming tool for immediate reading.
I've been also trying AvrStudio 4 on a different PC and the reding was Ok there.
Now I did one more try on the next different PC, now writing and re-reading with the AS7device programming tool
shows below the compare result with notepad++:
most of the .hex file seems bo be the same, but not all.
Shouldn't it be exactly the same???
Presumably the reader creates "sparse" hex? Do a hex2bin on each (objcopy is a good way) then use something like vbindiff to compare the bin files, that's ultimately what matters.
Attached you find a screenshot of the difference.
Obviously the size of the two files is no identically and re-reading the chip AS7 additional characters.
Would it cause a problem flashing the re-read file again?
