Split from: Oled lcd 128*64 using I2c protocol interfacing with atmega16
5 posts / 0 new
I am using ATmega16 controller for one of my project and I am using gsm sim800c and GPS my code is working but I want to toggle them that is for power saving purpose I want to switch grounds of my modules from my microcontroller and for this, I was using BC547 transistor but it's not working I had given ground in my code and I was switching them but they are not working.
Please Help,
What does that have to do with your I2C question?
For a separate question, start a separate thread.
Hello, I had now used I2c functions from peter fleury's I2C functions but still, nothing happened. What should I do??
What should I do??
Answer the questions in #2.
Follow the advice in #3 - check the status returns.
Use an oscilloscope or logic analyser to see what's happening on the wires.
Learn to debug your systems: https://www.avrfreaks.net/commen...
BTW it is not wise to switch the grounds to your modules as you will get ‘sneak’ currents through the port pins. Switch the positive voltage.
