which avr developement board to buy
15 posts / 0 new
hello I am planning to start 8 bit programming with avr.
which is the best development board for the beginning.
thanks
Total votes: 2
What is your definition of "best"?
What is your programming/engineering background?
Your location may limit the availability of choices.
What language are you hoping to use? (Assembler, C, C++, Basic, etc)
ps. And welcome to AVRFreaks.
Atmega328p Xplained mini.
Cheap, includes debugger, compatible with Arduino.
As Ross says, "best" is essentially meaningless.
But the most obvious suggestions are:
  1. Arduino.
  2. As already mentioned, an XPlained Pro, Mini or Nano
    See: https://www.avrfreaks.net/commen...
EDIT
Found my previous answer on this topic - with pictures!
#ArduinoXPlained
Total votes: 2
awneil wrote:
An XPlained Pro, Mini or Nano
In this day and age I wouldn't buy any of Atmel's boards that didn't also include a debugger. So if you choose an Atmel board over Arduino verify that it is also one with a debugger too.
Absolutely agree!
yes
(and not just Atmel/Microchip)
To be clear, the XPlained Pro, Mini and Nano are the ones with the built-in debugger.
awneil wrote:
Absolutely agree!
yes
Pardon my ignorance:
What is built in to the XPlained boards that you are calling a debugger?
My previous development board was an STK500.
Nothing.  The Xplained Pro boards have an EDBG (Embedded Debugger) that can program and debug code.  It also includes a CDC/COM port and the DGI (Data Gateway Interface) for capturing TWI, SPI and USART traffic.  The Xplained Mini boards have an mEDBG (mini Embedded Debugger) that can program and debug code.  It only has the CDC/COM; no DGI.
The Xplained boards have no such capabilities, although the ones that have a separate UC3B Board Controller do provide the CDC/COM.
edit: typos.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
+1.  yes
Greg Muth
Portland, OR, US
It wasn't clear to me.
Xplained Pro: EDBG (UC32) debugger
Xplained Mini, Xplained Nano: mEDBG (32u4) debugger
Xplained: no debugger.  (I had been unaware of suffix-less Xplained boards.  I guess they pre-date the newer boards.  The "MEGA-1284P Xplained" is particularly annoying.)
Two weeks since the OP asked his question. Maybe he has found a new hobby over on knitters 'r' us...
Correct.
Yes, they do.
They also have a different "standard" for the IO header connectors.
Indeed.
But this does come up frequently - hopefully the distinctions have now been fully spelled out in detail to avoid any future confusion ... ?
#XplainedProMiniNano
Pro? Mini? Nano? None? Doesn't seem the crazy naming scheme was Xplained all that clearly  crying
Atmel's ICE development tools...called Atmel ICE...creative!
The point is that wether it's Xplained, Xplained Pro, Xplained Mini or Xplained something else forget the name. Just ask yourself "is it a chip I'm interested in developing with?" and "does the description include the word 'debugger'?". Buy anything where both answers are "yes".
Or, at least, a close relative of one you're interested in developing with.
Obviously, manufacturers can't produce dev boards for every single variant of every single chip that they make - so they will tend to choose one that's "representative" of a whole family.
Typically, they will tend to choose the "biggest" member of the family - to cover the widest number of possible users.
If you're interested in a "smaller" member of the family, then just bear its restrictions in mind as you use the dev board ...
EDT
* can't
