Switch /case with pointer to structure
8 posts / 0 new
Hi guys,
I have defined a global struct for my ADC values (ATMEGA328)  like
	struct ADCint
		uint8_t ADC_No;
		uint16_t ADC_Value ;
		uint16_t ADC_VoltX100;
	extern struct ADCint ADC_1, ADC_2, ADC_3, ADC_4, ADC_5, ADC_6, ADC_7;
In the function  I want to access on of the structure variables (ADC_1,  ADC_2, ...) depending on the ADC_No passed to the function, like this:
void ADC_VrefInt(uint8_t ADC_No)  // writes values to the desired ADCint structure
    // struct ADCint *ADCvaluesPTR = &ADC_6;  //-> this alone works fine
    struct ADCint ADCvaluesPTR;
    switch(ADC_No)
        case 1: *ADCvaluesPTR = &ADC_1; break;  //-> this doesn't work
        case 2: *ADCvaluesPTR = &ADC_2; break;
        case 3: *ADCvaluesPTR = &ADC_3; break;
        case 4: *ADCvaluesPTR = &ADC_4; break;
        case 5: *ADCvaluesPTR = &ADC_5; break;
        case 6: *ADCvaluesPTR = &ADC_6; break;
        case 7: *ADCvaluesPTR = &ADC_7; break;
    // Read ADC
    // 	        7 bit 	6 bit 	5 bit 	4 bit 	3 bit 	2 bit 	1 bit 	0 bit
    //  ADMUX	REFS1	REFS0 	ADLAR 	- 	     MUX3 	MUX2 	MUX1 	MUX0
    ADMUX = ADCvaluesPTR->ADC_No;         // reading the desired ADC channel
    //.... and so on
Using for example
works fine.
But the use with switch /case does always process errors.
Any help would appreciated, maybe how to solve this more elegant, selecting structur variables depending on numbers.
Many thanks!
BEXX
Total votes: 3
Umm why not an array of struct? Whenever you start naming objects var1, var2, var3 it's just crying out for var[n]. Obviously your channel number becomes your array index. In which case you can drop all the switch() stuff.
Yes, you are right! Thanks!
This would be the easiest way and i will do that!
But just to learn something, can you tell me, what I did wrong in the switch statement above?
The reason that this works...
is becuase ADCvaluesPTR is of type struct ADCint *.
This doesn't work because now ADCvaluesPTR is of type struct ADCint - note not a pointer to struct ADCint, but also because of the asterix used in the assignment. So the simple fix is to put an asterix between the variable name and type in the declaration, and to remove the asterix from the assigning statement.
struct ADCint *ADCvaluesPTR;
Yup, declare a pointer then do pointer assignment.  It looks like this:
    struct ADCint *ADCvaluesPTR;    // declares the pointer
    switch(ADC_No)
        case 1: ADCvaluesPTR = &ADC_1; break;  // assigns the pointer
        case 2: ADCvaluesPTR = &ADC_2; break;
        case 3: ADCvaluesPTR = &ADC_3; break;
        case 4: ADCvaluesPTR = &ADC_4; break;
        case 5: ADCvaluesPTR = &ADC_5; break;
        case 6: ADCvaluesPTR = &ADC_6; break;
        case 7: ADCvaluesPTR = &ADC_7; break;
    // Read ADC
    //.... and so on
In C the struct syntax becomes clearer if you typedef them so the only place "struct" then appears is during the typedef. And only use struct tags if you need self reference.
The code in #1 would then become:
	typedef struct
		uint8_t ADC_No;
	} ADCint;
	extern ADCint ADC_1, ADC_2, ADC_3, ADC_4, ADC_5, ADC_6, ADC_7;
    // ADCint *ADCvaluesPTR = &ADC_6;  //-> this alone works fine
    switch(ADC_No)
    // Read ADC
As this "cleans up" the syntax then the missing '*' becomes more obvious.
As explained in #2, an array of struct is the way to go. But regarding your question:
The reason this works:
and this doesn't:
is because the first "*" is different from the 2nd "*". The first one is part of the declaration, it means the variable being declared is a pointer type. In the second case, the "*" is a derreference operator, it means the value will not go to ADCvaluesPTR, as you intend, but instead to the address pointed to by ADCvaluesPTR (that is, the starting address of the structure). The variable types will not match, so the compiler will give an error, or at least a warning.
...many thanks for the detailed explanation!
Really great community! ;-)
