avrdude reads 261930==0x3ff2a of 0x40000==262144 bytes
11 posts / 0 new
Here is the command line:
​avrdude -p m2560 -c atmelice -P usb \
        -U flash:r:flash.bin:r -U flash:r:flash.hex:i
with results:
$ grep -vn ':20' flash.hex
2049::020000040001F9
4098::020000040002F8
6147::020000040003F7
8189::0AFF200000000000000000000000D7
8190::00000001FF
/c/Users/hennebry/Documents/projects/msi-lava-pc-util
$ ls -l flash.bin
-rw-r--r-- 1 hennebry Administrators 261930 Jun 15 14:29 flash.bin
Line 8189 suggests that avrdude only downloaded the first 0x3ff2a bytes.
What is going on?
Why not use obcopy to convert the .hex back to .bin and it'll show exactly how many bytes were read. Or perhaps even easier, run avr-size on the .hex
I can read the hex. It corresponds to the binary: (8190-5)*32+10=261930 bytes.
The last byte shown is at 0x3FF29.
My problem is not that I do know how many byte avrdude read.
My problem is that the number makes no sense.
Why read 0x3FF2a out of 0x40000?
What do I do about it?
I need the rest of those bytes.
AS7 with a dragon got me all the bytes.
Could not get AS7 to notice the atmelice.
-rw-r--r-- 1 hennebry Administrators 262144 Jun 17 16:17 wtf.bin
$ cmp fl*.bin wtf.bin
cmp: EOF on flash.bin
Still do not know the problem with avrdude and atmelice.
The rest of the bytes turned out to be 0xFF's.
My suspicion is that avrdude quietly does not save trailing 0xFF's.
Do not know for sure.
The poke at it and see what it does method is a real pain.
I'm pretty sure it says that for definite somewhere. Either in the manual, the release notes or the source.
The documentation does not even specify any correlation between what is read and what is written.
https://www.nongnu.org/avrdude/u... wrote:
The op field specifies what operation to perform:
r
read the specified device memory and write to the specified file
Had I been hunting through the source instead of for a workaround,
I might still be at it.
$ man avrdude
           -U memtype:op:filename[:format]
                   Perform a memory operation as indicated.  The memtype field
                   specifies the memory type to operate on.  The available
                   memory types are device-dependent, the actual configuration
                   can be viewed with the part command in terminal mode.  Typ‐
                   ically, a device's memory configuration at least contains
                   the memory types flash and eeprom.  All memory types cur‐
                   rently known are:
                   r        read device memory and write to the specified file
                   When reading any kind of flash memory area (including the
                   various sub-areas in Xmega devices), the resulting output
                   file will be truncated to not contain trailing 0xFF bytes
                   which indicate unprogrammed (erased) memory.  Thus, if the
                   entire memory is unprogrammed, this will result in an out‐
                   put file that has no contents at all.
Thanks.
Hadn't even known avrdude had a man page.
Not just man page but it's been in the manual since this:
http://svn.savannah.gnu.org/view...
(April 2015)
Complete details of change:
(interesting that the text has to be entered in two places - suggests the "man" generation is separate from the "pdf" generation)
I did search.  All I found was what I quoted or similar.
