Atmel ICE error 4109 on Arduino ZERO and custom board
7 posts / 0 new
i finished project on Arduino Zero and now i made custom pcb. I COPIED the circuit from the Arduino Zero datasheet and diagrams, but now when i connect the Atmel ICE i get error 4109(in attached picture). I also get same error when i try to connect to SWD on Arduino Zero board, so what could be the problem? When i try to connenct to a SAMB11 Xplained board, all works perfectly.
All the pictures and diagrams are in attached pictures.
P.S. I noticed that i switched SWDCLK and SWDIO pins on CUSTOM pcb connector header, but i fixed that by making an flat cable that switches pins 2 and 4.
CUSTOM PCB:
PCB from official Arduino Zero files:
Error message in Atmel studio:
As Atmel have chosen to place the "Arduino" forum within the "AVR Freaks" section (presumably on the basis that a lot of the early Arduini were AVR based) I do worry about how many SAM using "eyeballs" you are going to get here - this is really more about SAM electronics than it is about Arduino. Should I move this to a Cortex M forum perhaps?
Yes please.
No pullup on reset?
Ok i fixed it, as usually it was problem whit conenctors. The SWD flat cable IDC conenctors were badly crimped, so after i crimped one myself, connencted it, now all works liek a charm :D
Note that ready-made  ribbon cables are widely available; eg,
http://uk.farnell.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=44&urlRequestType=Base&partNumber=2308531&storeId=10151
EDIT
Ah - missed the PS to the OP
thanksThanks :D
