avrdude returns 53
18 posts / 0 new
avrdude returns 53 and does nothing else, no complaints, no other output, nada.
What is going on?
What does return code 53 mean?
I've searching the source for 53,
but no enlightenment.
BTW the command line is:
$ ls -l "$(which avrdude)"
-rwxr-xr-x 1 hennebry Administrators 465422 Jan 24 17:31 /c/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avrdude.exe
/c/Users/hennebry/Documents/projects/msi-lava-pc-util
$ avrdude -p m2560 -c atmelice -P usb -U flash:r:flash.bin:r -U flash:r:flash.
hex:i
$ echo $?
53
It's from an MSYS terminal on Windows 10.
A powershell also returns 53.
Another edit:
Just did a reboot.
No go.
No change if I disconnect the atmel ice.
Hey!
I have the same issue with avrdude.
I think it has to do with the recent Windows 10 Update. Are you on Windows 10 as well?
Greetings Phil
I just did a stupid.
Since avrdude was part of the AS7 toolchain,
I tried "repairing" AS7.
Naturally, it 'repaired" the usb driver
so the avrdude could not use it even on a  good day.
I do not remember the incantations I needed for avrdude and usb.
If there is a FAQ, a sticky or a FM somewhere, I've not found it.
I am getting an error message now:
avrdude.exe: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2141
Edit: AS7 can see and use the atmel ice.
Wasn't that stupid as it helped us to understand the issue :)
So do you think that the update maybe "repaired" some USB drivers?
I'm using a Arduino nano counterfeit with a CH340 chip on it. Maybe windows overwrote that driver...
The interesting part is that you don't have to program to see an issue in avrdude: I'm using eclipse with avr plug in. I'm not able to open the avr dude preferences inside eclipse. I think the issue is that it somehow parses the output of avrdude and can not display it. Because there is no output...
It was stupid.
avrdude won't use any USB driver tolerated by AS.
Windows, AS, avrdude, USB.
It's going to be a long struggle
at the end of which, I still will
not know what error 53 is.
Atmel-ICE is a composite USB device (USB HID, DGI)
fyi, USB HID is a part of the forthcoming AVRDUDE 6.4 :
http://svn.savannah.gnu.org/viewvc/avrdude/trunk/avrdude/NEWS?revision=1425&view=markup
(lines 8 thru 14)
is there a libusb filter for USB HID devices?
Edits : typo, question
I thought jungo wasn't used anymore.
Also, how does one tell one USB thing name libusb from another?
Jungo superseded by WinUSB in Atmel Studio 7.0.1416 and subsequent.
AVRDUDE is via libusb; AVRDUDE 6.4 is optional via libhidapi.
No answer for the question.
by USB VID and PID
via https://www.avrfreaks.net/forum/atmel-ice-avrdude-cannot-find-device#comment-1740521
I'd not meant physical objects.
I meant all the things named libusb that one can download and install.
I found a solution to my problem with avrdude:
I had to disable the Windows 10 Driver Signature Force. (Don´t know how its called in english)
Do a F8 boot and then press "7".
After that I had to reinstall libusb0.dll
I used this installer for it: https://sourceforge.net/projects...
Hope that helps you as well!
Greetings Phil
Well done!
from where?
Reason :
Zadig - USB driver installation made easy
http://zadig.akeo.ie/
The executable is digitally signed and the signature should state: "Akeo Consulting"
I downloaded and extracted,
but the readme's leave me not knowing what to do next.
1. Disable the signed driver force thing from Windows
2. open the inf-wizard.exe in bin folder
3. follow instructions, select a usb device you want to override the libusb0 driver with.
4. select any location where to save the installer
5. go to that location and open x86 or x64 installer
6. install
7. reboot
I wrote that from my head, so I hope i forgot nothing :)
Greetings Phil
I can use avrdude now, though I still do not know what 53 means.
Other issues in another thread.
I notice exitrc is an uninitialized local in main() yet main_exit does "return exitrc;" so there's plenty of potential for a return without it being set.
