"Failed to enable DW" error message : trying to program Arduino UNO with Atmel ICE
9 posts / 0 new
Hi All,
I'm trying to get a simple LED blink program running on an Arduino UNO from Atmel Studio 7 on Windows 10.  I have the 6 pin ISP connector from the ICE connected to the UNO board, have it powered on, and have the ICE selected as the programmer tool in the IDE.  I have the interface selected as "debugWire" (other choice was ISP).  When I hit the "Start Debugging and Break" menu option I first see the dialog asking to use SPI to enable the DWEN fuse.  I select yes to this.  I then get the "Failed to enable DW" error message as shown in the screenshot.
Can anyone advise what is going wrong?
Thank you,
FW.
Have you made the hardware mod to the Arduino so debugWire can be used?
No.  What mod. is required?
Ever heard of Google? But the bottom line is dW needs NOTHING connected to _Reset. The board should have a solder bridge you can break to ensure this.
Actually google brought me back to here... https://www.avrfreaks.net/forum/arduino-uno-and-avr-70-ice-debugging-possible
Thanks.  Once I de-solder this bridge, will I still be able to program the board via the Arduino IDE, or will it be ICE only from that point?
Edit above.
OK, got it working.  As advised, I had to de-solder the bridge labelled "REST ON" on my Uno.  For other readers this is the red boxed area in the pic. below.
I think youll find that is "RST EN" (reset enable)
With solder bridge on, == Arduino bootloader program loading only
With solder bridge off, == ISB programmer only + debugWire debugging
Note: once you have loaded a program via the ISP, the bootloader will be overwritten, to restore Arduino bootloader operation, you must burn bootloader using ISP, THEN add the solder bridge!
