Fixing transistor tester (was A short story)
35 posts / 0 new
A quick introduction, I'm retired Master Auto Tech 65 yr.'s old and just stumbled intro Arduino. Always been interested in electrical & mechanical things. any way I saw this guy Dave at ( EEVBlog ) explaining OP-Amps and I was blown away I bought an analog and digital scope an assortment of electrical parts and an Arduino UNO, bread boards, and an assortment of sensors and things to play with. Enough, The reason I asked you here is. I bought 2 Transistor checkers ( http://www.instructables.com/id/... )
I did nothing but light up the display the 2nd worked I swapped out the atmel chip and it worked so I thought I would re program it I bought a ARV programmer ( http://www.jyetech.com/Products/... )  It says to  Change the board into USB-UART converter
The board can be easily changed into an USB-UART converter by following steps below.
1. Add the resistor R8 (simply short it if you don’t have a 0 ohm resistor handy)
2. Flash the MCU with AVR-CDC firmware (available at http://www.recursion.jp/avrcdc/ or
www.jyetech.com ). when I plug it programmer into my PC Windows 10 it does not see it, it sees the Arduino I tried a couple of avrcdc files but nothing I'm wondering if I need to remove the resistor first  at this point I'm lost!
I almost didn't post this, I read the tutorial about posting on this site and it sounds like I was being made to feel inferior to the GODS.
Look I'm old and tired, all of this has happened inn the last 2 months and I have been doing nothing but reading for days at a time. if someone could help my or point me in the right direction I would be grateful.
understanding op-amps, Mosfet, diodes, voltage dividers, and trying not to be confused over weather at the moment it's flowing from + to -  or need to relies it's - to +   I'm looking at.
I'M TIRED  thanks for the time. Mick
Mick
Join the club junior..... laugh many of us here are older than you, but is 65 OLD? Nah.
Unfortunately I'm not an Arduino fluent person but welcome to AVRFreaks, someone will pop up with some answer.
Mick B wrote:
I did nothing but light up the display the 2nd worked I swapped out the atmel chip and it worked so I thought I would re program it I bought a ARV programmer ( http://www.jyetech.com/Products/... )  It says to  Change the board into USB-UART converter The board can be easily changed into an USB-UART converter by following steps below.
Why do you want to change the board into a usb->serial converter?
From what I can figure, you need R7 and R8 fitted for the recursion.jp code
Personally, I'd just buy a real usb->serial board and avoid the hassle of this crappy work-around. It's a bit like fixing a leaky exhaust with coke cans and fencing wire - sure it works, but it's not what you'd call a clean solution.
What is the price aof the board?
What is the price of a USB<->UART converter?
Well, OP is annoyed because he has lots to read. AVR datasheet are 300-400 pages (with diagrams); ARMs datasheets are 700-1000 pages (I am afraid there are no limits; perhaps they will become written in Cantonese).
But datasheets are structured enough that one only reads chapters one is interested in, Avrs last long enough -it is unpleasant to find a nice circuit, and know MCU is no longer manufactured/distributed).
Arduino has very nice help, with examples.
Avrfreaks -forgot the adress- has very nice tutorials, for many topics.
Gammon http://www.gammon.com.au/forum/b... was very useful for me
4 years ago, a man buying an Arduino in Paris complained Arduino doc was mainly English; I bet this trouble does not occur in Florida.
This was before Hackable Magazine, a French journal, existed : main topics are Arduino and RPi (but this month, had a Z80 working: RAM was emulated by an Arduino, and it has a huge heap of Dupond wires). Author/Editor described, in the 10 first issues, each and every programming & data structure (variables, loops, arrays, functions, (arrays of) function pointers ....  except circular buffers) one found/should find in Arduino programs.
Maybe there is a review like this in the States.
Economical advantages of reading documentation: the time spent is not spent in buying... one can get some ideas of how to buy, what one needs (Arduini and avr component toaesters are gems, and OP choices seem often very wise)
Technical advantages :one codes less, making less bugs.
I don't think one of these will break the bank:  https://www.ebay.com/p/Cp2102-US...
Sorry but what tutorial are you referring to? We most definitely don't want to give that impression - in fact the opposite so I will change anything that appears to be condescending. Folks here are just present to try and help out other AVR users with their own shared experience.
Moderator
Which would have been unfortunate if you had not as your first thread is better than many we get around here.
+1
As John has already mentioned, the Arduino is a great place to start.  You can get knock off Unos and Megas from ebay for next to nothing and they have a HUGE variety of add-on shields with example code for you you experiment with.
Post your questions without pause, or hesitation, and welcome to the Freak Show! laughcheeky
Edit:  I should have read the OP a little better.
That Programmer you are using is an ISP programmer...albeit an odd duck, but they do provide a user manual for it at least.  All you would need to do to program your device in circuit(provided it has the pins on the target) is to connect one of the headers from the programmer to the target,   You do not need to change the board to a USB/Uart converter for programming.
Why is there a "Highway to Hell" and only a "Stairway to Heaven"? A prediction of the expected traffic load?  - Lee "theusch"
I'm afraid I don't understand the current goal.
Did only one of the little Transistor Checker boards work, and you are trying to debug the other one, or are you just tinkering with the board, and attempting to make it do something different?
One can program the micro with ISP, (In System Programming), which requires specific connections from the AVR programmer to certain pins on the micro.
If the micro has a "Bootloader" program already loaded in the micro, using a programmer, then one can load a program using a USB to Serial bridge, (if the Bootloader is set up that way).
It doesn't appear from the schematic that the board has an ISP programming header, which is unfortunate, as that would make programming the micro/board easy.
If the board has a Serial Bootloader, then as mentioned above it is certainly easier to just purchase a small USB-to-Serial breakout board, (eBay, Ada Fruit, Spark Fun Electronics, BangGood Electronics, etc.)
Hand Hang in there and you will soon be converted from a Master Mechanic to a Micro Guro Guru.
Hello mate I believe it was in the "introduction how to ask a question something something" I just cant remember the smart way maybe. Anyway I might have just been overly sensitive, I was very tired
Thanks Mick
Mick
"Read a lot.  Write a lot."
Hi there, Ya one of the atmaga 328P-PU. IC's on the 2 Transistor testers was toast, I have the .HEX and .EEP files & avrdude I was hoping go through that ISP to the UNO board to reprogram it. The directions I had for that failed. I also now have a brand new 328P-PU. What board would you recommend to make this process as painless as possible, if necessary I have breadboards and jumper wires. I want to learn this process as I go. I'm also trying to cram all of the electrical parts how they work in relation to each other. so much to learn so little time. WOO HOO! my LM358 & UA741 op-amps  and NE555 timers arrived today!
Thanks Mick
Mick
Yep that's them. Great quote.
Mick
Thank you very much , I'm feeling younger today!
Mick
OK but I'm still not getting this - of the two threads that Joey linked in #10 which is the one that appears condescending? The first one (and the second one too in fact) links to a an offsite article that we have no control over ( http://www.catb.org/~esr/faqs/sm... ). As the opening paragraph there states:
Many project websites link to this document in their sections on how to get help. That's fine, it's the use we intended
But on the whole that article contains the received wisdom of several people who have seen how beginners fail to compose sensible questions (usually a woeful lack of detail - something of which you can never have too much).
As for the second - I know it's a bit out of date and some of the links may now be dead but other than that I can't see anything that gives the impression
So is it the external catb.org article you were offended by?
First, I want to congratulate you for the choice of your hardware (analog circuits to teach you electronics, broadbeards, arduino and component tester). I understood there was an issue with component tester; those circuits are nice gems. At the beginning, they were meant for mega48, and functionalities -do not check only transistors, but inductances, capacitors and imperfect components; generate functions- , displays (graphical ones)  were added : still work with 48, but can work with 328 or greater (2560).
Issue I see  fear (without being able to verify it) a bootloader (Arduino adds it to 328) eat ... a "little" flash, and that, sometimes, they added enough functionalities to make a lot of users happy and ... to almost fill MCU flash (else, if it was not full, users would be ... less happy).
Maybe your idea of taking a new MCU, plugging it into an Arduino board and programming the component tester (it first installs boatladder, IIRC) does not work because of this trivial  issue. Without further knowledge of the details of your component tester (has a huge lot of options telepathy cannot guess -knowing who sold it might be enough if one has time or a priori knowledge/experience - ), I am aware this remains pure speculation.
BTW: I only  once bought such a gem, as I prefered using presoldered modules -already checked, I hope- . The only one I bought is likely to be gorgeous, once I manage to solder 1.25mm spaced pins for the graphical display (you have a LCD display, which seems ... wiser, and give ideas about the number of versions) ... but my old eyes cannot see where to solder, even with a magnifier.
dbrion0606 wrote:
broadbeards
I like that mistake Denis...
I found this intro to electronics a few years back, hope you find it helpful.
https://github.com/billcollis/te...
Also some good introductory stuff here: https://electronicsclub.info/
Well, I do not understand OP goal :
a) does he want to fix his Transistor Tester? (that would need further information to be of some help)
b) was he traumatized by tutorials on the right way to post?
c) did he need electronic courses (with the help of  wikipedia, seing his hardware choices, it is unlikely : bombing him with IT links to courses is weird, as he wrote he does not like reading)
Thanks Mick
I hope not to muddy the suggestions you have already received but I learned a lot from the Protostack site at https://protostack.com.au.  Protostack has a selection of microcontroller development boards at https://protostack.com.au/product-category/boards/microcontroller-boards/ , a programmer at  https://protostack.com.au/shop/accessories/usbasp-avr-programmer/ and tutorials at https://protostack.com.au/tutorials/ .  I hope you also find this site useful.
Alan
For the price of one of those bare boards, you could get a fully-assembled XPlained board complete with debugger/programmer!
Well, if instead of pasting and cutting seller sites (one can give thousands of pages of Arduino clones links , just mechanically google searching : advantages of Arduini are   some logical link with ... topic) which are redundant with what OP already has (no need to buy other things : he was wise enough to buy useful boards),  someone could guess what OP wants?
If he wants something, that might be useful.
It took a long time to find this again, I was looking for help on how to post, not etiquette but never the less I was linked to this and it just kind of put me off. I got their and back from here and associated that with this and here we are, Its all good. Moving on. P.S. I did not stop reading after the interdiction lots of good stuff their, way to much to remember but I will try not to step on any toe's Thanks Mick.
Mick
It'd help if you make the title of your thread descriptive of the content.
"A short story" tells us nothing - in fact, I keep seeing it and thinking it's one of Ross's jokes ...
I must agree with awneil :
a) is it (trying ) to fix a nice transistor checker? As it has a lot of versions -at least 4 processor versions, can test a lot of components) , knwowing where it was bought (an IT link may be enough) can help people in understanding what can be done, if something can be done (there are no deities her, or lazy ones, unable to use telepathy) . This would be consistent with the section you posted in.
b) is it forum management?
c) Is it extra documentation in electronics/ avrs -avrfreaks has a lot of tutorials- (but you wrote you did not like reading that much)
Hello, And thank you, and to all the contributors for taking interest in my plight.
A) why yes I do want to fix the transistor tester Its going to be a gift.  https://www.mikrocontroller.net/... This is and has links to all there is to know about the tester.
B) No trauma here..... well just a little.
C) Its not that I don't like reading, Its just that I have been doing nothing but reading for about 3 months now every day for hours sometimes as long as 12 hrs. at a stretch. It started with DAVE at EEV. the problem goes, I understood the concept of an OP-AMP cool. But then he started on comparators', inverting non, inverting, and into feed-back, voltage dividers. not knowing about such things I looked them up and you know how the net is you start reading about one thing like resistors and the next thing you know your reading about the molecular structure of carbon. I'm finding it hard to pinpoint in my mind what I'm looking for other than just the knowledge. I bought a bunch of test gear and misc. electrical components to experiment with, the Arduino was to come a little later, I don't know how or if my memory is going to like learning a new program language. I was getting in "edlin and basic" back in the day (Commodore 64) I also had a Franklin that was an Apple II clone. But that was a life time ago. I would like to slow down on the reading and play with some of the stuff I bought. you know how it goes?
I want it for free and I want it yesterday. Really trying to get away from instant gratification thing in my old age.
D) Without getting lost in everything their is to know about Arduino, AVR, and a transistor tester along with everything I'm trying to learn. I was hoping to take advantage of someone else's studies to guide me into reprograming that Atmel 328P so I can go back to being lost in my madness.
There were some great links shared with me going to look at them all eventually. Perhaps I'll find a way to a more disciplined form of education between what I know and what I want/need to know.
Thanks for your understanding or trying to. Mick
Mick
What do you think I should call it?
Mick
As dbrion0606,  I have no idea what it's about - so no idea what to call it!
As you can see I changed the title.
I bought this on eBay  https://www.ebay.com/itm/Mega328...
and it needs a new 328-P chip I have the new chip and the hex and eep files avrdude and this code
 avrdude -F -c usbasp -p m328p -B 12.0 -e -U flash:w:"TransistorTester.hex":i -U eeprom:w:"TransistorTester.eep":i -U lfuse:w:0xF7:m -U hfuse:w:0xD9:m -U efuse:w:0x04:m
This guy reprogramed got it all to work https://www.youtube.com/watch?v=...
I need a board that I can use like he had or one that can do what he did. Now Thanks to dbrion0606    I wonder if there is going to be an issue with the bootloader and this new chip?
If anyone knows how I can reprogram this new chip or needs to see the HEX or EEP files or more information I hope to be able to supply it. I'm so close yet so far away.
Thanks Mick
Mick
I thought I changed the title but it still looks the same. How do I change the title?
Mick
You need to Edit the first post, change the title and then click on post.
If you have any problems let me know the new title and I'll change it for you.
There's a lot of bad advice out there, and it can be hard to tell it from the the good advice when you come across it.  Case in point: >>NEVER<< use -F.  It causes avrdude to ignore communications failures and attempt to program the chip anyway.  The possible result is that you'll 'brick' the AVR.
There isn't likely a bootloader involved at all, since the video you show and the avrdude command you posted uses an ISP programmer known as usbasp, not a bootloader.
You mention that you bought a compatible programmer, but then you went on to say that you 'changed it into a USB-UART converter'.  That's not likely what you want to do, unless there's a pre-existing bootloader involved, which it sounds like there isn't.
The good news is that it seems you've got an arduino already?  There's an example sketch that ships with the Arduino IDE which turns an Arduino into an ISP programmer, so you could use that to program your factory-fresh 328p with the tester's firmware.
Start by itemising the list of tools and gadgets you have available to you, and hopefully someone will put together a procedure for you (think Apollo 13: "we have to make this... [holds up square canister]... fit into the hole for this... [holds up round canister]... using nothing but that... [points to rubbish pile]...")
How many 328p's do you have to try with (in case you brick one...)?
edited: this is a reply to  26
A : links you give are TransistorTester historisher Channel; in 2009, when I herad about it, it was a very nice gem. It remains a venerable gem, but things evolve : 4 processors can support it (the link gives mega48 and mega 8; your tester has mega328 and I do not remember wether there is binary compatibility; if there is a Xal, a link to a PC can be added; extra components -resistors, condensators- can  be tested; extra fuctionalities -Velleman's has a tone generator -software NE555...-). I bet dozens of options exist to day.... edited the youtube link has a nokia graphical display, messeems; historical chanel uses character LCD, way more popular.
Maybe a photo of both sides of the damaged tester would help in finding out if there is a quartz/resonator -Arduini **need a quartz/reesonator**, if it is easy to solder one.
If your LCD can be unplugged, Arduino+bread board can help finding whether LCD is still working (without photos, I am obliged to explain in great detail and poor english how one might try to fix it -or salvage valuable parts- ).
It might be interesting to know how it was fried (a friend of mine fried Velleman very expensive  clone, trying to measure capacitor values without discharging capacitor; as main value is 230v in France , >=310v peak, and it was a main filtering capacitor, clone tester died (there is no protection; ) .
B :never read about etiquette (as I go there to learn from other people errors -and try to fix them, if I feel I can - , following Confucius idea : " a wise man learns from his errors, a wiser from other people errors", I know I can get wiser if I go to ME dedicated fora (more errors)  -unless Confucius was wrong...
C and D : from what I read about your choice of hardware, you are very rational and choices were very good for self teaching. I can advise books that work for me (wikipedia is likely to give interetsing starting points), but I know I cannot go further without asking many questions and making bets
Note I have edited the subject in#1 (and hence thread title) - don't know if it's still an appropriate description of the subject but it has to be better than it was! If still wrong just edit #1 and change the text in the "subject" box
I have  to put this on hold for a little while. I will get back to it.  Thanks for your time and suggestions. Mick
Mick
