Where's the precompiler output?
4 posts / 0 new
I'm currently developing a program for the ATTiny 104 through Atmel Studio 7.  I was wondering where Atmel Studio 7 is storing the output of the precompiler.  I looked into all generated files in the Debug directory of the project, but none of them contained the precompiled output.
Anyone any idea?
Best,
--Geert
By default they are created under %TEMP% and deleted at the end of the compilation. If you want to see them to check pre-pro macro expansion etc then add -save-temps to the compiler command line (think AS7 has a tick box for this) then they are created in the same directory as the source files and so are the asm sources. Pre-pro files have .i extensions and asm has .s
That is really great!  It took me a while to find indeed the option in AS7, but for those also interested, here it is:
  • Select your project within the solution (if the solution would contain more than one project) and right-click (or select Project in the menu bar)
  • Select Properties
  • Select the tab Toolchain
  • Select AVR/GNU C and/or C++ compiler
  • Select Miscellaneous
  • Check the option Do not delete temporary files (-save-temps)
  • Close the tab
That's it, enjoy!
Best.
You may also find this useful for the .s files
https://spaces.microchip.com/gf/project/avr-source/
(/end shameless self promotion)
