error: Id returned 1exit status, recipe for target *.elf failed
7 posts / 0 new
I Have C++ code that compiles for UC3 but does not compile for megaAVR I get the following errors:
error: recipe for target *.elf failed
Anyone know what they mean? or able to help with where to look?
If you got to the Linker stage (ld) the individual C++ files must have compiled to object (.o) successfully.
Copy-paste from the Output window.
You have either omitted a file or you have two files with the same definition.
Or more likely, you have used too much SRAM or Flash.
------ Build started: Project: Atmega, Configuration: Debug AVR ------
Build started.
Project "Atmega.cppproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "K:\Projects\WebServer\WebServer15\Atmega\Atmega.cppproj" (target "Build" depends on it):
 Task "RunCompilerTask"
  Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
  C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 8 --output-sync
  Building target: Atmega.elf
  Invoking: AVR8/GNU Linker : 5.4.0
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x1c): undefined reference to `__cxa_pure_virtual'
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x1e): undefined reference to `__cxa_pure_virtual'
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x20): undefined reference to `__cxa_pure_virtual'
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x22): undefined reference to `__cxa_pure_virtual'
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x24): undefined reference to `__cxa_pure_virtual'
  Atmega/src/CSF/enc28j60.o:(.rodata._ZTC10enc28j60_t694_6http_t[vtable for enc28j60_t]+0x26): more undefined references to `__cxa_pure_virtual' follow
collect2.exe(0,0): error: ld returned 1 exit status
  make: *** [Atmega.elf] Error 1
  "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -o Atmega.elf  Atmega/src/CSF/arp.o Atmega/src/CSF/dhcp.o Atmega/src/CSF/dns.o Atmega/src/CSF/enc28j60.o Atmega/src/CSF/http.o Atmega/src/CSF/icmp.o Atmega/src/CSF/ip.o Atmega/src/CSF/mac.o Atmega/src/CSF/mb.o Atmega/src/CSF/mbap.o Atmega/src/CSF/mem.o Atmega/src/CSF/misc.o Atmega/src/CSF/net.o Atmega/src/CSF/ringmem.o Atmega/src/CSF/tcp.o Atmega/src/CSF/tcp_block.o Atmega/src/CSF/udp.o src/cpu.o   -Wl,-Map="Atmega.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mrelax -mmcu=atmega1284 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega1284"
K:\Projects\WebServer\WebServer15\Atmega\Debug\Makefile(239,1): error: recipe for target 'Atmega.elf' failed
  The command exited with code 2.
 Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "Atmega.cppproj" -- FAILED.
Done building project "Atmega.cppproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
ZIP up and attach your AS7 project.
Quite honestly,   AS7 works fine for C++ projects.
If your original UC3 project worked ok,   it should rebuild for a mega1284 ok too.
I do not have any experience with UC3 but plenty of code that runs on Mega, Xmega, ARM-M0, ARM-M3, ARM-M4
Did you Google cxa_pure_virtual? It should have hit the sticky thread at the top of the compiler forum
This.. https://www.avrfreaks.net/forum/...
I had forgotten.   It looks as if I just added
extern "C" void __cxa_pure_virtual()
    while (1);
to my "usual" glue file.cpp
I am surprised that there is not a weak function already in an object library.
OTOH,   it is probably wise that user actually thinks out an implementation of some sort or another.
Of course,   I had forgotten completely !!
But at least that form of catch-all means a debugger ends up here (or times out a watchdog).
Thanks Guys,
No idea why I needed to do it, but I put the code in from the sticky note and it worked!
It was very strange I simplified the code down as far as I could and I found if I removed a constructor it would compile,
if I left it in it would fail. I tried making a simple example to recreate it but I couldn't.
I had also seen the odd segmentation error mentioned in the sticky, nothing that a recompile didn't fix but hopefully that's fixed too.
Cheers, Now I can get some sleep!
