Problem with TIMER1 CTC mode
4 posts / 0 new
I have a problem which I have not been able to solve and it is making me crazy. I am using an interruption to change the width of the PWM pulse in a ATMEGA328P at every cycle. Actually my code seems to be working for a while, but after some cyclic time, the TIMER1 seems not to respond properly (see the photo attached: the high frequency signal is where my code is changing the PWM every cycle, so it is working. But after ~27ms it keeps in the same state for ~32ms. In other words, it stops working for ~32ms and it happens cyclically). Can anyone please help me to find out what is the problem with my code?
My timer configuration:
 cli(); //Disable interrupts
 DDRB = (1 << PORTB1); //Set port B1 as output in the in the register DDRB
 TCCR1A = 0;
 TCCR1B = 0;
 TCCR1A |= (1 << COM1A0);
 TCCR1B |= (1 << WGM12)|(1 << WGM13); //CTC mode, using ICR1
 ICR1 = 511;
 TIMSK1 |= (1 << OCIE1A); // OCF1A: Timer/Counter1, Output Compare A Match Flag is enabled. Interruption is executed when the TOV1 Flag is set.
 TCCR1B |= (1 << CS11); // clk/8
Sei(); //Enable interrupts
Code running in the interruption:
volatile int InterruptionArray [255];
volatile int counter1 = 0;
ISR(TIMER1_COMPA_vect)
   ICR1 = InterruptionArray [counter1];
   counter1++;
   if (counter1>ArraySize)
      counter1=0;
you're probably trying to load a compare value that is less than the timer's current value - thus it has to do a full count cycle to compare match. It takes a finite amount of clock cycles after the last compare to execute the isr, save the processor state then execute your code. In the mean time, your counter has been counting.
   counter1++;
      counter1=0;
That is wrong, unless ArraySize is not actually the size of the array, but one less.
Stefan Ernst
Thank you Stefan! This was the problem. The error was blinking in front of my eyes, but I could not see it, maybe I am working too much...
