Setting single bit on PORT toggles multiple bits on PIN
10 posts / 0 new
This is regarding the mega2560 and I cannot figure out this strange behavior. If relevant, I'm using an Arduino Mega2560 and Atmel Studio 7.0. I am not using any Arduino libraries.
It's regarding this line:
PORTL |= (1 << PL3);
I'm debugging this with serial communication.
Immediately before this line, PORTL contains 00000000 and PINL contains 00000000.
Immediately after this line, PORTL contains 00001000 and PINL contains 00001110.
As I understand, PINL should be 00001000 after that line, not 00001110. Toggling a single PORT bit should change only a single PIN bit right?
I've also tried debugging this with Atmel ICE. Toggling a single PORTL bit through I/O View also sometimes toggles multiple PINL bits. I'm also not using any of the alternate functions of PORTL (no Timer 5 in the rest of my code, no Timer 4 Input Capture either).
I don't want to show the rest of the code because it's really long. But what could cause this kind of behavior?
Thanks!
What do you have connected to those pins? Are they floating? Any shorts between pins?
There is nothing connected to those pins. I just have the board with only a usb cable plugged to the Arduino's serial outlet.
So the PORTL (or any other port)  pins are floating they can pick up nearby charges and can assume any value as well as possibly suck a lot of current.
Put a load on those pins (10K? to ground) and see what happens.
That is not really a good question.   Pin is a read register* that always reads the state of the physical pin (which could be shorted to gnd or Vcc)...if IO direction is set as an output, then the value set in port register is the intended output value (which can also be verified by reading port).  So if the  IO is shorted reading PIN (actual/transient value) may disagree with reading PORT (assumed/intended value).
Normally if an IO is an output we never read PIN, just set PORT & assume the desired level is present.  So the PORT value (assumed value) is the working value.  PIN changes may lag due to heavy capacitive loads or just fast timing in general..  So relying on PIN  (for other than true inputs) can cause issues.  Some chips (such as early PICS) suffered from read-modify-write difficulties, since they lacked the equivalent PORT register.
*also, as an extra feature :Writing a logic one to PINxn toggles the value of PORTxn, independent on the value of DDRxn.
If nothing is connected to the pins then the value of the PIN register at any time is undetermined.
Why is there a "Highway to Hell" and only a "Stairway to Heaven"? A prediction of the expected traffic load?  - Lee "theusch"
 Hmmm...what about the internal pullup? surprise  Perhaps that is considered being connected to something.   I'm often too determined to determine if something is undetermined.
It is, but only if the code enables the internal pull-up.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
You nailed it. Connecting the input pin to something fixed everything and PINL2 no longer reads HIGH (1) where it shouldn't.
You're completely right, it's a weird question. I should have mentioned the reason why I'm so fixated on PINL is because I need to check for an input on PINL2 after switching on PORTL3.
I also tried enabling pullup on PINL2 and then toggling PORTL3 but that actually flipped on even more PINL bits where it shouldn't have (this is with floating pins).
So problem solved. Lesson learned for me: don't have floating pins and try to use PIN values. Thanks everyone! You guys are awesome!
Please mark the solution - see Tip #5
