Syntax for function calls.
11 posts / 0 new
I am aware of, and have used in the past the convention of:
if I have a function which takes a struct of two integers such as:
typedef struct {
    int a, b;
} twoInts;
and have a function which accepts that struct as an argument such as:
int addTwoInts(twoInts input) {
    return input.a + input.b;
that calling this function can be done in two main ways...
twoInts foo = { 10, 20 };
answer = addTwoInts(foo);
or, more simply.
answer = addTwoInts({20, 20});
1st, is there an actual name for the second method... like...erm... implicit struct creation or something?...
2nd I'm trying this in AtmelStudio 7 and getting syntax errors, "expected expression before '{' token". Which seems odd as I know I've used this kind of syntax before.
Thanks in advance for any clarification people can offer on this.
To me, it is "just like"
void foo (char * MyString);
foo("XYZ");
There is a name for it but I don't remember anything about what it might be called. And, I can't help with your error message.
Try casting it to the data type like this:
answer = addTwoInts((twoInts){20, 20});
Nope, unless you have used a compiler that offered that syntax as a non-standard extension.
It is called "compound literal" and the real syntax is this:
answer = addTwoInts( (twoInts){20, 20} );
Stefan Ernst
If you are going to invoke it like that isn't a cleaner syntax simply:
answer = addTwoInts( 20, 20 );
as a result of:
int addTwoInts(int a, int b);
Don't try to over-complicate things if you don't need to.
(though I realise this may simply be a trivial example and perhaps the real struct is far more complex?).
LOL that you said "complex" as that was one of the things I thought of, real and imaginary parts of a complex number.
But anyway:  How many of us would do a lot of passing-by-value of structures and such in the first place?  Especially complex ones.  Very soon after the mentioned two elements, passing-by-reference looks a lot more attractive.
I think the second method is a gnu extension.
For me it works with gnu99, but not c99.
A c99 compound literal has the syntax of casting an initializer list.
That gnu allows the cast to be implicit, I think is an extension.
ISTR there was a discussion here recently about "compound literals" ... ?
Casting first solved this, great!
I didn't need to do this before, it "just worked", though that was both with Visual studio C++, and C in CodeBlocks, of course in both situations I've not payed much attention to the actual nuances of the different versions of the language or what flags are being used (Visual C++ vs vanilla, or the mingw C compiler in CodeBlocks vs gnu/gcc) trap for new(ish) players I guess?..
As you all no doubt have worked out the example was somewhat contrived, in the real scenario sometimes I want to call the function with an already created struct, perhaps deferenced from somewhere else or sometimes with a struct which didn't exist yet, and it seems messy to have to make the struct before passing it.
Anyway it's been a big help and I now know a proper name for it! Thank you all.
Really? You are talking about the difference between:
or:
twoInts data = {20, 20};
answer = addTwoInts( data );
That's almost the same amount of typing and, for my money at least, clearer to read.
Agree.
probably amounts the same in terms of generated code & memory usage, too - the compiler will probably optimise-out the intermediate variable.
EDIT
And, as noted, support for and, thus, use of compound literals is not so widespread
