How to create new custom character using LCD HD44780.
26 posts / 0 new
First of all, sorry for my English.  English is not my native language.
So, I have a problem with custom symbols on LCD.
First  of all I had created my custom character
const char customChar[8] = {
	0b00011,
	0b00011,
	0b11110,
	0b10010,
	0b10000,
	0b10000,
	0b10010,
	0b11110
Then I sent the command to LCD for set of  CGRAM adress.
LCD_send_command(0b00100000); //CGRAM adress is zero.
I transfer to specified adress an array of custom character.
for (uint8_t i=0; i!=8; i++)
		LCD_send_data(customChar[i]);
 Nothing works. Where is my error?
Of course, my full code:
#define F_CPU 12000000UL
#define RS PC0
#define EN PC2
#include <util/delay.h>
//LCD_FUNCTIONS
void LCD_send_command (char command);
void LCD_send_data (char data);
void LCD_send_string (char *string);
void LCD_initial();
void LCD_hex (char HEX);
// Character buffer of my symbol.
	0b00011,
	0b00011,
	0b11110,
	0b10010,
	0b10000,
	0b10000,
	0b10010,
	0b11110
// Main function
int main (void){
LCD_initial();
// LCD_FUNCTIONS
void LCD_initial (){
DDRC |= (1 << DDC2)|(1 << DDC0);
	PORTC = 0x00;
		DDRD = 0xFF;
			PORTD = 0x00;
				_delay_ms(50);
					PORTD |= (1 << PD5);
						PORTD &= ~(1 << PD4);
							PORTC |= (1 << EN);
								PORTC &= ~(1 << EN);
									_delay_ms(5);
										LCD_send_command(0x28);
											LCD_send_command(0x08);
												LCD_send_command(0x01);
													_delay_us(100);
														LCD_send_command(0x06);
															_delay_ms(10);
																LCD_send_command(0x0C);
void LCD_send_command(char command){
	PORTC &= ~ (1 << RS);
		_delay_us(40);
			PORTC |= (1 << EN);
				_delay_us(100);
					PORTD &= 0x0F;
						PORTD |= (command & 0xF0);
							_delay_us(10);
								PORTC &= ~ (1 << EN);
									_delay_us(40);
										PORTC |= (1 << EN);
											_delay_us(100);
												PORTD &= 0x0F;
													PORTD |= (command << 4);
														_delay_us(10);
																_delay_us(40);
void LCD_send_data (char data){
	PORTC |= (1 << RS) | (1 << EN);
		_delay_us(40);
			PORTD &= 0x0F;
				PORTD |= (data & 0xF0);
				_delay_us(10);
						_delay_us(40);
							PORTC |= (1 << EN);
								_delay_us(100);
									PORTD &= 0x0F;
										PORTD |= (data << 4);
											_delay_us(10);
													_delay_us(40);
void LCD_send_string(char *string){
	while (*string != '\0')
		LCD_send_data(*string ++);
void LCD_hex (char HEX){
	switch(HEX){
		case 0x00: LCD_send_data('0'); break;
		case 0x01: LCD_send_data('1'); break;
		case 0x02: LCD_send_data('2'); break;
		case 0x03: LCD_send_data('3'); break;
		case 0x04: LCD_send_data('4'); break;
		case 0x05: LCD_send_data('5'); break;
		case 0x06: LCD_send_data('6'); break;
		case 0x07: LCD_send_data('7'); break;
		case 0x08: LCD_send_data('8'); break;
		case 0x09: LCD_send_data('9'); break;
		case 0x0A: LCD_send_data('A'); break;
		case 0x0B: LCD_send_data('B'); break;
		case 0x0C: LCD_send_data('C'); break;
		case 0x0D: LCD_send_data('D'); break;
		case 0x0E: LCD_send_data('E'); break;
		case 0x0F: LCD_send_data('F'); break;
Are you sure that is the correct command byte?
Looking at some Arduino code, the SETCGRAMADDR = 0x40!  (please don't use binary numbers, all those 1's and 0's make my eyes hurt! )
It's not. The datasheet is quite clear and, as you say, 0x40 is the right command.
OP did a pretty good job in posting.  What made me lose interest is "nothing works".  Are we syupposed to speculate that it only means that the custom character did not appear as desired?  Or that OP's homegrown LCD libray shows nothing but one line of black boxes?  [fails to initialize]  Or shows no pixels at all. [bad contrast setting]  Or all pixels "on". [ditto]
A forum search here should uncover custom-character discussions.  I know I've pasted my work based on CodeVision's example.
https://www.avrfreaks.net/commen... and I posted my code.  There are a number of similar threads.
Pretty much what you and the other respondents have posted:
void define_char (unsigned char flash * map, unsigned char code)
unsigned char command, looper;
command = (code<<3 | 0x40);	// write to CG ram
for (looper = 0; looper < 8; looper++)
	lcd_write_byte (command++, *map++);
return;
Thanks for your answer.
No of course. It works very pretty, but I just can't understand how to write to LCD custom characters and nothing more.
In one word, I follow a clear sequence of actions, but there is an error.
Upgraded code:
LCD_initial();
	LCD_send_string ("Your custom");
		LCD_send_command (0xC0); // Line 2, Position 1.
			LCD_send_string("character is ");
					LCD_send_command(0x40); // set CGRAM to zero position.
							LCD_send_data(customChar[i]); // Transfer bytes to LCD.
Proteus cheme:
As you see, my custum character doesn't exist.
Your code snippit only loads the character to CGRAM, you must then print something that uses your new character.
println(0x00); //arduino example to print custom char 0x00   custome chars are stored in ascii location 0x00 - 0x07
Try
​int main (void){
LCD_initial();
   LCD_send_command(0x40);          //CGRAM adress is zero
      LCD_send_data(customChar[i]); //save char on adr 0
   LCD_send_data(0);                //print char from adr 0
Feni wrote:
LCD_initial();
What's with the code wandering off to the right margin like that??
surprise
The idea of indentation is that it shows "hierarchy" - not just sequence.
For example, the above would usually be written as:
LCD_initial();
so only the last line is indented - as that one is controlled by the 'for'
Note that it is also good practice to always put in the braces - '{' and  '}'  - even when not strictly necessary; eg,
this makes the code easier to maintain - you won't get problems if you later add stuff to the loop, but forget the braces...
EDIT
typo
Thank you, but it doesn't work.
I tried to do this and the resolt is the same :(
What code did you try?
The layout of the source text  has no effect on the operation of the code.
If you want to discuss layout of source code, it would be better to start a separate thread for that ...
Probably in Compilers and General Programming
You can give a link to this for reference.
So... I understood how to write my character ro CGRAM of LCD. But, I can't get any character from DDROM.
For example:
I write my custom character to CGRAM to LCD. (doesn't work)
LCD_initial();
		uint8_t adress_one, adress_two;
			adress_one = 0x00; // CGRAM adress = 0x00;
			adress_two = 0x01; // CGRAM adress = 0x01;
				LCD_send_command(0x40 + adress_one); // Set adress for writing of data.
					for (uint8_t i=0; i!=8; i++){
						LCD_send_data (0x00); // Display the custom character by adress = 0x00.
But, if I just display any character from DDROM of LCD, it works pretty. It means there is an error in code and I can't find this error.
LCD_initial();
	LCD_send_data (0xFF);
Although, this code doesn't work already.
LCD_initial();
	LCD_send_command (0x40);
			LCD_send_data (customChar[i]);
		} LCD_send_data (0x00); // Display the custum character.
		LCD_send_data (0xFF); // Display the character located by adress 0xFF;
This
​int main (void){
LCD_initial();
Please can you fix the indentation on any subsequent code you post?
It is almost
          impossible
               to
                   read
                       code
                          that
                               has
                                   an
                                       increasing
                                            indent
                                                 on
                                                    every
                                                         line!
And in your latest code (#14) you appear to be trying to use 0xFF as a definable character?? That won't work. The HD44780 only supports 8 and they are numbered 0x00 to 0x07.
(what's more if you print any of 0x00 to 0x07 on screen and then go back and make a new definition of any one of them all the existing output of that character will immediately change - so you can only have 8 different ones on screen at any time).
Hmm... If I understood your messgae correct, I use Atmel studio 7.0.
Thanks anyway.
BTW I figured someone must have an example somewhere showing this working. Google found this for me:
https://hackprojectssol.blogspot...
It is almost
          impossible
               to
                   read
                       code
                          that
                               has
                                   an
                                       increasing
                                            indent
                                                 on
                                                    every
                                                         line!
Yes - that was my point in #9
Then you should certainly be able to write code without this bizarre ever-increasing indent!
No doubt a significant number of people here use Atmel Studio (various versions) - and manage to produce "normal" indentation
There are plenty of styles to choose from: https://en.wikipedia.org/wiki/Indentation_style - but this "ever-increasing" indent jut makes no sense at all!
Thanks you very much! It works perfectly!
Lol :) Okey :) Thank you very much, I found my error :)
Total votes: 2
Feni wrote:
I found my error :)
For the benefit of the next person who searches and finds this thread can you say what the error was? It may be they have the same problem.
Feni wrote:
I found my error :)
+1
Also, please mark the solution - see Tip #5 for instructions on how to do that.
Maybe this solution will be helpful for anyone else :)
LCD_initial();
unsigned char adress = 0x00; // Local variable of adress CGRAM.
LCD_send_command(0x40 + (adress * 8)); // Adress calculation.
LCD_send_data (customChar[i]); // Transver data of the custom character.
LCD_send_command(0x80); // Here was my error. I had to place a cursor to the desired position
LCD_send_data (0x00); // Display the custom character.
Hexadecima type of command + adress.
0x40 - CGRAM cell #0.
0x48 - CGRAM cell #1.
0x50 - CGRAM cell #2.
0x58 - CGRAM cell #3.
0x60 - CGRAM cell #4.
0x68 - CGRAM cell #5.
0x70 - CGRAM cell #6.
0x78 - CGRAM cell #7.
Thank you very much!
So now please mark the solution!
I would point out that there's another probable error, although it may not be causing problems right now; when you strobe the enable pin, you're not delaying long enough to be sure it'll work. My guess is that if you were running with a faster clock, it wouldn't. Most of the spec sheets I've seen suggest a 1us or so minimum strobe time.
